A dream come true
R
robolop
Some pictures of the rolling cupboard.
Some of my stock of aluminium and wood.
When the closet is filled with all my materials, I wanted at least 10% of space left in my cupboards and drawers.
I accomplished this goal.
In my old workshop I had a corner that was always filled with fine thin strips of wood or aluminum.
Every time I had to pick something out of there, the rest fell over, and it was always a messy corner.
This I certainly did not want to have anymore and I ended up making this.
Everything remains at its place, and I have a good overview now.
Between the pedestals there was still plenty of room left…
The area in between is on small wheels.
I can shift the whole thing to the front, to place somethings behind it. And shift it all nicely under it, in place.
Here you can see the things I don’t need immediately.
When my eletrician asked me where I wanted the sockets, he looked weird when I said I only needed 1 per workingtable.
You can never ever have enough sockets he said.
Still, I wanted them mounted in another way than the normal ones on the wall.
I let someone fold me a stainless steel bar, and I nicely mounted everything in there.
You can see I also didn’t use the little cover around the sockets. Looks more clean to me, and…I saved me some euro’s, haha, lol
They are nearby, and there’s never an annoying cable on my table.
I counted all my sockets in- and outside my garage, and I can totally say…I must be nuts.
One of the nicest things in my working place, IMO, is still my sectional door.
Once the floor heatings is off, i’ll open it, and I get the nice scenery for free.
I’m also very happy with the nice working terrace, which has several compressed air-points.
This table will stay outside, I just need to cover it with an aluminium plate.
I can get everything outside in a second, and I can work outdoors.
I added rubber mats of 4mm on every table.
If I want to use my saw or mill, I just roll the rubber to one side, simple
Regarding the division of my drawers, I needed a closet which contained all my keys and screwdrivers, in a central point.
So I lose a minimum amount of time to take something.
You can also see I first measured the plastic units from Facom. So it all fits perfectly, and there no space around it.
I did the same with the plastic little trays for screws and nuts.
As for the routers (milling), I made myself something nice so I had a nice overview.
Soon much more with a little movie
kiwipip
Hey Robolop good to see you on this forum where your shop belongs. Keep up the good work look forward to your updates
R
robolop
The right part is now also completely finished
I also moved the gray cabinets that were in my old workplace
It's the intention that they get out of there at some time. I'm already making some plans for my garden shed, and they'll move over there when it's finished.
A second basin, next to the cabinets wich contain my polishing materials for the bmw, and EVERYONG MUST KEEP AWAY FROM THOSE .
***61514;
The long aluminum worktable. I also made it so that it fits nicely between when I do not need it.
Here you can see how I gave my welding set a place behind the sliding closet.
And against the wall, I screwed another rack to storage some other stuff.
I had a stainless steel plate of 2mm to bent and welded, for the workbench outside.
So it's protected for rain and snow.
jb3
Rhode Island, USA
this place is incredible. I don't think i've ever seen such a meticulously clean and organized workplace. Reminds me of an aerospace lab
Victorymike18
North NJ
Wow, what an amazing space you have built! Very well thought out and implemented designs.
I'm not exactly sure I understand the purpose of the big sliding cabinet, what was the intended purpose that having it movable fulfills?
And I apologize if you mentioned already but what do you do for a living? I assume a workspace like this is for a business or at least an income generating hobby?
BMcC
Colorado
This garage is easily becoming one of the more epic ones on the Garage Journal.
R
robolop
A couple of months ago I purchased myself a new belt and disc-sander. It looked almost identical to the model that proved it's service for over 9 years.
When I unpacked the new machine, I immediately saw that it was big dud.
I worked with it for over 2 months, but I bought more drive belts then the machine was worth.
Enough was enough.
I found the cause pretty quickly. The suspension of the engine was running skew;, and the front part of the roller was not beared.
I had the old one laying around, so I put the disc in all of this.
On the right you can see the old piece, with the roll that was beared.
Then I stretched everything nice and straight, and welded the 2 parts to each other.
The top side made pretty tight.
Did some more improvements on the side, so it was all runing straight.
Everything goes perfectly now, and I don't need to replace any drive belts.
volvo
PNW 45th Parallel
>>>In the meantime I’ve got a new friend, which keeps me company every day!>>>
I must have missed something? Other than your out of this world build.
Tyberius
Wilmette, IL
I've got a question. The rolling shelf: Is it simply used to move the shelved items closer to the work, or is their some other purpose to having the shelf on wheels?
I thought it was just to move the supplies (or whatever is stored on there) closer to the active work area, but maybe I'm missing something.
BHR4CE1
Long Beach, CA
I love the sliding doors over the storage cabinets. I did the same thing in my garage years ago, and yours is the first one I have seen that did that too. Bravo!
R
robolop
***61514;
R
robolop
In terms of organization of the workshop, this is (I think) the last thing I had to put in order.
I made two solid aluminum brackets.
These were made to hold the router table in place, once it's folded open.
If I do not need this, it justs hangs next to the table, and this doesn't takes any space somewhere else.
The roundells I milled, I provided with a layer of paper which they use to make seals from.
The advantage is that it doesn't scratch, but the best thing is that once it is established, it doesn't come loose from it's own.
This for the safety of the router-table once it is lifted.
80WTI_55_CHEV
bundamba australia
robolop,
your workmanship is second to none, i wish i had quarter of your talent and workmanship please keep us up to date with future builds as your quality of work will hopefully rub off on me. Thankyou Lee
