bob15
Agreed. Ihate posted a...how it's made clip at the snap-on factory, and they were stamping snap on and williams sockets on the same line.
At the same time, on the same press or two different clips in the same video (which i believe was the case)? I've already proven Williams and Snappy wrenches are different; so why wouldn't sockets be different? Do a Rockwell comparison between the two, and you will see a big difference. Even the screwdrivers aren't identical, as the OAL is different between Williams and Snap On. The Snappy's version of the OP's screwdriver I posted, is .25" longer (catalog length and me measuring it). That blows the identical out the window (close but no cigar).
As for the getting different steel alloys and heat treating/nitrating them differently, not very hard to do. Snap On's metal stock probably cost more than the Williams alloy, hence some of the price increase. Wrenches and socket alloys aren't even considered exotic metals. Having to go through heat with two different batches are normal. Where i work, before it was sent overseas and to NC, heat treat would run around the clock with a hundred different specs for treating different parts, most with different metal alloy call-outs.
Also, if Williams' sockets and wrenches are the same as Snap On's, how does the offshore Williams match up with Snappy? After-all, it is Williams......
bob
