Show off your lifts!!!
gordyy
North Dakota
Not what you guys normally lift did a little modification to mine so I can work on my tractors and the quads easily
shopnut
Florida
I installed my first lift in the Asylum this spring but forgot to post in this thread. It's a Bendpak HD-9XW in black.
Parts all laid out ready to go together:
Putting it together by myself with the help of the jib crane:
Some finished shots with the old Chevelle and the new Avalanche
A shot from above:
Custom twin reservoir air bottle system so I don't need to hook up to shop air to release the locks:
jimmie jam
fort lauderdale, fl
A shot from above:
Very nice. I have a HD9-STX and was thinking about the air bottle system. It seems expensive for what it does. Is yours from BP?
shopnut
Florida
Thanks Jimmie Jam. I waited waaaaaay too long for this lift. Hopefully you are enjoying yours too.
I expanded on what BP offers and built the air system myself. This link should drop you in my build thread where I explain it all:
AIR BOTTLE DETAILS - Asylum Reply #2646
If you don't have time to jump over there, this should give you a quick overview:
(And yes, I probably overdid it a bit, but I have a tendency to do that sometimes :))
600SL
Connecticut
My 4 post lift in CT. Soon to be moved in to my new Garage in NC. Perhaps a 2 post will be along side it.
AndrewnTX
Plano, Texas
A couple of pics of the day my BendPak HD-9 got installed. Many measurements, drawings, layouts and calculations of will it fit, or will it hit... the truck squeezed through just fine and tucks into the vaulted ceiling with inches to spare!
shellback
Jax, FL
Silverplate: What's your ceiling height? Did you remove ceiling dry-wall? Looks awesome! Someday, someday....
don long
southern california
I have 4 working lifts in and around my shop
The first one is more like a work bench that is adjustable
The 2nd one is for project storage as well as undercarriage work
The 3rd one is a light pull frame machine that I use for a work bench and a mid lift for doing body work, It will raise 7' in the air
The 4th is my dirty lift for preasure washing / changing engines and the like
Aquaticbob
Seattle
Also have another 4 post that is direct drive on from the outside that isn't pictured. One XPR 10, 3 XPR-10's, 2 HD-9St's with RJ-45s for each
Randy Forbes
SWFL
Some very nice__working__shops!
Now with just two (2) 2-post lifts, I feel so inadequate; must be lift-envy ;)
kenvb
Whitecourt Alberta, Canada
I just got a Dannmar 10 ACX wide post on Christmas eve from Princess Auto.in Edmonton . just took it off my trailer today and laid it out on floor. need help for the legs. here one peice 13 ft high . says on the side. Assembled in USA..Built in China. it looks identical to a Bendpac 10,000 my friend in Alabama has. we measured each others. the same!. he says his is Built in the USA.. dont think so. my son just put in a new Mac Tool 9000 hoist thats made in Pakistan.and $1000 more. paid 2900 for mine. its a asymerical lift shorter arms out frt ,longer out back.
97CV
Romulus,MI
Atlas PV-9P.
My son and I putting it together.
Distance to true 12' ceiling. Drywall should be fun :D
Done.
angrystroker
Earth
Atlas PV-9P.
Done.
I am wondering how you center the car on that thing? Even if there is clearance for the car pictured after the junk behind it is removed. That is a bad install with serious restrictions vehicle wise forget trucks go karts will not be a problem:lol_hitti
HD FLHX
Central Iowa
My mid-raise 6,000lb Atlas. I do more paint and body than mechanical so this type of lift is way better for my application.
Plus I can use it as a frame table
787B
Baltimore, MD
Umm, have you heard of asymmetric lifts? :rolleyes2
