Lowe's Clearance Thread 2014
Slowboat
Green Mountains
Bryan, thank you!!! I brought in your picture on my phone (along with my 4 year old girl so I looked respectable), and they agreed to price match. I was $111 out the door with tax.
Thanks again,
Slow.
Here is receipt and sale sticker for the Lincoln Port a Torch set.
Note: I got additional 10% military discount, so it rang up at $94.18
I called another local store here in Easton, PA. They have in stock but not discounted. It had another item number associated with it and I was told some stores are not carrying it any longer and are discounting it, but the Easton store will continue to stock, but at the regular price. So it was just a lucky hit for me, but still, some stores may drop it too. Also, there is another set Lowe's carries online without bottles that retails at $199, Item #: 486625 Model #: KH777. It comes up online. My set is the KH776 and came with bottles. May have to do with the trend that bottles are usually leased and not owned.
drwheels
okla. city ok
can you see the tiny n below the bar code. That means it is going to be a non stock item. That is what the store people tell me. The bottles are worth over a $100.
ishiboo
Oshkosh, WI
Thanks again,
Slow.
Same here... thanks Bryan. They price matched (their clearance was showing $200+) and I used the 10% off, $98.80 out the door! :)
I was going to have to pay someone to cut the tabs off my bucket when I switched my loader to SSQA, now I can do it myself. Wonder if those tanks will last (obviously they come unfilled, I know) long enough to cut off both brackets. I haven't done O/A since high school.
erty67
Mig welding wire on clearance at my local lowes. Only had 1 each of the larger spools, but tons of the smaller ones.
i stopped in a local lowes that had non listed online and they had two rolls for $23 each :rocker:
alxdgr8
Seattle, WA
If you search the KH776 model you get item #98353 to show up.
Sadly it's not discounted anywhere around me.
erty67
The kobalt 34 pc. wrench set is going down again. Back to $49.99
Item #: 498909
Model #: 87156
mshell56118
Elkhart, IN
How do you guys price match? Do you get item then see if cashier will price match or do you ask at service desk and if told yes go get it??
zeekh
Upstate NY
Lincoln Electric Port a Torch 81597 $104.65 Bethlehem Pa. I opened it up. Bottles included.
I pulled trigger and got it. Had associate check local area inventory and several popped up, so it may be national.
The description said it would only weld 1/16" mild steel. Is that correct? IT also says with extra tip and larger acetylene tank it can weld 1/2" material
ishiboo
Oshkosh, WI
That's the rating. You can I'm sure do thicker stuff, but acetylene has a certain amount you can take from the tank in a certain period of time. It's rated to cut 1", which is what I'm using it for.
DezRanger
Gilbert, Az
Well my Lowes wouldn't price match, still showing a stocked item and wouldn't price match out of state. :(
Sent from my SCH-I545 using Tapatalk 2
Reit38
Iowa
Here's one to keep an eye out for : Lincoln Electric Port-a-Torch lowes # 98353
These are $299 in most stores, but I have seen them on clearance in a couple stores in DE. was $104 in one store and $74 in another.
Will be watching for this
Sent from my SCH-R530U using Tapatalk
zeekh
Upstate NY
Thanks for the info ishiboo
Is it safe to assume you can use the torch, hoses, & regulators on larger tanks?
ishiboo
Oshkosh, WI
Odd. The store I bought it from said it was a corporate markdown and non-stock.
Yup!
I believe the place I buy my gas from will trade them for whatever size tank you want, too. I know all tank sizes are $44/year to lease.
PassnThru
Bowling Green KY
John Deere oil change kits - includes two quarts of oil, filter, funnel and a small bottle of fuel stabilizer. Showing item 471955 on my receipt. Normally $31.** - picked up 4 last night for $4.65 a piece. They were unmarked - had a price check and the mower section guy knew they were non-stock and on clearance. When I checked out, they rang up full price. A manager was nearby and knew they were on clearance although they didn't show that in the system. So YMMV even if they are on clearance at your store.
an0nymous
Intersting thing about this, I used the online Lowes stock checker for my area and everything showed 299. Then I checked Arizona and it was the same. Then I checked PA and the online prices were also all 299, including at the stores were you guys bought.
I am convinced I saw this in the local Lowes 2 days ago for 250. I think the online pricing is wrong (for any stores clearancing). I don't think I've seen this before.
fred d
Metro Houston Area
Once the stock as been depleted, price goes back up to regular price so it may not show as on sale
an0nymous
Yeah, I've seen that plenty, but I scanned a few hundred stores and wasn't able to find one non-299 example.
buening
Decatur, IL
Note that they have both flux core and mig wire as you show in your pictures, so everyone pay attention to the wire you buy. I just bought the 178802 0.03 L-56 Superarc 12.5lb Mig wire for $15.05 at my Lowes.
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
Somebody said the same thing about those Record vices at Big Lots for $18...some ******* snatched them all up to sell them for profit! Can you believe the gall of some people?
:bitchslap
Super Sport :bowdown: = ignore list member.
Like I said before, This group has really gone down hill from a few years ago.
Used to be a great group of guys.
tinkergeek
Kobalt Assorted Pliers similar to Item #: 253677 $5.60 a set (vs 19.98)
in store and in computer at checkout but not on web site (picked up last packs here)
Wiss Quick-Change Folding Blade Utility Knife $4 vs 7.98 (hand marked)
A 3 part set of wire wheel, wire cup, and flap disk can't find on web
hand -marked down to 9.98 from 19.98. Look better than HF. Several more at this location
All were part of leftover holiday stock sitting back across from the ladders. Have been watching for price drops. Many items marked down by hand
Other items included magnetic socket trays for 3/8 and 1/2 sets $10, lots of traditional plastic socket tray sets metric & SAE $3, some 2 pack 7+" saw blades course, lots 10" saw blades 3 pack 40T, a wrench and bit set.
loranger
DFW, TX
I tried to get a local store to price match the cutting torch, but the tool department guy wouldn't do it. He checked and it still showed to be a normal stock item. Said he sold 7 last year so it was a "decent seller".
an0nymous
1/4 inch flex ratchet is down again locally:
1/4-in Drive Quick-Release Flexible Head Ratchet
Item #: 337314 Model #: 85852 $6.25 1 $6.25
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
Man, my Lowes has been dry as a bone the last 6 weeks, and I'm talking prohibition era dry. Only thing remotely at a lower price was a $1 each hand drywall sander, which I decided I really didn't need even at a dollar. It is so bad, they even took the clearance little area they had and got rid of it completely.
Looks like it's back to my Menards deals thread again for awhile till things improve here. Shoot, I've even finding better deals over at Kmart at the moment... - Paul
shopboy13
NY
[QUO TE=Harrison2;3781194]will that 1/4" head fit on the body of a 3/8" tune up kit ratchet?[/QUOTE]
That's a fantastic idea.
Brians VWss
INLAND EMPIRE
Picked up all 3 LED lighted ratchets. The switch just unscrews from the back making it flush with the top of the ratchet. All 3 totaled under 20.00. Also picked up a 1/4nut driver for 0.94. Added the handle to the 1/4 ratchet
Harrison2
Bay area and UK
Sent from my iPhone using Tapatalk[/QUOTE]
if it does id take a 1/4" head on a 3/8" body, il pay the cost of the 3/8" kit plus shipping to me.
an0nymous
re: the head swap - hold on, I'll check.
edit: Sorry guys, thats a no-fly. It's not even close.
stage20
pcola FL
Kobalt channel locks are horrible. I bought a 3 or 4 piece kit and only have the 12 or 14" left because I don't use it. The rest slip bad. Tosssed them out.
Sportzmaniak
Browsed my local Lowes, found a few good deals on some Kobalt tools. Also found a good deal on Kreg Deck Jig, I have no use for it, maybe some of you do.
[/URL][/IMG]
[/URL][/IMG]
Kobalt Triple Cut Utility Tool
$12.98 regularly $24.98
498922
