did you break a tool this week?
y5e06
Austin, TX
I snapped my band saw blade this afternoon... picked one up at Lowes after an evening errand. put a big dent in my garage activities.
Jarhead0408
Who knows?
Yep! Snapped a SK 14mm socket in 3/8 drive. I was taking loose the rearmost bolt on my civics rear motor mount when it broke in three places. The bolt had exposed to road salt imo. I wasn't using an impact gun either.
rayh91
SoCal
Well, I found out my HF 24mm impact socket was cracked. Not sure when I broke it.
pendragon1998
NE Georgia
No, but I dropped my brand new 1" Stanley Sweetheart wood chisel on my concrete garage floor. As I saw it start to go, I just jammed my foot under it to (successfully) stop the cutting edge from hitting the floor. Didn't even give a damn if I got sliced, but luckily leg/foot and chisel didn't get hurt.
RivennHewn
PNW
A friend of mine did that same thing, only he was wearing flip flops.
Chisel was fine, but he got a trip to the ER out of it.
redwrench60
East Tennessee
You've got to break yourself of that habit. I've trained myself that when I bumble anything, even a socket I can't get the **** out of the way fast enough. I've seen several people get hurt, some bad enough to end their career by trying to 'save' heavy or awkward parts and assemblies they fumble. I've done it myself in the past but was lucky. You have to train yourself to save nothing or you'll try to save everything.
Kracin
Omaha, NE
hah, i have that habit when i wear steel toes at work, catch things so they dont break as they fall..
and i can attest to that being a HORRIBLE habit when you wear flip flops / slippas (4 years in hawaii), and when i was in hawaii i wore slippas every day i could, and dropped a few things and bit my lip hard when i realized it hurt to catch metal things with your feet, even your phone can be a big pain in the toe.
Mr.3-5-7
Mesa, AZ
Broke my snapon T30 in 3/8" drive, 15 minutes before the tool truck showed up. No lost time there.
kenburkholz
A guy I used to work with was out of work for over a year trying to stop a falling oxygen cylinder with his foot. The cylinder was safe, it was capped. His foot wasn't, he was wearing tennie runners. Ken.
CNGsaves
KS and OK
BROKEN Tool thread . . . . . and . . . . . . not a single picture yet ??
OP . . . you have no excuse . . . . you started the thread !!
Ed ke6bnl
Agua Dulce, Calif.
simple one, broke the 1/2 bit that is in the 1" hole saw drilled through and then when it hit the aluminum twisted off the 1/4 bit. no biggy
Beerman
West Columbia, SC
Broken 4 American made tools in my life, three on the same Honda Civic crank bolt. None recently.
That crank bolt was a *****!!!!
Strouty
Southern Maine
It depends on where you work, if I fumble something it can kill someone if I don't catch it.
jeffmoss26
Cleveland, Ohio
Actually, yes!
Went to drill a hole for a new lever door handle and my Lenox holesaw arbor snapped in half. I was able to use my smaller arbor and 7/8 holesaw as a 'nut' for the 2 1/8" saw and drill the hole.
Knowing myself, I will probably buy a whole new set of holesaws now!
1950mercury
metro detroit
Broke a old matco round head 1/2 drive ratchet (wright). And the matco guy gave me a new 1/2" 88 tooth. He said they dont make a kit for it. Now i cant wait for my old 3/8 to break
O
outdoorsman310
DE
oh i forgot I also broke my 10mm craftsman 1/4 drive swivel socket using it on a small air ratchet just pulling on it. and somebody else has broken my screwdriver. I have a pre broken one that I found in the dirt for prybar use
Steevo
43.49600, -112.04300
I broke an allen wrench trying to remove a retaining screw from a Milwaukee drill chuck. Then I tried another and turned it the correct direction to unscrew it (clockwise), and it worked.
CWP1616L
USA
Screwdrivers can break while using them for their intended purpose, believe it or not.
I've never had that happen. I use the correct screwdriver for each screw and use the tool correctly as it was intended to be used.
tweedlestan
Palmdale, CA
You da man.
I use screwdrivers in the same manner (correctly) and have still twisted brand new Snap on tips. Either I have the strength of a gorilla or sometimes screwdrivers fail from normal use.
I'd say it's the latter.
kunkernator
US of A
You da man.
My auto teacher was very strict about using screwdrivers as screwdrivers, and prybars as prybars, except in one instance; automatic transmissions. A small flathead screwdriver is the "prybar of choice". :thumbup:
And I couldn't agree more.
fivespdcat
I broke my snow blower today. Well I didn't really break it, it broke on its own. The main piece that holds the chute on is made of, you guessed it, plastic. And not just any old plastic, but ABS. That means it cracked today on all three holding points, just as I wrapped up round one of clearing snow. It really was a perfect time for it to happen considering I had 7" of snow then and now have another 8" on top of it (I'm being sarcastic here). There's no time to wait for a warranty fix or part to arrive so back into the basement I went for some Fiberglas work. Added a washer for strength and then fiberglass. the part is installed and now it's at least good for a few more runs until I can get a new piece ordered in and reinforced before installing it.
the tool man
I broke my 1/4inch ratchet from homedepot while trying to remove a stubborn 5mm bolt off a bench and also an axe handle trying to cut a root of a tree and well the axe head flew off the handle and the handle was wood so now I need to buy a ratchret and a handle
the tool man
I bought a 41 piece ratchet set from pittsburgh and that 3/8 inch ratch broke but I have alot of spares
Sent from my SAMSUNG-SM-T217A using Tapatalk
2oolhound
BC Canada
My 4 1/2" canadian tire Jobmate angle grinder died today while sanding. Took it apart, cleaned the commutator and brushes (had to resolder one). Will try to modify the brush socket so it holds the top end lower to allow for the wear and hope it works. This thing still looks brand new, even my pos B&D old one I bought used 2 years ago is still going strong. After looking inside I can see why it's worth spending some bucks on a good one, this one is obviously a disposable but I expected more out of it.
Jim C.
No. I almost never break tools. I remember cracking a socket about 30 years ago in college, and had to replace the guts of a 1/2" drive ratchet about 10 years ago after torquing down a lag bolt on a deck I was building in my yard. I've also broken a few drill bits over the years too. A few months ago, however, a Craftsman staple gun that I've owned for several years quit on me in the middle of a job so I took it back to Sears for a replacement. I went to the rack, found the identical gun, and took it and my broken one to the check out counter. The sales clerk then informed me that staple guns only carried a one year warranty. I didn't have a receipt for my old one, which was more than a year old anyway, so I had to pay the new one.....I also saved my receipt just in case!
Jim C.
T_Roze
Edmonton Alberta
Two weeks old. Bolt backed out, and blew apart while I was removing the rear spark plugs on a caravan. Happy I had an open palm!
Ordered a new bolt and spring for it, and it will be going back together with locktite!
DieselRiver
Madison, WI
Yeah this co worker yelled at me for not giving him an alignment job and i told him to **** off, he was quiet the rest of the day. Oh wait, different kind of tool.
