wrenchguy
Does anyone know any specifics about a ROCK ISLAND 98? Thanks.
Picked these up today. Craftsman 5198 with missing jaw support. I'm sure someone here could use it. I couldn't leave it there.
Vanderman #1 with what may be a factory table? Heavy, heavy table construction with center bolt so it can rotate.
$100 for both.
$100 for both.
Nice I saw that one. Glad you grabbed that one. Did you see this one?
Prentiss vise $80
http://boston.craigslist.org/nwb/tls/4944591318.html
~Veeps
Veeps I saw that but i have a lot like that. Fixed bases i like 5.5" and bigger. I also got this tonight, an old Reed 403 1/2. Paid 140 but I liked it alot.
Vandermans all have a slight raised collar at the base so they can be mounted on a base or truck bed. It makes them a pain to be mounted on a bench but they were many for in the girls use by pipe fitters.
That's a beast of a vise, Joe . I almost have as many of those as I do Craftsman 51xx vises and don't like moving them at all. I think I posted some pictures on here long ago of them but if I get a chance, I'll take another.
As for the Craftsman, you found the only one ever used in the world . I don't think I've ever seen one that beat\damaged and its hurts me to see it like that. Did you happen to see a date on the slide? If its a 1956, somebody is really going to want it
Is that the one you thought might have been cracked? How is it?
~Veeps
Should be a fixed base, smooth cast in jaw, possibly 8" er
I have a 94 (4.5" jaw). I know the 97 is a 6" That 98 is a big b@$tard.
Maybe someone with brochure will chime in.
Knowing jaw width & weight??? those r the big questions now!Maybe someone with brochure will chime in.
I have an old Rock Island in about the same shape you started with Steevo...what was that final finish on yours? I really like the grey.Today I re-assembled the Wilton C1 I have been cleaning up and refreshing.
The swivel nuts were beat up, and one handle was missing and the other bent and mangled (in foreground below), so I turned the nuts in the lathe to clean them up, and made new handles for them.
A curious thing, I learned while doing this. One of the swivel bolt holes is closer to the body of the vise than the other. After I made the first handle and it fit well, I made the second, and found that it hit the vise body when turning it. So, I had to re-turn the ends on both to make the heads thinner and more domed to clear when turning.
I found some nice stainless screws in stock for the screw retainer clip:
Made new pins for the rear cap retainers, and assembled the rear, along with the shined up cover:
Now I just need some new jaw inserts. I think I'll make some aluminum ones for now, then buy some of the cross-hatched hard ones.
Before:
my apologies to everyone here. The Craftsman is a 5196 NOT a 5198....sorry.
I had some time today to practice on a some hard inserts casted into this Holland 3-1/2. The jaws are smooth but were not matching very good and the edges had chips. One way is to set the vise up on a mill and using a carbide end mill you could cut the faces but that way applies more tool pressure and the cut is not as parallel as I like. Another way is to use a surface grinder and use the side of the wheels what we call side wheel grinding. This I believe is the easiest and best way to reface these jaws.
After dressing the wheel and aligning up the vise I started facing the jaws and you can see how they were not very parallel, more material came from the bottom. It took .025 to clean up the faces, and clean some chips from the top edges. The sparks look like oil hard tool steel to me, and I still would like to know how they casted those hard inserts in and they stay there with all the clamping pressure they have seen.
Found this recently on PM while searching for some Rock Island info for WG's # 98. On the thread it was stated that RI made these vise for Atlas. Just above the pictured combination vise they list some heavy chipping vises. The 8 1/2" at 345 lbs. would likely also be the Craftsman 5168.
Sold by RI, CMAN, and Atlas, there's got to be a couple hiding in somewhere big and old....like an old rail/ship yard, electrical plant or similar ?
That's a very nice viceDid you restore it?
[/QUOTE]
Does anyone have any info on this one.....does it look like its been abused? That steel plate bolted to the side of the jaw worries me. Is that a fix?
Tried google but cant find anything.
Thanks guys
In 1920:
The 98 was a 7" jaw @ 210 lbs
The 67 was the 8 incher @ 286 lbs
The rear jaw is a pivoting jaw and can be removedd. I've seen the repairs before and its usually done because the jaw is broken internally ad it will not hold under pressure. I would pass on the vise unless you are close by and can inspect it closely. It might just be the limiting pin ismissing
For a woodworking vise you should have a wooden handle. A piece of dowel is good. For the ends I turned a couple of knobs and glued them on. A wood vise does not need the strength of a steel handle.If I wanted to have a new handle made for a vice who or sheer do I go for this? I have a Columbian woodworking vice that could use a new handle
damn i was worried about that......thing is its hard to find american steel up here.....that was the first parker in about 4 months of looking.
So does it look like someone drilled into the vise to bolt that plate on or did they use existing holes??
You know before thumbing through this thread I could have gone home without this vise! Instead, picked it up, wiped it off, bolted it down to use it, just needs a little lube. Parker 433 1/2, wish it had the original swivel lock bolt and wrench, anyone got an extra?
Very nice. There is a guy on my local CL selling a #2 wrench for $45. There is also two currently on ebay. As far as the bolt goes, I need one of those too for a parker I have, once I get a wrench (#3) i'll look for a bolt or to have one made.
http://www.ebay.com/itm/Parker-Mach...685?pt=LH_DefaultDomain_0&hash=item5d56e9ed15
http://www.ebay.com/itm/VTG-CHARLES...366?pt=LH_DefaultDomain_0&hash=item4d2f9e492e
