I would have bought a few of them at that price lolGot it, thanks. (Cordless saw). I was about to run out to my local HD if the saw was $99.
I like my cordless circ saws, but they arent Milwaukee nor are they full size (6" blade). I really only use them when I have small lightweight jobs to do (cutting 3/4 ply, a few 2x4s, etc), otherwise Id use a corded anyway.
While it would be really nice to have a cordless saw with corded power, I use it so infrequently Im not sure Id pay for it. Now if HD had a bundle that included it for free (which they do), well then maybe![]()
Question about the Fuel impact drivers:
I have a Mercedes Sprinter that when I put the Steel wheels on the torque spec is 240n.m (177ft lbs).
For an impact I'm a fan of brushless technology.
It looks like the fuel options are:
M12: 2452: 1/4"
M12: 2454: 3/8"
M18: 2653: 1/4"
M18: 2764: 3/8"
M 18: 2763: 1/2"
Would any of the M12s be capable of handling these lug bolts reliably (all of my current stuff is M12).
If not.. what level of M18 do I need to go up to?
Are any of these still made in the USA?
it's worth going into the store.
yesterday when i checked, one store had it listed at 129.99 and phone was 99. it rang up at 99 anyway.
and today when i purchased, website was back to normal at 169.99, the shelves in the store were still at 129.99 . and it still rang for 99...
best to go and have someone price check it.
Ouch. Yea if you catch something it will easily turn a big man around...I got neck-chopped by the handle of one of those many years ago. I learned really quick how to hold that thing correctly. ;-)
the m18 3/8ths is probably the one for running the lag bolts into rail way ties.... idk i don't do alot of that style work but i feel like anything like the 1/4 hex even m18 probably couldn't handle that task for very longWhat's the good "middle ground" impact? Something that'll run lag bots into railway ties but still use able enough to run 3" screws into 2x4's without snapping the heads off?
For the guys that bought the M12 combo kit for $99, i found the 2 speed screwdriver on eBay tool only for ~$35 bucks. Good addition to the combo for light duty tasks.
http://www.ebay.com/itm/330828630188
No way pal that would be a task that the 1/2" may not even be able to handle...geek... Depending on how big your lags are, and how long. I'd say a 3/8x 3" lag is max, and your runtime will be much shorter. This would more than likely need to be done in low.speed high torque...why would you be putting lags into railway ties? I wonder how well that zinc would do in a railway tie....the m18 3/8ths is probably the one for running the lag bolts into rail way ties.... idk i don't do alot of that style work but i feel like anything like the 1/4 hex even m18 probably couldn't handle that task for very long
After yesterday's input I'm needing a bit more from those who have:
I have an older milwaukee subcompact driver (non "impact") and I'm going to pick up the big 1/2" M18 fuel driver to do the lugnuts on my Sprinter (180 ft lb).
I'm also looking for a good all around "wood working" impact.
My M12 one doesn't have quite enough power (there are times it runs out of oomph) and the big 1/2" is going to be way over kill..
The 1/4" drive M18?
The 3/8" M12 or M18?
I'm trying to figure out which would be best for the gap in my usage and I am a fan of brushless technology.
Thanks in advance.
p.s. I ordered his and hers heated jackets today. Can't wait for them to arrive!
I live literally on the side of a mountain @ 8000ft. Parts of my property are 60+ degree slope. I am going be updating a bunch of retaining walls, sections of which are railway ties.
Cheers,
Ed.
.mobile
Thanks for the input!
I'm definitely picking up the 1/2" impact for doing my Sprinter's wheels (180lb/ft) as well.
My original question (post 783) was actually should I get a 1/4" or 3/8" to fill the hole in my lineup with *having* the 1/2" fuel and my M12 non-impact driver.
Mainly for woodworking I find that my M12 (non-impact) doesn't have quite enough oomph when driving long fasteners into wood and I fear the 1/2" is way too much and will rip the heads off of small stuff
cheers!
But I'll also tell what I know from personal experience: despite the marketing claims, the BRUSHED 2650 M18 is noticeably more powerful than the Fuel (brushless) 2453 M12.
What battery pack were you running the M12 with?
Its been mentioned that a higher Ah battery pack might give the tool more power. I assume the M18 pack was bigger than the M12 pack, it would be interesting to see if running both tools run with the same Ah makes the M12 closer to (or better than) the M18
Absolutely not saying it is, Ive just never seen it done so Im curious.
Need to grab that 6.25 circular saw... everyone have good experiences? If so, what type of duty does it serve for you? Run times, etc.?
The M12 was on a fully charged 3.0 XC and the M18 was 4.0
XC
I am one who believes (knows, for me) that the XC packs give the tools more power, but a turbo V6 still ain't a V8.
Cheers,
Ed.
.mobile
The 1/4" drive M18?
Thanks in advance.
Ed:
I have both the 3/8" and 1/2" Fuel impacts. Even thought it's more money, I would have to agree that you want the 1/2" impact. I would think the 3/8" could handle it, but it would be working at max capacity if you are using decent-sized lugs and would really reduce your run time. Meaning, tool is working harder, battery is draining faster, more battery swaps, and then down time while working.
Ed:
I have very good luck with mine. I built a garage for my neighbor this summer and never once had to break out my corded saw. I was very impressed with it.
Banjorear,
Did you mean to say "decent-sized LUGS"? If so then yes I agree the 3/8 IMPACT WRENCH would probably be working too hard. Now if you meant to say "decent-sized LAGS" I disagree and think a 3/8 IMPACT WRENCH would more than suffice for driving LAGS into railroad ties.
