Citrogarage
Lippyp
Shropshire, UK
Fantastic as always, the atelier is looking great. I shall be using your pictures for inspiration as I need to repair/relay my very similar old cobbled drive outside my house here (house dates back in part to 1630) and your yard gives me lots of ideas.
ct71rr
Massachusetts
This is a beautiful picture. Once again, I'm impressed with your ingenuity and hard work!!
L
lucajack2cv
Italy N/W
Thanks for your kind words, here's the rest of the story of the drill-place:
Remembering that I had somewhere two beautiful supports, fused with silver hammered finishing, ve coupled them to a suitable measure metal shelf obtaining an above-drill-shelf practical and elegant..
Complete the drill-station a wooden panel with a practical drill-bits container made from an old.. aluminum rabbits feeder!
The shelving for small parts instead has quickly found a place on another pillar near the main entrance ..
L
lucajack2cv
Italy N/W
Sorry Vegar, no Panda 4x4 but in our citrofamily find place the Panda 900 "Dance" my wife bought new as a young girl back in 1992. In these days it's in mechanical revision..
L
lucajack2cv
Italy N/W
The modernization of the electrical system goes straight for the way he has undertaken of which we have some more detailed slide. Here's the underoof lamps..
And here .. the four fluorescent tubes that complement underoof lamps with a nice light-cut perpendicular to the door. also in this this case.. difficult to do less: 50 years-old hand-made lamps consists of a galvanized sheet metal bent and white-painted on the inner face with the electrical components directly screwed on it: Bzz.. Bzz .. ZOT!
Here the two rotary-switches "ILME" that turn on each one a pair of roof lamps..
And here the d'antàn main switchboard: the two small blacks switches "Ticino" on the top left of the panel light fluorescent tubes in pairs... The red light in the center above the general indicates that there is tension as the two big brown switches dissect the right- bank and the left one separately to facilitate any maintenance..
L
lucajack2cv
Italy N/W
While in the yard pile up parts, memorabilia and unfinished works (such as the iron gate ..) behind the door of the "energy room" leaning next to the garage, the re-wired electrical system allows the compressor to operate without the intervention of the 3-phases diesel Ducati generator..
yves64
PESSAC FRANCE
Hello Citrolover, still interesting your post !
I keep plates on hand
Nice Panda, despite when you drive one, if you roll on a ****, a two or three somersaults are guarantee
mofo62
Perù
Feliz navidad Luca &familia.greetings from Perù! :3gears:
Congratulations awsome work :bowdown:
V!
Aeminium
Portugal
Hi
This will be my very first post on the forum, but I had to do it here.
What an amazing and inspirational work, Luca. I had a great time going through the pages of your thread and will continue to accompany your endeavours.
Best wishes for you and your family and a great 2014.
Alex, from Portugal
L
lucajack2cv
Italy N/W
2014 must be the year of the rationalization of spaces and equipment of Citrogarage: a large amount of metal shelves is fortunately available for this purpose. A better use of space will give preference to the vertical dimension as opposed to the previous two-dimensional model "all scattered on the floor": a massive metal shelving stands on the head wall from two sturdy wooden shelves that set to about two meters in height and 25 cm for lean on a 2 meters high "doubling" wall of the infill of the porch that was built at a time when it served as a stable. The stability of the structure is provided by a multitude of plugs in the brick pillars and coupling the rafters..
Several climbings and boltings after, shelving start to be populated..
.. Some of the particular attachment of clips bolted to the upper beams of the roof:
From the beautiful view from up here you will also better enjoy the lamps wires and chains..
L
lucajack2cv
Italy N/W
The new shelves rack was followed by the reorganization of the bench-west and of the above shelves, the operation is marked by the same rationalism: goodbye to the colorful jars of screws and bolts that makes so "Italian". welcome to a system of practical small-holder plastic containers: the content will be identified by a special cardboard label leaving perfectly clear the counter. In the upper left, the technical library.
The stereophonic Autovox exhibitor-demonstrator moved to the opposite side, surmounted by three beautiful milk fat so that fans "Fonzie's garage." Besides, even for the bench-west the higher floors have remained in the service of decorative tins ..
L
lucajack2cv
Italy N/W
We must say that Citrogarage was already half-loft from 2008..
The second half was not. Primarily because I was sorry to miss the cathedral-effect, than because the large spaces were prepared to accept, sooner or later, one or more car elevators. The electric transformations , the extension of the air system and the general cleaning and reorganization of the spaces are in fact been triggered by the fact that for one of those elevators was finally presented an opportunity ..
The final sweep that cleared the bay No. 2 is preparing the mysterious advent ..
L
lucajack2cv
Italy N/W
And here he is, red and yellow that you can not look at .. long and wide that you can not photograph .. Voilà the futuristic four-columns elevator that will start to serve restorations and repairs on all types of vehicles, including DS or HY!
After almost thirty years of service in a historic body-repair shop, it is going to be firmly placed in the position that after an endless series of hypotheses defining this one as the most compatible placements with the access roads, the presence of the loft and the provision of a possible second bridge with two columns..
It is a bridge-bank manufactured by Universal Bench incorporating a kind of universal template that consernte to attack those hydraulic equipment with which the true coachbuilders straighten the cars involved in accidents.
In the beginnig I would have preferred a standard deck without all these bank stringers in the middle so that to change an exhaust line you beat eight times the head, but on closer examination-and in the absence of alternatives to equal the price- I considered it's best versatility, especially when I noticed that the platforms on which to run the wheels had already been divided into removable segments (so you can leave in place only those on which the wheels) and that the two large longitudinal beams were also removable, after putting in support of the car body and eventually anchored it on the central bank.
Unfortunately, this one being one meter wide, it is not directly usable to fixate a chassis of 2cv but there is certainly the way of manufacture some woodeno or metal elements that allow to do so.
In short, the future is full of promises for my new bulky "Christmas Gift"!
L
lucajack2cv
Italy N/W
Something, in this garage is finally operational, as the main desk, nice and clear now flanked by the side also features a vise:
Among the refinements, the drawer door of the electrical adapters. The first of the green containers, as you can imagine from the identification code (MICROSW-2POS/L351100) is intended for cutters..
The tin-door Svitol, contains Svitol:
The drill, it remains stubbornly out-of-service pending conversion phase:
And 'even started the fixing of the four legs of the lift, three bars diam. 18 per feet. The thickness of the concrete pavement does not exceed 17-18 cm and I do not think incorporating a welded net but I hope otherwise constitutes a proper support..
Alternating cycles of swelling and sweeping preparing the hole chemical anchor bars ..
Although the repainting will be the last step, I've got a folder-color of hammered-tints which I propose to use. It should open the debate on the color that suits most!
L
lucajack2cv
Italy N/W
:) Clean, tidy, light and spacious facilitate maintenance operations and exceptional works in a more rational and modern Citrogarage ..
..while a further shelving is rising on the metal furniture that faces the new elevator:
To remedy the fact that the center post is lame at the counter, I was reminded nothing better than hanging on the beams of the roof with this kind of network structure..
Meanwhile, the fervor of Reorganization and shelving is spreading to the loft ..
L
lucajack2cv
Italy N/W
The shelving is already completed, and other enhancements already put in place, the photos are old.. they can not keep up with the creative fervor.
The 2CVAzam has completed the maintenance and will be replaced by Roxie's yellow 2cv needing some body works.
;) Meanwhile my friend Bulè continues its project for a racing car that will look something like this:
L
lucajack2cv
Italy N/W
From the first days of 2014, several developments have occurred, at 01/21 I took opportunity to update subtracting a bit 'of time to work in the happy day of my birthday. Here I recieve compliments from my citroinfants..
It's completed and partially occupied the great shelving in front of the elevator (not yet active). One shelf is home to temporarily files containing almost 1300 "Type A" surveyed the Italian Citroen Car Historical Register (riasc.it). It seems to me a temporery suitable place..
Hangied between memorabilia, what I believe was the first calendar offered to members of the Italian 2CV Club in 1997, six years after its founding. On the cover an italian 2CV that is a long time living in the United States...
Store material goatskin six meters of height can be staggering and dangerous.. a series of glorious helmets is aligned on the highest shelf, ready to be worn:
bidouchon
France, Burgundy
"sablés de la mère Poulard" ;)
https://scontent-a-vie.**.fbcdn.net/hphotos-ash3/1474373_10202126163869328_409770341_n.jpg
did you went to Mont St Michel ?
Sham
Antibes, France
Thanks for the gorgeous pictures!
Your garage looks AWESOME! :thumbup:
What about the wooden floor you were installing in the other worshop? Is it finished? Any pics to share?
Wingnut65
Tampa Bay, FL
Nice lights, but I'm really loving that roof. We don't do it that way over here, but it looks like it has spent a lifetime to prove that it works. Love it! :thumbup:
Awesome Lift! From the colors you have in the Citrogarage right now, MT04 is the only one that will not stand out and be totally out of place. But that is just my thought...
Awesome Updates, Luca. Thanks for posting! And, a belated Happy Birthday! :beer:
Solidwood
Sweden
Hi Luca,
Congratulations on YOUR day. I am sure you need it, Glad to read more about you.
There is a big difference since a few yrs back. I hope you haven't floated away in the rain.
I guess you guys got a lot of rain too in the last month or two. Crazy right.
www.youtube.com/watch?v=us3dQ0nnlHY‎
Enjoy
Best wishes from south of Sweden
smschriefer
Yorktown, VA
I'd paint it MT03 and then paint your diagonal white safety stripes to a height of 1.5 meters - alternating the stripes direction on each side so as to make them appear as arrows when viewed perpendicular to the edge. This would keep with a theme you have done in other narrow areas. Viewing all four sides at once the stripe would look thus, /\/\ Otherwise, MT06, as it would blend in quite well.
eokie1
Great to see the updates, Luca !!!! I was thinking maybe the "safety" yellow for the lift, since once REALLY needs to be safe, using one !!
Metal shelves look GOOD, too, great use of vertical SPACE !!!
Warm Regards from America's OLDEST city-
Saint Augustine, FL
yves64
PESSAC FRANCE
Very impressive work....and still a funny backyard ! I love the chianti fiasco on the wall
and se volete scambiare una targhe de Libia,ho sempre francesi neri
