$25 plus $30 for a seal kit and I'm in half the price of a HF jack. I guess it's worth a shot. Is an 867 any good if that's what it is? I don't do anything huge. Just the normal maintenance of my 2-3 cars.
I've been looking for a floor jack on CL and ran across this one for $25. Seller says it doesn't work and he doesn't know why, but he thinks its repairable.
I tried filling it tonight and have some questions. It was totally dry, so full of air. The plug is in the block and I filled it until it was just below where the plug would go in. I put in the plug and try to pump and get nothing, just the sound of sucking air. I pull the plug out again and the level has dropped so I add more and try again. Same thing. I read on Hyjacks.com to prime it by pulling out the rod with the release closed, then open the release. I pulled the rod out fully and it retracted by itself (with the springs) about 3/4 of the way, then I had to open the release to retract it the rest of the way. I am wondering where to go from here, is it not primed and I have to get it primed? Or are my pump seals probably shot and I need to start the teardown?
When I pulled out the rod, no pitting on it so that seems good. Also the jack mechanism worked smoothly. And when I used the release for that 1/4 of the stroke that seemed to work smoothly and controlled too.
Leather Piston Seals, Especially USED seals Generally don't carry enough cylinder wall pressure to Create the Vacuum to Pull Oil and "Prime". About the Only time I ever lift up on the Lift Arm to assist with bleeding is with Air operated Jacks to help purge the Air side of things. Im not trying to be a ****, But Generally there is a reason things sit in the Corner of shops for 15 years. MY Advice and take it as you will, Tear into the Jack and get a first hand view of what your dealing with in regards to the Seal/Surface conditions etc.. Don't Guess.
Oh.. And that style of Walker is a Bear to fill with Hydraulic Jack oil, I generally fill them before installing in the Frame after I remove the Release Valve. I do this to create a Secondary path for air to escape while filling via the fill hole and Don't want to fill it completely up.
Good Luck.
Not taken as a **** at all. I'm trying to learn what I can as I go, the only jack I've ever had was a Autozone trolley jack and none of the info on the web I've dug up has said anything about how to fill through the block so I wanted to make sure I wasn't just missing something. The only reason I was even going to try to fill it was that I thought on the 1 in 1,000,000 chance the jack just slow leaked in the guys garage over the years and a refill would get it to work was worth the 10 minutes it would take. Now that I know filling it isn't the problem, I will start tearing into it.
2 more questions then. If/when I would go around to filling this style, how do I know how full? I read in your sticky to just cover the main cylinder, but since I'm filling through the block I can't see that.
Secondly. How do I get at the relief and check valves? They both have what appear to be solid plugs where I though there should be screws. Do I gotta drill those plugs out?
Hiball. Do you think it will be a waste trying a bearing locknut hook spanner with a big cheater instead of cutting up an impact socket to get off the tank nut?
http://m.protoolwarehouse.com/prod-...-To-3%22.htm?gclid=CN2A6ozglMQCFVFp7AodTmMAPQ
I got the inner spanner off and pulled out the packing and ram. It came off easy with a hook spanner wrench. It looked like someone had taken it off before with a hammer and punch. I haven't gotten the tank nut off yet because I haven't had a chance to make a HF run and get a socket, but I thought I would get as far as I could.
The packing was 3 leather seals as expected looking at that cutaway, but the ram seal looks rubber or plastic and pretty shot.
How does the ram surface look? Seems s little scratched up to me, but I don't know how smooth this stuff needs to be. The inner bore looks similarly scratched.![]()
Also, is there anything to be gained by pulling off the tank at this point? It seems that I can replace all the rod seals right from the end. Is there something I should or definitlt shouldn't use to flush the cylinder out with? I've been cleaning all the parts in simple green.
So am I stuck just replacing with the same size U Cup? Or is all that's needed for using a leather seal the deal and nut? I've never seen a leather seal installed.
Anything special about the sealing washer? Do I just get something as close as I can to the ID of the leather seal lip?
What's the procedure for installing the ram with the leather seal? I assume the lip points down so the pressure would expand it against the walls.
Sorry for so many questions, I just wanna do it right.
Okay next few questions/mysteries. When I took apart the pump there was 1 neoprene seal stacked on top of 3 leather seals. Is that correct? I wouldn't have questioned it, but know they changed the ram seal, I don't know what else got messed with.
Secondly, there was both a leather seal and an o ring sealing where the release assemble goes into the block. Is this right or should it be one or the other?
Thanks for the advise on the pump. I gave a half hearted attempt at driving the pin out but it didn't move and I was afraid if I hit too hard I might damage the pump body. If it's really that much easier to install the seals, aI will give it another try maybe with a bigger mallet.
Is there anything in particular I need to do with the breather? It appears to have a rubber seal in it. Is that seal part of the normal service kit? I didn't want to damage it attempting removal if it's not in the kit.
Unless someone deliberately plugged the hole and air can't pass thru it.
