I unpacked mine Friday night after work. There were no instructions, none, zip. It was very well packed and nothing was damaged though. The hoses look to be good quality and so does the pump. There was a bag of hydraulic hose fittings, some gold ones and some silver ones and some quick connect couplings. After studying everything for a while over a cold drink I figured I could tackle this. Now I know that the male quick connect goes into the female quick connect so that was no problem. Then there was these 4 male 90 degree hose fittings, 2 silver and 2 gold with a AN thread on one end and machine thread on the other so I knew the AN part went on a hose. There was also 2 straight male quick couplings with a machine thread with O-Rings so I figured these went on the pump since the pump was machined for a o-ring seal. That left the 2 other 90 degree ells so I put 1 end in the hydraulic cylinder and screwed the silver cylinder thingy into the other end. Then I snapped the quick connects together where I thought they should go. Now on to the hydraulic fluid (I think that is what should be used) but since there were no instructions with the pump I'm not sure of that either. I have no idea how much to put in so I filled it up to the top bulge on the tank.There are 2 bulges on the tank, one lower and 1 upper so I assumed they were the min. and max fill levels. Next I plugged the pump in and pushed the up button. The jacks were not under my car at this time, just sitting on the floor. After a few seconds they started to move up so I stood on them and cycled them up and down a few times to work out any air bubbles in the lines. Then I decided to put them under the Cobra and try them out. Now to position them properly I had to disconnect the hoses from each jack to route the hoses under the car from the front. The quick connects leak a lot of fluid when you first uncouple them and if you are not real fast they leak a lot also when you put them back together so have lots of rags ready. I wasn't real happy about this on my RaceDeck floor.
Anyway after I was satisfied I had them positioned properly and cleaned all the fluid up I hit the up button on the control and the car raised up very nicely. I did not raise it to the max height as I wanted to check for leaks at all the connections. I left it up for almost an hour while I cleaned up and put my tools away and another cocktail. No leaks so I must have done something right. I guess my only complaints are no instructions and the leaking quick disconnects. Why they did not send instructions is beyond me!
May I suggest a moderator sticky this for a while so as guys get their units we can sort all this out without having to search the forum for this thread?
Thank you,
Jim
