Lets see your workbench
Gojeremy
My bigger workbench now has a bottom shelf and my smaller workbench is on casters, and I just bought some wood to install a lower shelf.
mmouse
Bowling alley bench.
It's well beat and has some character. Flooded with 2 coats of spar eurethane. Front edge is 2x angle for a crisp edge to bend sheet metal. Base is 2x2 .120" wall, blackened, oiled, and waxed. Next project is to build rolling cabinets to nest underneath.
dittle fart around
Vancouver, Washington, USA
Nothing better than bowling alley. Plus you don't have to worry about spilling beer on the top, good chance that's happened already.
:beer::beer::beer:
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I don't know if I posted pics of this bench or not. I had a wood bench that was deeper that I gave away to a so called buddy of mine and built this one. It's only 2' deep ad uses a standard box store counter top, but it does hold a lot of weight. It's 2' deep and 23' long and has (5) support legs under it. Once I get the small addition built onto the side of the garage, the bench and overheads will go over there to make some more room for my machines. I actually miss the other bench more as it was 32" deep. And that few inches makes a hell of a difference when working on the bench.
jgorm
San Diego
I build this at my last house. 2x6 glued and screwed. Then I moved:(
jgorm
San Diego
thanks guys. It was a ton of work (2 days) with the belt sander and the electric planer to level out the boards. I might do something similar, but with less wood and a plywood top. Probably something with 2x6s 4" oc with double 3/4' 5 ply on the top. I'll probably do another support leg with solid 2x6s because it was nice to be able to pound the hell out of things on the work bench with a hand sledge.
jnich1977
Just run the edge of the board through a table say to give it a square edge, sooo much easier than sanding.
jgorm
San Diego
I didn't have a table saw back then:sad: I beat the **** out of that bench, but you really can't damage it too much. It was covered with grease, oil, tons of pound marks and drill holes. It looked more like this before I moved.
jrod60
Katy TX
My new one. Folds down from the wall, which is super handy with a dead car in the way most of the time. It's 41" high and 32"W x 60"L, which is a bit too deep. I can't reach the wall behind it at that depth. It's plenty sturdy for me to jump on.
I put a piece of steel strapping on each side spaced out a bit so my drill hook can hang on there. That's been pretty handy so far.
The tie bar between the legs lets me just kick it in the middle to make sure they're both seated against the wall.
CharlieHo
WV
Picked this table/bench up last month. Storing it in the hay shed until I get around to building a new garage.
4'x10', 3/8" top, 2x6 structure, I think 1/8" bottom.
I won't say how much I paid for it, wouldn't want anyone to cry.
rartuin270
Fort Wayne, IN, USA
I like the drill idea.
F-117HWK
Virginia
I...want...that...table...
Rogue Status
Almost finished with my new workbench. Old work surface was 2 2'x8' 2x4 tables with a lower shelf I made on the cheap. They worked great but collected far too much clutter and the plywood top was not ideal for welding, grinding, or other metal work.
New bench measures 2'x10' and has a 12ga top over 1.5" solid core doors. The frame is all 1.5" 1/8" wall square tube and 1.5" angle. The receiver will accept a vice, bench grinder, and whatever else I can come up with. Should have some completed pics this weekend, 2nd box is on the hoist sans casters and ready to go to it's new home.
https://scontent-a-mia.**.fbcdn.net/hphotos-xfp1/v/t1.0-9/10414600_10153103311309880_5697344913423669326_n.jpg?oh=b1d6082b859265cbd01f0db4ff715fcf&oe=55263700
https://scontent-a-mia.**.fbcdn.net/hphotos-xpa1/v/l/t1.0-9/1484558_10153103311514880_9178826603376740816_n.jpg?oh=ff853f619c714466591bb885ff5dfb4a&oe=55669531
https://scontent-b-mia.**.fbcdn.net/hphotos-xpa1/v/t1.0-9/10355886_10153103311764880_4825423347736343209_n.jpg?oh=12be68dc5cc111b0c2e4bd08f91dc959&oe=5525F18C
bri_man57
Windsor Colorado
Built this guy to replace the haggard one that the previous renters had. Build it on top of the washer and dryer to utilize previously wasted space. It does sit slightly taller than most benches but is a great height for standing next to and fits my needs exactly. The dryer controls are slightly more difficult to get to, but sometimes in life you have to get your priorities straight. :)
banditbigdog
Southeast
Took awhile to complete
No metal fasteners, wood glue and a couple hundred dowels.
Was going to add another sheet on top so I used the "bad" side of the
boards on top.
Thinking now I will just leave it as is.
banditbigdog
Southeast
Pretty Heavy
250-300 lbs guessing.
Currently has 2 coats of pure tung oil.
That is a Lista in the background
Still organizing it currently.
13 Drawer and its very heavy.
Drawers slide very smoothly.
Stripped off several layers of paint and repainted.
Will post some photos of when its complete.
BearsFan315
Portsmouth, VA
boards on top.
My big guy liked helping along the way.
Man that looks awesome, and BUILT like a TANK !! could put my VAN on that with out any concerns !!
Elginz
Oconto, WI
I don't know if you can find my work bench under there. Most of the work gets done on a 3 x 6 sheet of plywood on some saw horses that I use as a table/work bench.:willy_nil
hoffman912
Columbus, Ohio
mine came with the garage. its probably about 100 years old (my house was build in 1895 and the garage in the early 1900s)
btw, this is what i found under the bench behind a pile of **** when i moved in
:lol_hitti :wtf: :scared: :eek: :yikes:
mypov
That is the sickest work bench ever! Love that thing, would almost kill to have something like that/
hoffman912
Columbus, Ohio
its cool, but a few things bother me
-location. i wish it was on the other side but its too damn heavy for me to move
-space underneath. I wish i could roll stuff under it (like a cart, stool, floor jack etc) or have space under it for larger items. i can fit my jack stands under there though, so i have that going for me, which is nice.
-drawers. i havent quiet figured out what i want to put in there. some of the drawers are harder to get out that others. i mean.. yeah i can put stuff there no problem. just not how i would have had it from scratch. I think if i was starting a new, i think i would just want a top with 4 legs. im picky as hell.
but what i love
-it is freaking solid. i can beat on this thing, and it doesnt bother it. I can put anything on it, and it can take the weight.
-character, patina, and it goes with the car and the garage quite well
zkling
Pretty Heavy
Great bench and :drool: on the lista. What are the dimensions of the lista cabinet?
banditbigdog
Southeast
Lista Cabinet Dimensions:
13 Drawers Total
Outside Dimensions: 56.50"Wide x 52.50"Height x 28.00"Deep
8 Drawers 52.00" x 24.00" x 2.875" Deep
4 Drawers 52.00" x 24.00" x 3.875" Deep
1 Drawer 52.00" x 24.00" x 7.875 Deep
Added 2 each 3/8" thick steel plates on bottom then attached 4 Colson casters
rated at 1000 lbs. each. Added a foot operated floor lock and a handle on the side.
