The strongest 1/2 inch impact gun?
gnx547
I'm looking for a new 1/2 inch impact gun and wondering what is the strongest 1/2 gun out there?
gsingh
NOVA
Ingersoll 2135 and SO MG725
Sent from my SAMSUNG-SGH-I337 using Tapatalk
firebox40dash5
Why don't we go ahead and recommend an Aircat, and a Chicago too, while we're at it? :lol: :p
I've got a 2135TiMAX, after putting Milton V fittings on it and unforking the shop air supply that I had halfassed when we moved into the shop, it's a beast. My boss has an older CP model, and a SO IM7100 beater gun, neither have ever succeeded at anything the IR has failed at. The IR and CP are both more than competent at snapping bolts up to about M14 anyway.
firebox40dash5
Cornwell cat4150.
Sweet, we got the Aircat vote, just need someone for the CP, and maybe the HF Earthquake? :D
I'd be curious to see a head to head of the big'uns, with a pretty much unlimited air supply... like 150psi, big tank, fast compressor, and just a 50' 1/2" air hose and one quick connect. Different guns seem to react differently to various air supply restrictions. Before I upgraded the shop air system, the CP would sometimes outdo my IR, but now that they can breathe better, it won't anymore. Always been sort of interesting to me since it doesn't seem like there's a way to quantify the effects other than just trying.
Mr. Brooks
Can we ask why you need the highest rated one? Work reasons or GJ mentality (bigger always better)?
colin39
Facom ns.3000f/mac awp.050 is the best for unfastening ,and possibly the most expensive. The ir and the so are the 2 most common In every workplace ive been in I think its a person thing.
DieselFxr
near Seattle,WA
I vote for the TiMax its the most powerful 1/2 and the 3/8 as well that I have owned and used in my almost 30 years of wrenching.
shampoop
SW Washington
Home air or shop air? Big thing to worry about. My IR kicks *** with proper air pressure/flow, but on my lousy shop air it's got no balls. 120psi at the tank simply isn't enough even with high flow 3/8" couplings and a short hose.
ADSR
Average Air Consumption (CFM): 5.1
Blow Rate Forward: 1160
Breakway Torque (FT LBS) 1260
Drive Size (IN): 1/2
Free Speed (RPMS): 7225
Weight (LBS) 4.6
Overall Length (IN): 7-3/32
bob15
Northeasten, CT
Difference between the Snap On and the Proto in breakaway torque is 70ft/lbs (Proto having more) or 5%. Or in other words, basically nothing (sorry lord, 5% isn't a killing number). We aren't comparing the 600ft/lb IR231 to either of the aforementioned impacts. If the Snap On has more airflow or higher pressure or the high flow connectors and not the Proto it will have "more power".
The Snappy does consume less air for the power output, a bonus. Also the Snap On is USA made......Proto Tiawan
ADSR
What's the price of the snap on? The proto is on for 250 bucks.
ADSR
I'll take the American made gun. Look on e-bay and you can buy them new for $200 and up.....cannot complain on that.
Problem with the snap on is the balance. Go pick up a proto before you dismiss it.
Or are you one of those kool aid guys?
OP asked about the strongest, and the proto beats the SO and the IR. It also beats them in price, which is a big factor.
Skin
Boston
Of the ones i've had (paper specs aside)
AWP050 (versions also rebranded under Proto, Facom, and Sidchrome)
MG725
2135QTIMAX
in that order. The MG725 falls to third place with the muffler installed, both impacts are so close in power its honestly a toss up, certainly no clear cut "winner". The AWP has a little bit more brute force.
proto makes the gun for MAC
No, fairly certain its a contract between Stanley and PTP. They're made in Taiwan and strongly resemble other PTP impacts despite Stanley's claim that it was designed "In house". The trigger and reverse lever design is a dead give away-nearly identical to other impacts like the CAT line from Cornwell.
colin39
No, fairly certain its a contract between Stanley and PTP. They're made in Taiwan and strongly resemble other PTP impacts despite Stanley's claim that it was designed "In house". The trigger and reverse lever design is a dead give away-nearly identical to other impacts likw the CAT line from Cornwell.
I was under the impression that facom made the gun originally
mine dam fine gun, hasnt been beat or struggled yet, its also better than my ir and so mgt and a hell of a lot lighter than the mgt
Skin
Boston
First brand it came out for was MAC in 2011. Sidchrome in 2012, Facom and Proto last year.
The Proto has a slight cosmetic difference compared to the others around the trigger in that its missing what i'd call the trigger stop. All are essentially the same though in that they're rebranded under the Stanley family. Like i said they seem to be in an exclusive contract with PTP.
bob15
Northeasten, CT
I handled the snappy years ago and the balance never bothered me. As for the kool-aid, look at another post I made, i still have my IR2131. If I need anything bigger, I go with my 3/4" Blue Point.
Jwych
Sioux city Iowa
whats wrong with aircat? i have a 1000-th and its been pretty decent for 1/3 of the price of the SO. I work on semi trailers and have some heavily rusted on nuts and have yet to meet one it can't break loose!
mopar01
Angola IN
I have an mg 725. Friend had the timax. The max worked better somtimes and I think it was the gun. Already sent it in once. The mg that is. Still has good power. But I probally would of went with the ir if I had to do it over.
Dusty61
Cincinnatus New York
I have a MG725 and a Aircat 1200k. Both are great and both have their uses. The air cat is quite, the snappy is not. I belive the aircat will best the snappy by a shade or two in breakaway torque but the snappy seems to tighten bolts better. Its personal opinion. Pick one you lile because you like it. I like the light weight and low volume of the aircat.
ADSR
MG725
2135QTIMAX
thanks for the correction. I didnt know that.
Jswain
Calgary, AB
Weight (LBS) 4.6
The thing they don't tell you is that is probably 1260ft/lbs if you run 200psi through the gun. Just like snap ons 1170 or whatever they claim but recommended torque is ~800 lol. And then the IR has around ~780 so realistically you could probably say they all are around 750-800 ft/lbs, so pick which color you like better/can get cheapest/has a repair centre near you.
Not saying anything against the Proto it looks awesome, and I bet it feels just as good...but I really doubt those numbers considering the 3/4" IR Qimax we have at work is only rated at 1350 and hits like a damn jackhammer
