Shed Build Construction
Mandres
What I don't understand is why you need to build another floor on top of the crushed stone floor you already built? Why not just use PT sills and frame the walls right on top of the foundation, as if it were a concrete slab?
D
D45
NW INDIANA
I wanted some air flown and air movement under the shed
Plus, as it stated earlier..... sitting the base on 4x4s will get the structure up off the ground, away from snow and moisture
allinon72
Indianapolis
That won't fly in Indiana weather, even with PT sills. I put my shed on deck pylons.
msgross
Central PA
If you aren't insulating then I don't see why 24" OC wouldn't work. It's enough for truss' on a normal house.
D
D45
NW INDIANA
Definitely not insulating the walls
I'd love to save some wood and cash by spreading out the wall studs a tad more
TLCObsession
Bellingham, WA
There is a simple technique called advanced framing that allows you to build on 24" centers. Easy, simple and no problems if you did want to insulate.
D
D45
NW INDIANA
I bought a boat load of 2x4s tonight, from 12' lengths, some 10' lengths and a **** load of per cut studs
Wall construction starts this week
Micscience
Nice build I like it a lot. I would like to extend my shed one day or just build a new one even though mine is fine it is a bit to small for my needs. Good luck.
Can someone help explain with what Mandres mentioned about the pressure treated sills as the base for the floor I can't seem to picture it in my head.
D
D45
NW INDIANA
Any suggests on door size and options for entry?
I was thinking about having two doors side-by-side and built from scratch..... 3' wide each......
This way when they are both open, I would have a 6' wide opening.......maybe 7' tall?
I think a roll up garage door would be cool, but what is the cost?
glider
Flint Michigan
Menards sell roll ups under the name Ideal. Just ordered some 7' wide by 6' 6" tall for $249 each. Can be ordered in any color. Barn doors look good but don't hold there tolerances well.
D
D45
NW INDIANA
glider
Flint Michigan
The seal is fair and could be improved on with your threshold. I use a piece of diamond plate. If you stack a strip of diamond plate under the seal it creates a dam. The installation takes about 20min. with two people. I believe there is a video on there web site. The opening can be set to your needs. The smaller the door you go with gains you corner space just inside of door. I have installed hundreds of these with no call backs.
D
D45
NW INDIANA
I have used a piece of 90 degree 1/8" aluminum angle channel before for my thresholds, just to help with wear and tear on the floor
D
D45
NW INDIANA
Install of the roll up door seems pretty easy, I am a fan
So, if I want a 4 foot wide door, do I need a stud to stud rough opening of exactly 4 feet?
D
D45
NW INDIANA
2 Side Walls Are Done......12 Foot Long sections
D
D45
NW INDIANA
I am going to work on the front and back walls tonight and tomorrow
Hopefully have all four walls built, raised and installed this weekend
Just need to decide what size door opening I want
4' wide x 7' tall
6' wide x 7' tall
D
D45
NW INDIANA
What should OC roof truss spacing be at, for a gambrel roof?
Once again, do I need 2x4s here or are 2x3 acceptable?
Lastly, what should I use for roof sheathing? OSB? Treated? What thickness?
D
D45
NW INDIANA
I like the roll up door also
For the price, it will save a lot of material costs and a lot of time building the two doors
D
D45
NW INDIANA
Going to start on the front entry wall this week
Still not sure on the 4' or 6' wide door
D
D45
NW INDIANA
How wide is an average riding lawnmower?
I'd love to have more than 2' room for storage on each side of the door......with a 6' wide door that's all ill get
jasong70
Just a couple of observations. You should double or triple the outside corner where the other wall butts up. If you're going to put sheathing on the inside, make sure you leave yourself a nailing edge.
Also, after you finish your front wall, be sure to add a second 2x around the perimeter, bridging the other 2x top plate. It'll make it solid.
For the door, a 5' door covers most bases. You can get an overhead garage door or a roller door like the mini storage -- that's what i use. If you go with a roller door, I recommend you put in a man door if you plan to go in and out allot.
Looks great so far.
jethrodawg
Southern NH
Go with a 60 inch door. Most riding lawners have 38-42 in decks (plus the chute).
You'll quickly realize how fast a small shed like that will get filled with stuff. Trust me :)
D
D45
NW INDIANA
Looks great so far.
Thanks for the info.......I will not be sheathing the inside, just leaving it bare studs
Yes, the front wall will be built with a few more 2x4s for added strength
The rollup overhead garage doors like Glider and I have discussed only come in 4x7 or 6x7 sizes.........I really don't want a huge rollup door up front, because I don't want to loose the storage and I think it will look odd to have something wider than a 6' wide door, with a 10' wide shed
