23 CHIEF
It's laminate floor on the top got the idea from another member here, it holds up surprisingly well.I like the top, I am trying to make a hardwood top for my boxes. Hate small towns and lack of materials. Did you make it?
My wood top is 2 X 6 then the laminate flooring and yes it just rest on top I did put a piece of 3/4 on top of the HF boxes so it would not just be sitting on the edges I have not had any problems with moving at all23 chief Does that top just rest on the two box or do you have it secured? Thanks
Here is mine.
That's pretty sharp looking. What wood did u use for the side cabinets?
Thanks. The wood is a hardwood tool cabinet top made by husky that I cut down.
http://m.homedepot.com/p/Husky-27-i...Top-for-Rolling-Cabinet-HOCN260001/203949843/
Now I need more boxes dam youI'm In!
I'm In!
I guess just call me the thread killer?
Nice setupI don't want to see you banned as the thread killer so here is a little different take on organization with a HF chest....
Nice setup
So how the heck do you work in that garage? Looks full.
I saw you post Duker and thought this will be good.I don't want to see you banned as the thread killer so here is a little different take on organization with a HF chest....
On The HF can you close a drawer into the lock position after it has already been locked and a drawer is not closed?
No
I thought you could. I'll have to check again tonight. I very rarely lock mine up.
My box, cart and main three drawers. The socket and wrench drawers aren't real impressive, it's just for home stuff. Everything I do professionally is electrical and mostly within the passenger cabin.
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
http://m.harborfreight.com/t-bar-with-3-8-eighth-inch-flexible-ratchet-98484.htmlWhat is that 2nd from the bottom LHS, ratchet? Long, flex, roto? Custom job?
Druder - Did you paint the trim or just remove it? I’m on my iPhone and it’s hard to tell.
edit: I can see it’s removed. Was it destroyed in the process because that would answer some questions about repainting mine.
