Thank you for the info.
I am starting a file on this for machine rehab.
Did you use electrolysis for any of this?
Is the Caswels a better option than actually having something black oxided?
And what is your filling and painting process?
Bill
Yes i used Electrolysis for the table and the large coolant guard.
i bought a large green tub at fleet farm thats used for horses.
i had 6 anodes place through out.
For filler i used Rage brand light weight filler . i like it because its easy to sand with no sand paper clogging.
after stripping and degreasing i use a torch to help loosen old filer and burn old stuff off casting.
then sand with 80 grit.
wipe down with acetone .
start applying filler .
dry over night .
shape it all with 80grit
filler again in low spots.
sand with 100grit
then jump to 180 grit over whole thing
let bake in sun for couple days.
apply heavy coat of high build primer .
sand with 180
apply another heavy coat of high build primer sand with 320
let cure for day or 2
wipe down and apply light coat of sealer primer.
let dry 4hrs
apply top coat after mixing with hardener
this paint you must apply second coat within 2 to 4 hrs
apply 2nd coat .
Now take pictures and drink a monster energy drink and enjoy the shiny new looking machine
