Lowe's Clearance Thread 2014
sdavis622
Surprise, AZ
18 1/2" tall X 21 1/2" deep X 36" wide. Hope that helps.
Just finished assembling mine. Pretty happy with its quality for $67. I added external tooth lock washers to all screws and nuts simply because I had them on hand. Hopefully it helps keep vibration from loosening them over time.
Sent from my SAMSUNG-SM-N900A using Tapatalk
elronin
Hialeah,Fl
A bunch of the Red head stuff has been on sale for a while now. On slickdeals there was a thread last week. had a bunch of idiots buying stuff that they had no idea what is was for. :wtf:
Dude i couldn't agree with you more. Was trying to get 20 3/8 by 5 inch wedge anchors for 32 cents. Was going to use them for 6 foot 4x4 Steel columns for a porgulla I'm going to build but the order got canceled. Probably ebay oh well got go be quicker next time.
MonoxieChild
Rockford, IL
Anyone with the tool cart that doesnt like how you have to lock it to keep the lid closed, i found a ghetto hack to fix that.
All i did was remove one of the lift supports on the inside. So now instead of a pair, there is only one. Now i can close the lid, and it stays down, or if i lift it slightly, the 1 support lift still has plenty of power to open it, and to hold it open.
PassnThru
Bowling Green KY
Yes - it is slightly annoying. But I just left one of the keys in it.
Automag88
I went to pick up a couple sets of the wrench rails today and found the 1/2" and 3/8" drive magnetic socket rails on sale for $3.50 and $4.00 respectively. I think they were normally $10 or $11
I forgot to say they are the are the ones that are set up like a little shelf that hold the sockets magnetically not the ones you snap the sockets on
fitz11
Fox Valley, WI
Don't buy those socket holders, they are terrible!
stage20
pcola FL
i thought about getting some for dividers in my big drawer between my flat phillips and nutdrivers.
:lol:
almost cheaper than some angle and i dont have to paint it or put a hole in my box if i want to change something up.
drwheels
okla. city ok
Chucks are still $12 here. The dewalt 12 inch three pack went back up today. I guess all of the bosch good buys are gone around here.
thewatusi
Philly Burbs
Finally got around to stopping in a store that still had some spark plug kits still in stock. Found them buried behind some other items in the automotive section. $12.58 is a steal just for the ratchet alone.
(part # 436178)
Brians VWss
INLAND EMPIRE
Local store had the max access wrench set for 4.58
Anyone use these are they any good. For 10.00 you could have 14 wrenches, mm and st. Store also had service cart for 70.00 trying to think of a reason to buy
kenped86
Small cup for paint sprayer. 248536. $1.98 reg $7.98
Sent from my HTC One using Tapatalk
kenped86
uploadfromtaptalk1395938888643.jpg 1/4" Female NPT couplers. $0.36 item 68604. handy for when those air ratchets go on clearance
Those wrench sets are $4.19 in my area. The odd thing is they have 3 different part numbers but yet they are all the same? Says they work on both metric and SAE there isn't seperate SAE and metric sets.
turmlos
Rochester, NH
The boxed/splined ends work on both SAE & metric fasteners, the open ends do not. 379797 has SAE open ends, 379798 has metric open ends.
wvrailroader
West Virginia
Are there any new coupon codes for Lowe's? I finally found the Kobalt tool cart for $71.60, but I can't find the $10 off coupon code.
wvrailroader
West Virginia
I kept putting the codes in from that site and they were all invalid. I just went ahead and got it for $71.60.
Sent from my DROID RAZR HD using Tapatalk
DLAB
Bought the 4 PC tune up kit tonight. And the 1/4 drive lighted ratchet just cause it was only $4.
stage20
pcola FL
The 4pc tune up kit here is showing new low price of 17.97. THe ratchet is 29.97 by itself. I need a long 3/8 ratchet but not sure if I should spend the money on something better quality? I don't want to spend 18 bucks for a ratchet then spend 50 or 60 for the same thing
DLAB
At my lowes the tune up kit was only like $12. I would have bought another but only saw one. But the quality of the ratchet seems to be pretty good.
DLAB
Unfortunately I didn't see any of those wrenches when I was there. I was hoping to find them.
P_856
South Jersey
I've been using it for over a year now it's a nice ratchet, 72 tooth I believe.
bareass172
N'awlins
I scooped up more of the socket trays today as well as the 29 piece Hitachi drill bit set for $20. Most of the other deals discussed here haven't been at my store also.
nicksnothereman
In the Mojave
I own them but I've never used them. I'm not sure why I bought them I'm kind of a stickler for non "it's metric AND sae!" stuff and don't really see much sae so... Probably use them when I have to replace the exhaust flange gasket on my car; almost always end up with sae hardware because I'm too cheap to buy the good hardware which is probably why I have to replace that gasket every year and a half.:lol:
In your case...it's 5 bucks for a set of wrenches. You ain't going to find anything cheaper including the harbor freight stuff. They look well built to me, most of the taiwanese kobalt stuff is excellent.
