BBChevro
El- cutting a section out of the middle step between the two flights. going to put me on the edge of building code due to riser variance, but if I get nicked on that ill deal with it then...
I once worked in a place where the top riser was an inch higher - it got me everytime - I never actually tripped over or fell down the stairs, but there were a couple of "anxious moments" (our parts were on the mezanine floor, so I was usually carrying an armfull of truck parts down the steps).
I know that it's already powder-coated, but...
If you aim to trim a very small amount (no more than about 1/4" ?) off the top of the final riser of the lower flight and the same small amount off the bottom of the bottom riser of the 2nd flight maybe you could do a slight "adjustment" (ie - create a gentle slope between the 2 flights) to the landing???
An inch doesn't sound like much, but it is very noticable in a single flight of stairs - you've made the right choice by doing it (whatever you do to reduce the overall height) between the 2 flights.
Mark
