balane
I, personally, do mask those curves. First I find something that matches the arc of the curve, like a plastic lid or plate, then I put a piece of 2" wide painter's tape down on something flat that's easy to pull it off of. I lay the lid/plate down on the tape and trace the edge with a marker. Peel off the tape, trim along the line with a pair of scissors and then put it on the slide to line up with the curve. Mask everything else, paint and remove. It's easy.I'm betting Balane masked it off before painting. On some vises that area rises above the first green part and some careful sanding can remove the overspray. Either method works.![]()
