The VISES of Garage Journal
balane
I'm betting Balane masked it off before painting. On some vises that area rises above the first green part and some careful sanding can remove the overspray. Either method works. :thumbup:
I, personally, do mask those curves. First I find something that matches the arc of the curve, like a plastic lid or plate, then I put a piece of 2" wide painter's tape down on something flat that's easy to pull it off of. I lay the lid/plate down on the tape and trace the edge with a marker. Peel off the tape, trim along the line with a pair of scissors and then put it on the slide to line up with the curve. Mask everything else, paint and remove. It's easy.
Filson
NE WA
And here, I thought you slapped the piss out of your roll of tape against your magic vise stump and it turned out just the way you wanted. :lol_hitti
scrapdaddy
Dittmer, Mo.
Anybody have a Ridgid vise. These aren't old, but have 6" jaws made of brass. I bought the table and two vises for $125. Heck of a deal. I mounted my Reed 106 with steel jaws, on the other end. I bought another table with a Columbian vise on it, for $100.
I was thinking of trying to find some steel jaws for one of the Ridgid vises.
Fretters
South Yorkshire, England
I'd stick with the brass, personally. It's pretty much the perfect insert material if you don't abuse your vices. Nice and soft, (almost like copper, but won't marr as easily), yet won't damage anything but the softest of things in the jaws.
I like the looks of that Heuer vise; kind of funky.
Greats score on the Rigids! they come up once in a while, and are always well thought of!
Good job on keeping the Reed on the opposite end of the bench, you don't want that Reed fighting with the Rigids! :lol:
zkling
How do they compare to the other big old names like Rock Island, Prentiss and the like? There was one recently, a 6", it looked solid, but the weight spec was either way off or? Seemed drastically lighter than a 6" from the other brands. :dunno:
scrapdaddy
Dittmer, Mo.
Yeah, you're right. That Reed is always talking trash to the Ridgids. :) As far as the weight goes, the Ridgids seem as heavy as the Reed. They all came out of a hydro. cylinder shop.
Filson
NE WA
That Reed is ****. You should send it to me, and I'll send you a check so you break even. :bounce::thumbup:
Mark in Indiana
Southern Indiana
Hey Scrapdaddy: You did great! A couple of months ago I picked 3, 6" vises for $75.00 ea. They were >50 years old. I nominate you for a "you ****" award.:rocker:
All the vise friends who posted recently: Y'all got great looking vises. Sorry but I've been in lurker mode lately.
superautobacs
Vancouver, BC
These are pictures from 2009...
Here's my "No.4 Nodular" Schulz mechanics vise:
It reads: Joinville / S. Catarina / "Technologia De Vanguarda"
In the center: Ind. Brasileira
Schulz started making bench vises in the 60s.
bigcaddy
Orange County/ San Fernando Valley
I just finished up my little Paramo No.1 this afternoon. It came out so nice i might just have to keep this one instead of letting it go:D
Monte
Germany
Pascal
Belgium
Hi,
I just picked up this vice.
Can someone help me identify it?
The jaws are 14cm (about 5,5inch), they open 17cm (about 6,7 inch)
Thanks!
va.grouseman
Southern-Central VA.
Previously posted by Pascal
Ok B100, what is it?----Let's have it.
Craptain
Tampa Bay FL
Hi,
Thanks!
Pascal,
Can't offer much help. But it is a great looking vise. From my very rusty French I think that Brevet is Patent or document, so perhaps you could start by looking up that number wherever you are. France? Belgium?
I see that you have been around for a while and this is your first post.
bl00
Chantilly, Virginia
I don't know, but it looks pretty stout. No luck searching, but it might be easier if I could figure out what "UA. H" is for.
Fretters
That'd definitely make sense, especially with the design/style of this vice. Just seems a bit skimpy in proportions for something like that, and also why allow 3/4 rotation or so travel on it. It's a better guess than mine as to its function though. :D
AndrewH
Three Rivers, MI
Found a Desmond Stephan / Simplex 43S today for $50. It came out of a machine shop. Seems to be in great condition! Weighs about 70 lbs and has 4 3/4" jaws. The only problem is it's missing one of the screws that holds the jaw pads. Looks like a very unique screw so I'm not sure if I'll be able to find a replacement easily.
bigcaddy
If its a slotted screw, they can be had pretty easily and turned on a lathe to the correct shape. The large 5/16" phillips are the ones that can't be found.......at least for now;)
AndrewH
Three Rivers, MI
Its the same screw that is holding the collar on in the picture. Theres 2 per jaw pad plus the one on the collar. I read somewhere else while doing some research that it has a unique taper that isn't made to any standard.
Andrew
ABSTIFFGS
Twin Cities, MN
I'll play. I got this HUGE vise from a coworker. He wanted something smaller. I had a 4" craftsmen that he traded me even up for. Does anybody have any info on this thing?
Andrew
You take a Std Screw and "Make it So" like BC said.
If without a lathe, you could also chuck one up in a DP and file it. Time consuming, but doable.
bigcaddy
That can be sped up greatly with the use of an angle grinder and a set of calipers locked into the size you are shooting for. Just keep checking from time to time and you will get it perfect:beer:
Fretters
I'm not the only one who resorts to that type of thinking then. :D On that point, been considering for a while making something, or using a lathe headstock assembly, just for holding parts to spin for filing, rather than resorting to using the lathe. Would take up less room, no chance of stabbing yourself with the currently installed toolbit, :D and no worrying about getting any rough **** on the ways. It's another of those things on the rather long todo list. :D
You got screwed, I'd be glad to trade you another Craftsman so you don't take a loss.. :evil:
AS went out of business in 1960, so it's at least that old. :beer:
If you are going to set up something like that could it be made for either horizontal or vertical (upwards facing) orientation? Depending on what you are doing one might be easier to deal with than the other.
Hmmm, maybe a good use for part of a Shop Smith...
Fretters
I like that idea. :) Hadn't considered that. My idea had just been to static bench mount, horizontally, but a swivel arrangement sounds much better. As you say, some tasks are easier from a different angle. Going to have to get the brain in gear on that idea.
Any photo's of a Shop Smith unit for reference?
