Small Jack Stands
redmed
With smaller compact cars my jack stands are many times too tall to fit. Does anyone know of compact jack stands?
mrvm
PA
Check out the jack stands sold at HF. They got some that may be compact enough for you.
Need more space
When it comes to these cheap ones look at them good before using, I had a set of the harbor freight orange and white ones and they treated me well, So well I bought a second set for at home. The very first time I used them the lever that locks the height position folded completely down, since the lever is the only thing that holds the weight the car slammed down to its lowest position.
LB-1911
Northwestern Il.
R
redmed
454cid
West Michigan
Yeah this sounds like an odd problem to me. Usually when I see jackstands, I'm amazed at how short they are. I drive a 1-ton truck, However.
Joe B.
My current stands go down to 10 inches. When I looked a few years ago these where the shortest I could find.
I did a very complete review of jack stands a few years ago. I don't remember any going lower than that.
LB-1911
Northwestern Il.
You may want to consider using low profile ramps* in conjunction with your floor jack and current stands, you could use 2 x 10's & 2 x 12's if your cautious.
* Race Ramps
http://www.raceramps.com/jack-assist-ramps.aspx
zkling
What you probably need is a jack with taller lift capacity or change your jacking points.
R
redmed
I have been using a bottle jack as a jackstand and a couple 4x4's & a 2x4 when I work on my car with low clearance. Just thought someone made mini jack stands.
PBCampbell
WV
:headscrat
Have you tried jacking the car up before putting the Jack Stands under?
