princess auto pass/fail thread
Outlander
Quebec, Canada
Princess Auto will have its illuminated magnifying lamps on sale from Aug 13th to the 25th for $45 (down from $70). I have one and they're great for old farts ... like me.
Been waiting for this to go on sale! Thanks!
Oh -the eyes are not too old...they are making things smaller :lol_hitti
young_buck
Alberta, Canada
3/8" stubby ratchet- PASS used it heavily for almost a year now without skipping teeth or failure.
[/URL][/IMG]
young_buck
Alberta, Canada
Lady foot pry bar set - PASS
Socket holders - PASS, I own every one they sell and they are holding up
3/8" drive crowsfeet - FAIL, they do work and have held up for a bit but they spread with force
[/URL][/IMG]
Double faced mallet - PASS I bought this for the heavier tasks that I didn't want to ruin my MAC mallet with since I only paid $7 for this one but I have quickly began using this one for everything
[/URL][/IMG]
Pincers - PASS I use them for clamping air hose clips
[/URL][/IMG]
Hacksaw - PASS the handle is holdig up well but the blades that came with are a big FAIL
[/URL][/IMG]
Convertable snap ring pliers - PASS but I only use it for ratchet and air ratchet rebuilds
[/URL][/IMG]
Long handle pliers - FAIL they work fine but due to the length the handles have a lot of give to them
[/URL][/IMG]
Rubber mallet - PASS the mallet is holding up great without chipping
[/URL][/IMG]
young_buck
Alberta, Canada
anybody have experience with the digital caliper? i need one and this one is reasonably priced
The Cobbler
Can't beat there tundra line of air hose. many hundreds of feet and no complaints. very flexible & light.
PA return policy is awesome . no sale is final until you're satisfied ...
PCO6
Newmarket, Ontario
Princess Auto is clearing out its Pro-Point circular metal saws for $82. I have one (see post #69) and I have been very happy with it.
The original price was $240. I have seen them on sale for $150 several times and that is what I paid for mine. At $82 this is a very good deal.
View media item 34368
PCO6
Newmarket, Ontario
That spins pretty fast for a metal saw, I thought most blades were limited to 1500-1800 RPM especially for ferrous materials?
The rpm seems about right when I'm using it. I think better saws like the Milwaukee that is popular is a few hundred rpm less.
PCO6
Newmarket, Ontario
You have cut 3/8" steel with that saw?!
Yes, and with the blade it came with. I'll probably get a Freud Diablo blade for it when the original one wears out. The Milwaukee saw will do a lot more than that. I think it's about 12 amp vs. mine which is 9 amp.
ADSR
That's pretty damn impressive! 3/8 is nothing to joke about cutting.
PCO6
Newmarket, Ontario
It will cut 1/8" steel plate about as fast as you can go through a piece of 2"x4" wood. You need to go a bit slower as the steel gets thicker but it works fine.
Here's a test of the Milwaukee saw. I'm not claiming mine will do what this one does but it meets my needs quite well.
The Cobbler
1/4 in. NPT Drain ****
SKU: 8507956
http://www.princessauto.com/pal/en/Compressor-Components/1-4-in-NPT-Drain-****/8507956.p
store price was marked as $0.99, at the cash rang up as $0.83 . I went back & bought a few more. Usually I see them for $5 and up. My guys are hard on them and seem to break one on compressor every 6 months or so .
young_buck
Alberta, Canada
While not "tools" in the traditional sense I use these on a semi regular basis without failure
http://www.princessauto.com/mobile/product/productDetail.jsp?productID=8294787
I have pulled and been pulled out of the mud many of times with this strap so far and it is holding up great, for $15 on sale it's worth grabbing a few since same size straps of different brands are well over $100 I have two and am picking another up for me an 2 for my buddy
http://www.princessauto.com/pal/Aux...ary-Spot-Light-Kit-with-Stone-Guard/4250151.p
These lights haven't been used yet, I bought a set to use as back up lights in the bush and right out of the package I am impressed, the lights are heavy and seem to be well built, it has the full harness and a toggle switch
They also carry lisle engine tools and there is nothin that I can say bad about them, made in the USA, high quality and low cost their piston ring compressor gets two thumbs up and their filter wrenches do too
Oldsmobiler
Coquitlam, BC
Bought the 1/4 and 3/8 version of this ratchet on a whim just in case something came up that I couldn't get at. OMG i use them for everything!!! Changed out a water pump on my cummins and it couldn't be easier with the 1/4 version
Rotator wrench
Fireball027
Niagara, ON
Just like the 3/8 one above this is my go to ratchet in tight spots. I have had it for years and is holding up great.
http://www.princessauto.com/pal/en/Ratchets/1-4-in-dr-Quick-Release-Stubby-Ratchet/8309528.p
Also this flexible magnet is great. I use it all the time to help cope with my butter fingers.
http://www.princessauto.com/pal/Mag...-Pick-Up-Tool-with-17-in-Flex-Shaft/2970228.p
I have a couple of these mirrors, after a while the plastic ball joint breaks, but I still give it a pass. The flexible shaft is great for getting into tight spots.
http://www.princessauto.com/pal/Magnets-And-Inspection/Inspection-Mirror-with-Flex-Shaft/2970229.p
As Young Buck said, not really a tool... but these recovery straps are great for the price. I keep a couple in the jeep and have paid for themselves over and over again.
http://www.princessauto.com/pal/en/Recovery/2-in-x-20-ft-Recovery-Strap/8020973.p
and
http://www.princessauto.com/pal/Other/3-in-x-30-ft-Recovery-Strap/8435125.p
PCO6
Newmarket, Ontario
I bought a 3/8" rotator ratchet mostly out of "curiosity". It worked great! :thumbup: I went back and bought the 1/4" and 1/2" ratchets as well. I think they're all on sale now.
flippin
Montreal - Ottawa
Young buck, the current sale is about to end (Sunday Feb 2) and there's a bunch of great things on special currently. I already did an independent post about the incredible Pro-Point impact socket sets on sale.
http://www.garagejournal.com/forum/showthread.php?t=234345
I also have these TITAN 3/8 in. dr 6 in. Locking Socket Driver Adapter, They are available in 3" and 6" in all three drive sizes. They are awesome. On sale till Sunday for only $6.
http://www.princessauto.com/pal/en/Power-Bits-And-Extensions/TITAN-3-8-in-dr-6-in-Locking-Socket-Driver-Adapter/8455370.p
This 24" Pro Point 72 tooth ratchet goes on sale Tuesday Feb 4th. It is extremely good quality and as others have said, Princess Auto has the best warranty in the industry. Regular price is $40, on sale Tuesday for $30.
lilredex
Toronto
Look in surplus for the Westward 2 1/2" combination wrench..........if you need one. You'd be all in just moving that thing to the job at hand.
MikeF2316
Thornhill, ON
I have that ratchet, and while I agree the quality is good, I think it's a too long. I find the handle is always hitting fenders or hood hinges or whatever. Of course the way I use my ratchet isn't the same way others use theirs so it may be good for you. I'd love to find a 15-18" one.
Sebastien
Quebec, Canada
You should check the Gray promotional flyer, I ordered a 8740L from my distributor, 15" long, 40 tooth mechanism and only 56$
Fireball027
Niagara, ON
Princess auto has Titan Inspection cameras on for 99.99. Has a 5.5mm lighted head. Runs on 4-AA batteries. Titan Model number 15054.
I picked one up.
Fireball027
Niagara, ON
rmsg0040
Toronto
those extra long pro-point ratchets are identical to ez long ratchets.
I personally don't like the detents
raskal
British Columbia
superautobacs
Vancouver, BC
I bought a 1/4" drive a couple months ago and decided I needed to get another one for the home. I gave them both a custom handle makeover as well.
This version is more compact than the Stanley version so I give this two thumbs up. :rocker:
powerstroker
Ontario
I'll play. These are my favourite PA purchase. Mine are holding up great and they don't transfer a lot of vibration. Price is right too. Around $30.
