PCO6
Not if you fill it with beer and ice.![]()
If you put that in your shop, you have to turn in your man card.
Here are a couple of tool boards I have on my walls.
I secure the tools to an insert that slides into the front of the bench like this.
[/URL][/IMG]![]()
If it was all rusty and you used it as a spittoon, would that get your man card back?
How about if it was painted red with FIRE painted on it and was full of ice and bottles of beer?
Home Depot sells some peg board in 16 by 16 inch sections. I built some frames for them to add some extra storage opportunities. The Husky wall cabinet is also very nice, I chose it over looking at the Craftsman stuff.
[/url]![]()
DSC01997 by cawthon_engineering, on Flickr[/IMG]
What kind of workbench is that?
Hi guys, I'm new to garagejournal. I joined specifically because I found this thread. I love the ideas and had to subscribe. Here is mine. I built a bench that I would need to use a lot of different things which would have to be secured but didn't want to bolt things down to the bench so I couldn't use it for anything else.
[/URL][/IMG]![]()
[/URL][/IMG]![]()
Then I store the tools I'm not using along the side of the bench like this.
[/URL][/IMG]![]()
When I want to clear it off to use a nice clean flat work bench I just slide in a blank insert.
[/URL][/IMG]![]()
The system works great. Any time I get a new tool I need to mount I just make a new blank insert and tie it to that. I use this stuff for reloading but it works just as well with bench grinders, bench vise, etc.
Here's my wee storage bit
Here's a bigger version of that in Adam Savage's workshop mancave![]()
That looks good but do the spray cans rattle and roll around when you open/close the door? Usually those racks just hang over the door, but did you screw this one in to keep it from moving?
Installed a spray cans rack from a 20$ shoe rack. Holds 36 pairs so 72 spray cans.
Thanks for the idea again!
I got mine at Bed Bath & Beyond tonight. Mrs. LS6 thought I had lost what was left of my feeble mind when I asked her to go there. She always has about a million discount coupons to that joint...
Tommy
Dennis Leigh Henry
Great ideas, execution. Simplicity. Excellent use of space. Thanks for sharing.
Paul
and.. repurposed bunk bed, keg / wash tub, and propane pole heater "top"
The bunk bed / overhead storage also has my 5' step ladder, and is where we store our corn hole boards, banquet tables, and outdoor umbrellas during the winter, and the pool cover during the summer.
The keg / wash tub was hard since it didn't have a handle to hang it from, so using hook eyes worked well.
The top to the pole style propane heater could have been wedged behind a workbench or tool box, but it is out of the way and away from potential damage stored bolted with wing nuts to the ceiling.. One can also see the bicycle hooks holding my sled too.
Not necessarily "up" on my walls but I did these a few weeks ago in preparation for some new equipment that I have ordered. I needed to get my metal stock under control as it was strung everywhere. I cut some 4" PVC at different lengths, capped them and mounted them to a 3/4" square tube screwed to the wall. This keeps them spaced out away from the wall the same distance as my base molding yet still allows the PVC tubes to sit on my foundation and support the weight.
Behind my disc/belt sander.
Some longer one mounted behind my drill press.
I hope this will help me to keep my metal stock organized as well as help me to keep a better handle on what I have and what I need when I get low. In the past I had metal anywhere I could store it and when purchasing metal for a project I kept overbuying in fear of running out in the middle of a project. As stock gets smaller/shorter I will move them to shorter and shorter tubes until it gets completely used up.
Mike.
