those were the wrong impcts to buy.....crv. the other ones are moly. Whaats the issue with the gun, its one of their better products
I think what we was saying is that he gives them a Pass, as in he has been pleased with them and their performance.
AFAIK, they don't have the crmo in 3/8 drive.
Geez, pretty good deal. Were they full polished?
What size's?
Do they skip any?
Yup. Only CR-MO in 1/2 drive.
Why the non-moly is the wrong one to buy? Not as strong?
Thanks.
does it say on the package which are which? other then that how does one know the diff in case it doesnt say?
Thanks.
It's not really an issue of strength. Cr-V is harder, more wear resistant, and excellent for hand tools. It is also brittle and doesn't handle the shock of an impact wrench as well as Cr-Mo. Cr-V can break in half when used with an impact tool and send chunks of metal flying at speeds high speeds. I've seen guys go to the hospital to get pieces of metal removed from their flesh. Cr-V is still used for impact sockets but in order to meet safety standards they will be made thicker than Cr-Mo sockets which is typically not a desirable trait. That's not to say that all Cr-V impact sockets are made to meet this standard, some are not! Name brand impact sockets are pretty much unanimously Cr-Mo.
I should've taken pictures. The harbor freight air blow gun is a MASSIVE FAIL. Hooked it up to shop air and used it for about 5 seconds, set it down and it exploded. The end where the air line attaches came out of the plastic and this air line started shooting shop air pressure out of the air fitting that was still attached to the air line. Hose flying around like crazy. Another mechanic walked up to me from across the shop and handed me my blow gun.
It could be ****** construction or design. It could be our shop's air pressure is probably much higher than reccommended. Whatever it is, I ain't buying another one from harbor freight.
this is the blow gun that fails. im lucky my air hose didn't fly into a car when it was wiping around and put a dent in it .
http://www.harborfreight.com/pistol-grip-blow-gun-68259.html
Yeah, I also feel you should be able to use it at whatever pressure you want.And what was the maximum pressure on that blow gun? You can't fail something if you used it way beyond it's specifications. Hell, without a part number or something, we don't even know what to avoid!
How do you try out an auto darkening helmet? I have one I don't know is good or bad and I have been trying to flash myself with things that won't blind me to test it but I don't know if I'm not using things bright enough or of they're all telling me it's bad.If you're going to be doing Tig, get an expensive one and try it first before buying it.
Thats a well known fail and only has a 2 star rating anyway. /\ It even looks like a cheap piece of plastic, I wouldnt have bought a air gun that looked like that from a name brand store.
I'm going to try that thanks. I wasn't sure how bright it needed to be but my guess is this one is broken.My Miller has a reset button that wakes it up if I haven't used it in days/weeks, causing the lens to cycle. Also, pointing it directly at the sun will cause it to darken.
thats all l have is a MIG and stick.Thank you so much JimDon, I only do MIG welding (and some oxy/propane) at home once in a while. My current helmet is fixed shade. I saw HB has a auto-dim helmet for $44.99:
http://www.harborfreight.com/blue-f...zIjoiNDQuOTkiLCJwcm9kdWN0X2lk IjoiMjI5NiJ9
Since I have never used auto-dim so I'm a little paranoid that it may not dim when the arc strikes then it'll be too late?
Did it ever fail to dim for you?
Thanks again!
mike-
