which t8 fixtures?
Ger12
Palatine, Illinois
Re: Menards 4 lamp T8-Anyone use??
Did you try your radio?? Do you have FM radio static??
FM reception is ok. Didn't notice any static. AM is a different story. I can only get WGN which is a 50,000 watt station just 25 miles away
frijolee
Big Island, HI
Bumping an older thread as I'm now going cross-eyed from all the reading and yet still have questions.
FYI: for as often as it's stated "we've discussed this a million times" (the more helpful folks typically reference yet another link with an obscure title I never would have found otherwise), the fact that the lighting section as a whole doesn't have a single sticky isn't that helpful.
I'm bumping one of the more read t8 fixture threads since (you guessed it) I need to pick t8 fixtures.
My Info, because you always have to post your info:
-20 x 21 foot two car garage with a 14’ door.
-Garage parks one go fast car that sees lots of project work. The other side is as a work shop (4x8 welding table, big tool boxes, saws, presses, open shelves, etc. It's my own version of the 12 Gauge Garage before I’d ever heard of Jack.
-I have an acid stained floor in deep browns and blues (already done, I like it a lot, it's darkish, but will hide blemishes well).
-Exposed 2x10 joist ceiling (clear coated natural wood cause I like the look), ~9 feet high
-Plywood on top of the joists (it's a storage area above) made from the nice cabinet stuff, painted white.
-Walls are (or will be) a combination of drywall, gear, and pictures.
What I've Learned:
Bulb Family:
-Fluorescent's seem to be the best bang for the buck going in terms of life cycle costs
-T12's are phasing out, if you're starting from scratch don't go there.
-T8's are a good choice for most folks
-T5's particular T5H0 are very intense (IE you won't be happy looking at them) and better served for high ceilings which I don't have.
-Given the above, I'm looking at T8 fixtures. Hence I'm posting in this thread for clarifications.
Fixture Details:
-8 footers and 4+ bulb fixtures can save some money but come with a compromise of more localized light and you can end up spotty, especially when dealing with lots of gear and low ceilings.
-One rule of thumb just about everyone agrees on (amazing!) is to target 100 lumens per square foot. You can use online calculators and examine ceiling heights and reflector knock down factors, but at the end of the day. 2800 lumens per 32W T8 bulb divided by square footage is going to give me very decent light.
-I like the idea of common bulbs everywhere as possible so I'm sticking with 4 foot 2 bulb fixtures and will scatter them as best I can. I'm sticking one on either side of the big door and two firing through the doors details windows.
-My math says 15 four foot tubes but I’ve also seen the math at 2500 lumens which implies 17 tubes. I’m planning running 20 (10 fixtures) since it lays out well, 2 fixtures will be firing through the window as mentioned (inefficient use of light), and I do have a darkish floor. That gets me laterals and longitudinal with a bonus fixture directly over my variant of the STEEVE-O bench.
Other setup Info:
-I'm hard wiring my stuff because GFI is a mess otherwise and really it’s meant to be that way. Have several electrician friends so details of junction boxes etc is beyond the scope of this thread.
-I’m planning on three stage actuation, hallway CFLs plus workbench fixture for taking out trash is stage 1 (aka the piss poor lighting I have now). The main 9 fixtures are the two additional stages depending on what I’m doing.
-Whether you pick a fixture with a diffuser (aka lens) is largely a matter of preference. They spread light a bit more, but are in the way when changing bulbs and are easy to break.
Picking Bulbs:
-There's plenty of reading on color temperature and CFI values. Color is mostly user preference. Some folks like the 6500 k "daylight version". For the amateur the only viable approach to picking a color is seeing for yourself. I'm going 4100k as I like the light and bulbs are easy to find.
-Bulbs are cheapest when bought in bulk from www.1000bulbs.com.
-If accurate rendering of light matters pay attention to CFI when buying.
Things I don’t know:
-Does commercial vs. residential mean anything (seems to the only info the big boxes tell me).
-How do you evaluate ballast specs on something you've never seen before.
-How critical is the reflector? With a generally white ceiling I'm tempted to go without.
Recommend me a Fixture
-Four Foot, 2 Bulb, T8 fixtures.
-Cost effective. Not going dirt cheap but $20 - $40 is fine. Prefer logic and justification if I’m straying toward the upper end of that.
-Needs to be able to mount to exposed joists (some lateral, some longitudinal), bonus if I can both surface mount and suspend since that keeps it tighter to any joist I run along. No big deal if I install some angle to the sides of joists and suspend from that.
-Planning no diffuser.
-I don't care about FM reception (sound comes in via WiFi) but I don't want them to hum either.
-Would really like to do a bare fixture with no reflector either. I think I’m a little high on fixture count, but I also have relatively dark floors and a lot of gear. Partly I think reflectors look terrible, are hard to match if the chosen fixture ever goes out of vogue and I don’t mind lighting up the ceiling a bit.
-Have both Home Depot and Lowes local to me.
2ManyProject did the best job at providing links earlier but half of them are broken (all the lowes things) and his first choice someone else criticized greatly.
Thanks in advance,
Joel
Charles (in GA)
50 mi south of Atlanta
This is a non issue with electronic ballasts. Older magnetic ballast (those super heavy, wound wire transformer types) are the ones that do all the humming. If you are buying new, you will be getting electronic ballast.
Residential ballasts are the least likely to cause radio interference. Commercial ballasts are probably heavier duty and more reliable, but will cause interference.
Charles
frijolee
Big Island, HI
Charles, Thank you. One good piece of news and one less topic to think about.
A practical example might be in order.
How would one evaluate the comparison between these two fixtures?
Lithonia Model # MNS8 2 32 120 RE M6
(Home Depot SKU # 492819)
http://www.homedepot.com/p/Lithonia...ip-MNS8-2-32-120-RE-M6/202563409?N=5yc1vZc9h7
Lithonia Model # C 2 32 120 GESB
(Home Depot SKU # 453825)
http://www.homedepot.com/p/Lithonia...-Light-C-2-32-120-GESB/100543144?N=5yc1vZc9h7
Is there a difference between an "instant start" electronic ballast and a regular electronic ballast? That, plus a subtle change in form factor is about all I see.
cybrdyke
USA
One is a "mini strip", the other is a standard strip. The Mini has the lamps much closer together and the body of the fixture is thinner. If you are ham fisted and work with alot of these, the mini's are a pain. But if it's your garage and space is tight, the mini's are fine.
Both have an electronic "instant start" ballast. None of these fixtures come with a "residential" ballast. That doesn't seem to worry you anyway....I like your response to this issue, using Wifi.
Understand that when doing your calculations, you do NOT get 2800 lumens from the T8 lamps. You only get 88% of that. But 100 lumens per square foot is a just a target...and a fairly high one. If you fall short you'll prolly still be happy.
As for the reflectors, it doesn't sound like you need them. They are mostly for fixtures that hang from very high ceilings.
Good luck!
CD
squarles67
Orange, Texas
I just put 15 of these from Lowes in a 30 x 50 and I'm very pleased with them. With 6500K bulbs it lights up quite nice and they're $39.97 each
http://www.lowes.com/pd_163723-337-8TSNF-232-UNV-EB81-U_1z11owh+1z140i7__?productId=3181905&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1%26page%3D1&facetInfo=Metalux
For whatever reason they only come with 4 screws to assemble them with so I bought some #8 x 3/8 sheet metal screws to fill all the holes. To be honest they probably would have been fine with just the four but screws are cheap.
frijolee
Big Island, HI
Something about the Lowes links doesn't seem to work correctly. I get a general Lowes Page not specific product info (same issue with 2ManyProjects' links earlier). Got a part number?
Based on cybrdyke's response I'm leaning towards the mini fixture I linked above
squarles67
Orange, Texas
Item #: 163723 | Model #: 8TSNF-232-UNV-EB81-U
frijolee
Big Island, HI
Squarles, thanks. If you're going for 8' length with 4' bulbs that looks like a great choice.
Since I'm going to scatter mine around I bit I think I'll stick with the 4' fixtures. The mini fixture above is still trending as my top choice. A few folks claim the knock outs are hard to get out, but otherwise feedback looks good.
Lithonia's number is "MNS8 2 32 LP" http://www.lithonia.com/commercial/t8+mini+strip+-+2+lamp.html#.VDL4A_ldXw-
Cut sheet is here: http://www.acuitybrandslighting.com/library/ll/documents/specsheets/sl8u.pdf
I'm assuming since there's no mention of mounting or chains that I can directly bolt these to the exposed joists, correct?
Possibly last question before placing the order. Anyone ever feel like an idiot for clanging a ladder into bare bulbs and taking a glass shower? Wondering if I'm setting myself up for that eventuality...
ripperd
Twin Cities, MN
I whacked the bulbs above my workbench with a piece of wood one day. Rather amazed one didn't break. They are about 4' above the bench on the bottom of a shelf. After that I put a little protection for the one over the workbench. But the rest of the garage they are just bare and I haven't had any issues.
mwilson6192
What I've Learned:
Bulb Family:
Fixture Details:
I appreciated this post because it summarizes my understanding as well.
I have a new garage that measures 22-feet by 24-feet with a scissor-trussed ceiling that at the lowest point is 10-feet tall rising to peak at 15-feet tall at the center of the garage. I also have a 9-foot by 12-foot by 22-foot triangle that opens to one side of the 22-foot side wall.
I have a 20-AMP dedicated lighting circuit protected by a GFCI breaker at the electrical panel. Currently there are seven (7) incandescent light sockets in the following configuration:
- 1 light socket in the flat ceiling of the "triangle" section of the garage (this is serving as the "shed" area so the lawn mower, bicycles, garden tools, etc. reside here). The floor to ceiling height will be 9-feet.
- 3 light sockets spaced "evenly" across the 24-foot ceiling, which are mounted directed to the scissor-trussed ceiling which is at about a 30-degree angle. The floor to ceiling height is approximately 12-13 feet.
- 3 lights sockets spaced "evenly" directly on the opposite side of the 24-foot ceiling. The floor to ceiling height is approximately 12-13 feet.
Question: Bright lighting is of prime importance, so the T5HO is attractive to me. I am willing to accept the additional cost of T5 lighting. Can I mount these lights (hardwired) directly to the ceiling at the angle of the ceiling? Or should I hang the lights such that the lights point parallel to the garage floor? What about the need for a reflector at the height that I identified (e.g. 12-13 feet about the floor)?
Question: I am not at all concerned about radio interference, so what brand should I consider that will last with commercial duty ballast? Where do you suggest I buy them at? Any link to a suggested supplier?
Question: I like the idea of 4-foot lamps with 4-bulbs in them versus 2 bulb models? Good idea or bad idea?
Any other sage advice?
Thank you in advance for your help.
