Mini Precision cutters/pliers
game
Hi guys.
Its my first post but i have been lurking around for a long long time. Finished the tools from the old world thread and damn, this place is gonna be bad for the budget!
Anyway, does anybody have any experience with the Irwin 8 piece mini pliers set?
nanofrog
Hi guys.
Perhaps Amazon can offer some insight to their mini pliers.
What exactly are you trying to do, and what's your budget?
On the low end, you can go with say Craftsman or a number of poor quality imports for example, to mid-range, all the way to the top of the line products. Costs can run anywhere from ~$5 to more than $100 per pair.
Lot of variation, and top quality isn't as expensive as you might think ($100+ as a necessity is extremely rare, and usually for a very specialized profile).
Mohawk Dave
SoCal
Swanstrom is another top notch one...I guess they're big in the medical field. I have a pair of their needle nose...awesome quality.
nanofrog
They're primarily known in the electronics field (check the distributors page).
Medical fields use a lot of the same cutter shapes from what I understand, but the medical variants are usually made of stainless alloys and have no grip materials over the metal (to meet sterilization requirements).
A little history if you're interested; the Swanstrom family that started this company also founded Diamond Calk & Horseshoe, which they sold to Cooper Industries prior to founding Swanstrom. The original Diamalloy electronic cutters & pliers are still sold under the Xcelite brand. Newer Swanstrom stuff is quite a bit above in quality and design though (cutters, not tried their pliers), and is a decent value (i.e. run ~$30 - $45 per). All-Spec carries them if you're interested in an easy to deal with source.
How are the teeth on the needle nose, or did you opt for smooth jaws?
I've a pair of their cutters (S512E), and they're quite good (I've a mix of cutters, but only Excelta and Schmitz for pliers).
Schmitz are worth a serious look (cutters, and pliers are incredible; value is outstanding *purchase direct from the online store that's linked*), and you may have seen them before under other brands (CK Tools and NWS rebrand them for example). Another to consider for cutters is Tronex (cutters are the best I've ever laid hands on thus far). Haven't touched better pliers than Schmitz thus far FWIW, and at ~$28 per total (cost, currency conversion, and shipping from Germany), is one hell of a value.
Mohawk Dave
SoCal
hey nanofrog, great info!
To tell the truth, when I got my Swanstrom needle nose they were used and the teeth, which are simply perpendicular to the jaws, were already used up pretty good. So, in all fairness, I suppose I can not comment on how hard the steel is b/c I do not know....but the construction, fit and finish are top notch. The pivot is some kind of sealed bearing held in with a Torx screw...real fancy and smooth as wet ice on wet ice.
BTW...where are you? Country/state?
Mohawk Dave
SoCal
Of all these cutters mentioned, what size/model/make would be ideal for cutting 12 & 14 tin coated marine grade wiring for the 4x4 when it gets a whole new electrical system.
I have big cutters, but no reason to use big heavy tools at the workbench when a little light weight one would be more comfortable and controllable. Any suggestions?
game
Looking at spending maybe $50 to $100 on a set. Im currently using Ungar pliers and flush cutters. They are great. They look like rebadged Kleins.
I have been building and modifying guitar pedals/electronics for several years and until only recently had my eyes opened to good tools thanks to this place. Im always looking for tools to make the job easier.
jeffmoss26
Cleveland, Ohio
I have all but one of the range of Channellock mini pliers. I use them constantly for working on locks and electronics. Also have a few different Snap-on mini pliers.
nanofrog
don't forget the japanese ones
there are some good opportunities like these: *click!*, *click!* and *click!*.
Not really had access, so wouldn't know which brands to look into. :dunno:
FWIW, the first link reminds me of the Diamalloy/Xcelite type I mentioned in the previous post due to the spring (pic for comparison; click on the large/300.jpg for more detail). The stamped steel type in the second and third links, remind me of Piergiacomi (these get rebranded, including as Wiha) and Xuron.
The second and third pics also remind me of Hakko's cutters & pliers, which were the only Japanese brand I was directly familiar with for electronics (Amazon sells them; cutters, pliers).
Well, I do use these things daily, so I've used quite a few (and gotten pissed off a lot of them too, as they ended up as garbage, and I'm not talking about $5 el-cheapo specials from the flea market sites such as eBay). :D
Regarding the joint, it's a new take on a lap joint, where they use CNC machines to cut the blanks, then use a screw/rivet hybrid (what Swanstrom calls a Scrivet, but is being manufactured by just about every manufacturer of electronics cutters & pliers). There is no bearing however (closest, would be Tronex, which uses Delrin washers in theirs).
But the nut is pressed into one blank (riveted), and a screw is used to hold them together. It's why they're adjustable. It's also highly automated (CNC machines instead of people performing forging operations), so they don't need much human labor to produce by comparison.
And for cutters, this joint is just dandy. Not convinced it's the right joint for pliers though, due to multiple axis joint stresses, such as those generated from twisting motions. Box joints are better suited to pliers for this reason (pin/rivet is supported on both sides).
Regarding teeth, you'd be amazed at how many aren't that wonderful (flatten out from improper hardening <i.e. lack of as a result of cutting corners>, not formed properly from the factory <teeth are flat from day one>, teeth won't mesh, ...). See the links posted below, particularly on the Tronex & Schmitz reviews. ;)
There's another member, Precisiontools, that has done reviews on a lot of electronics pliers and cutters, and we seem to have the same type of approach and outlook. Well worth the time to read IMHO (right click the pics into another tab/window for larger images & not leave the review article).
Reviews:
Tronex
Schmitz
Knipex
NWS Micro-Line (these they produce themselves, the ESD line w/ yellow & black handles, are rebranded Schmitz)
USA, more specifically, NE Louisiana.
Most, if not all, electronics cutters aren't designed for that large an AWG (they typically top out at 18AWG, most being smaller). Can even get as small as 0.025mm for cutting individual pins on SMD IC's (really fine pitch stuff, and this is where they get uber expensive, as well as those with tungsten carbide insert jaws meant for cutting hard wire).
I might be able to point you to something, but what type of cut are you after (bevel, semi-flush, full-flush)?
You can learn about the different types of cuts from any of the manufacturers, such as Swanstrom (mentions others I didn't; manufacturers tend to use different names in their marketing, but those I mentioned are the most common, and correct terms). Download a few catalogs, and you'll get more info, and usually some nice pics or illustrations that show what the wire will look like as well as demonstrate how the blades meet.
You'll likely still end up with a large (what you're used to as "normal", say 6.5" - 8"), but they can be found in cuts other than bevel. Just be prepared to pay for them (i.e. Lindstrom, Facom, or Swanstrom IIRC offer them in Semi-flush). Full flush at this point, would be a pair of wire shears, such as those sold by NWS or Knipex for example.
What exactly do you need as per profiles, wire gauges, and what type of wire?
For example, if you mean to use them to cut guitar strings, you'll need something rated for hard wire. The best suited for that in electronics types, are those that use tungsten carbide inserts. And they're not cheap (go Schmitz if you need these, as they've the best pricing I've ever seen for them; much cheaper than say Erem, which will set you back nearly $200 per pair last I looked).
Now if you're after something to cut copper wire, you're in luck. :D You'd be surprised at how few you'll actually need for general purpose work. Pair of long and short needle nose (with teeth), and a cutter or two will suffice in many situations. And would be possible to get you decent tools at the top end of your budget (~$25 - 30 per pair will get you something really nice in a forged box joint; stamped sheet metal types, such as Xuron types, a bit cheaper per).
Same as Lindstrom FWIW (Snap-On own Lindstrom). Unfortunately, not worth the money anymore since production was moved to Spain (cutting corners).
You really can do a lot better for the money (less money actually). :eyecrazy: :D
Post is long, and I do apologize. But hopefully enough information it helps someone. :)
game
@nanofrog,
I did some research and I think the Ungars Im usung are rebranded Xcelites. They have "Made in the USA" stamped on them.
I think Ill go with a Pro America set on my next tool run. Id like to try a pair with a box joint.
Mohawk Dave
SoCal
Nanofrog. Awesome reply once again. Thanks for the effort put forth.
The 4x4 will have all GM Delphi/weather pack connectors. that being said I do not know which type of cut I want. I went through the pages you linked and see there are many different types. I have no idea which one is designed for a simple weather pack connector. Any suggestions? Also I have large hands so I don't know if that will come into play with using smaller cutters. It may be easier or it may be uncomfortable. I have smaller cutters and I've used them Lindstrom to be exact, but that was only cutting a couple things here and there so I've never been able to repeatedly use them and know if they are truly comfortable for extended amount of time
nanofrog
@nanofrog,
Don't know when you bought them, but Cooper Industries bought Ungar, and merged it with Weller. So it's very likely if they were purchased after the acquisition occurred.
BTW, the Pro America products apparently all use standard lap joints these days, just like the Xcelites (cheaper to make than a box joint). Seen older versions with box joints (can find the pics on Amazon), but suspect they switched to reduce production costs. I'd expect similar quality and performance to the Xcelites.
Should be just a step up from the stamped steel stuff though IMHO (not all that fond of the stamped steel for pliers; works OK for cutters, but just doesn't have the width to really bite into something as a plier to me).
nanofrog
OK, if you're going to be crimping on terminals, you'd be best served with a Semi-Flush. Gives you a nearly spike free wire end, which will give you enough wire surface to be placed in the terminal, and still last you a good long time before needing to be resharpened or replaced.
As per grips, the ergonomic styles tend to be longer for large hands (I have the same issue). For example, if you went with a Swanstrom, you probably want to look at the S512E that I have (E grips are longer). S512E will cut 18AWG all day long like a hot knife through butter (~$47 before shipping from All-Spec). Schmitz may come in cheaper, especially if you order more than one item at a time (save a little on shipping IIRC).
Tronex is the same way, and the ergonomics are nearly identical to the Swanstroms (some get rebranded as Excelta 5 star; usually more expensive, but you can find them from time to time at a good price on eBay). They cut even better, operate a bit smoother, but will also cost you more (~$75 last I checked).
Erem's ergonomic grips OTOH (Magic Sense line), aren't longer, nor do they fit my hand better than standard foam grips (cut extremely well, and I do like the hidden spring). I have 2x of these. The 812N would be a possibility (~$60; standard foam grip, not Magic Sense, which is a textured rubber), but IMHO, you'd be better off with the Swanstrom's or Tronex's longer grips.
What's your budget, and what's the max wire gauge you'll be cutting?
I presume most will be 18AWG and under, and larger stuff (Metri-pack) if you need, will require a different pair of cutters. So worst case, you'd only need 2x pair. Really heavy stuff will require shears (i.e. battery cable).
I can also help with crimpers should you need it.
Mohawk Dave
SoCal
Nanofrog...great info. Thanks again. Most stuff will be 12 to 18 on the truck. As far as budget, there really is none. Buy once cry once.
I have all the SO cutters, some Lindstrom and other small flush cuts, and then have German made ratcheting cable cutters for battery cable etc.
The Swanstroms and Tronex you mentioned look good.
As far as crimpers go I have some big Channel locks and Klein's....nothing special and very large and heavy for most stuff. I was reading about the SO ones on GJ but would like to look into the more specialized companies there too.
And do you happen to know what the best crimper for the weather pack connectors are?
nanofrog
Nanofrog = Precision pliers Ninja.
Sorry about that. :eek:
I use them for hours on end for extended periods of time, so it's close to my heart is one way to put it. Poor tools that don't fit or work as well, cause a lot of frustration/aggravation for me. Call me crazy if you want, but when a single pair can burn through most of a $100 note or more (tier 1 products), I don't see it as a good investment, and try to help others avoid making the same mistake. :D
FWIW, I've have the impression it's rather similar for you (electronics bench background). So primary hand tools such as pliers, cutters, and screwdrivers really get put through their paces, and you can discover what really works and what has issues. Just comes down to enough hours, that the smallest of differences/faults on the surface (may not even be noticed during occasional use, or considered acceptable), prove to be a major point of aggravation for very frequent use.
Fortunately, your reviews have really come in handy to help explain matters, (detailed photos are exceptionally helpful in this regard as well), so thank you for taking the time to create them. :)
platform389
^ Doesn't look very impressive. I'd give Wiha or Xcelite a try...they're into this business for a long time. I don't understand the Snap-on obsession. They make good quality mechanic's tools. But, if you're looking for a toothbrush...you should really buy a Snap-on toothbrush simply because of their reputation for mechanic's tools.
/rant.
The Snap On E series pliers offer significant features I haven't found in any other line. For instance, my E703BCG and E712BCG pliers have a set screw to eliminate handle wobble.
The 703's have a pin installed in the jaw to hold them in alignment for strength.
Combined with spring loading, they are simply excellent. All of the E series have very nice paddled handles that are comfortable to use.
I don't of any other manufacturer that offers these features in a small pliers like these. I could not be more satisfied with the ones I own and highly recommend them for anyone having this application in mind.
nanofrog
NF, are the Snap-on E series pliers the ones made by Lindstrom?
No.
The E Series are still their own (as in the pic posted by platform389), so I do apologize for any confusion over this (actually thought these would have been discontinued with the Lindstrom acquisition when they bought out Sandvik's hand tool group). :eek:
For a Lindstrom rebrand, COO would be the most definitive way to ID them IMHO. Lindstrom units are physically unmarked with COO (stated as ESP for Spain on Snap-On's website). They were made in Sweden originally (these are incredible, and what built their reputation), but that changed under Sandvik prior to SNA's acquisition.
I'm trying to find what I remember seeing, which was a Lindstrom Supreme or 80 Series in red plastic grips, and labeled as Snap-On. I'm not having any luck finding it thus far though. :headscrat
But I did locate an example of a Lindstrom in red pajama's :p :
Snap-On EPC160 = Lindstrom P6160
Some Lindstrom differences/details that might be useful (online catalog):
Ergo/Rx series (blue grip; larger images if you click higher resolutions)
Series 80 (yellow grip)
Supreme (white grip)
All joints are screw + rivet nut based lap joint now. No box joints produced any longer. Rather common approach by other manufacturers as well (Swanstrom, Erem, and Tronex for example).
Side note with Lindstrom vendors, I still see the old stock photos that still have the "Sweden" marking on the inside of one of the grips rather often (i.e. Amazon). Some are so old in fact, they still show box joints.
If you ever come across a Swedish pair in good shape, do yourself a favor and grab them. They're really that good (seen pairs more than 30yrs old that still cut like new). Hard to find good used ones though (owners rarely let go of good ones).
FMC1959
Montreal, Canada / Upstate NY
I have been looking around for mini pliers & cutters, came across this website. Anyone here familiar or heard of this place
http://www.augohr.de/marine1.php?id...ated-jaws-with-ergonomic-handles-p-13355.html
They have crazy good prices, put a brand name in the search, like Erem, Swanstrom, Hakko and other brands, the prices are crazy. Maybe a scam, but maybe someone has used them and they actually deliver the goods?
nanofrog
Looks too good to be true.
But you can be the guinea pig, and let us know. :evil:
928'er
Wine Country, CA
I don't think anyone has mentioned them (probably for a very good reason), but the Lowes Kobalt line of mini pliers are absolute ****.
game
Here's the current crop of precision pliers.
These let me do my work but there are still a few things out there I'd love to get.
game
How is that Knipex wire stripper?
They are really good! I bought it based on the reccomendation from my buddy. Ive tried quite a bit of wire strippers over the years and im sticking with this one. Would be really pissed if I lose it or break it.
Its light and easy to manouver and fits my hands real well and the action is reall smooth. I did a marathon session with 24ga stranded wire (around 250 connections.) the only snag i encountered is sometimes the insulation I stripped off gets stuck in the sliding part o the lower jaw. No big deal. Just give the lever a squeeze to eject the stuck insulation. Would definitely reccomend getting one.
RedRabbit
SoCal
Stay away from modeling flush cutters, they cut close but the blades will be ruined by the wire,
Mohawk Dave
SoCal
I have a bunch of Lindstrom Rx 8140 cutters now. It's hard to believe how big and heavy the old side cutters are that I always used when that was total overkill....but $50+ cutters were unheard of before I got on GJ. They really are that nice.
I have a small surplus of these, and they are listed in the classifieds in my for sale thread. <---(shameless plug)
nanofrog
Not much there, but it's a decent discount (regular cutters & tweezers). Tungsten carbide cutters are a steal (2495T go for ~$150 at All-Spec).
Haven't had my hands on them, but at that price, it's worth the gamble IMHO. :bounce:
They look like better grips on Xcelite green handled cutters & pliers in fact, with a change in the spring as well (swapped out the coil spring for leaf springs). The Xcelites are decent BTW, but not top notch (intermediate quality, but they're a huge step up from most Asian imports). Xcelites run a bit small, but work for their intended use (I started with a set of these when they were still made under the Diamond Caulk & Horseshoe company).
Marketed at aviation maybe (thinking FOD compliance regarding the spring change)? :headscrat
jptbay
Thanks so much for your feedback.
I ordered the Armstrong pliers, the Erems are too rich for my blood.
nanofrog
Suspect you'll like them, especially if all you've ever tried is junk. ;)
Meh. They're selling for what they're really worth IMHO. :shocking: :D Current street prices are insanity (prices used to be ~$30 per for most brands, then went crazy ~2008 IIRC to what you see now).
If you're after value at this level, Schmitz is the best out there for this, and in many cases, is also better performing. Really amazing (gets rebranded a lot, such as CK Tools & NWS's ESD line w/ yellow & black grips). Review.
Perhaps this little teaser will start the drooling. :evil:
Evolution-VII
Itatiba, SP
I'm thinking about one of the following models:
Pro America 4006
Knipex 78 61 125
Hakko CHP-170
Wiha 56818
Lindstrom FK101612
I already had one Klein D275-5 and it doesn't last long. I'm looking for something of better quality. Which brand should I choose?
nanofrog
Pro America 4006
Knipex 78 61 125
Hakko CHP-170
Wiha 56818
Lindstrom FK101612
I'm not a fan of the stamped steel models (don't last as long, more corners cut, such as jaws not lining up, and not hardened as high as claimed). Of that group however, I'd opt for the Wiha if I had no other choice (rebranded Piergiacomi).
No experience with the Pro America, but at least it's forged instead of stamped sheet steel.
Can't pull anything up on the P/N you provided for the Lindstrom. But anything forged or CNC machined will generally speaking be a considerable improvement over a stamped product.
Best advice on a budget but still after quality, check out Schmitz for precision pliers and cutters. Seriously, they're quite similar in cost, but difference in quality and durability has to be experienced.
Others to look for, would be Tronex (or rebranded as Excelta), Swanstrom, or Erem (any of these will likely be more expensive than the Schmitz though).
Of any of the one's I've recommended ^, you'll get years of service out of them so long as you don't abuse them (no cutting steel if it's not made for that, and don't exceed the wire capacity rating of the tool). Don't drop them on the tips either (jaws have been known to snap off this way).
blarf
I hate to revive an old thread, but what about for removing terminals from a reel?
nanofrog
Are you asking which cutter to remove terminals? :dunno:
If the spike doesn't matter, just use a standard 6" set of diagonal cutters (they should be capable of removing most anything that comes on a reel).
Now if you have specific/special requirements that ^ wouldn't work for, more information would be needed.
Kinda glad you did.......
Anyone know a US Schmitz source?
Schmitz do NOT have any distributors of their own, so it's buy directly for their label (see links above, including directly via Amazon.de).
Your only other alternative would be rebranded (C.K. Tools or Belzer would be the most extensive). Both are also quite a bit more expensive. Other big names rebrand as well, such as NWS, but the selection is very small.
As per buying directly, it's NOT a hassle at all, nor is it slow to arrive to your door (sent via air mail). No need to be concerned. :thumbup:
