The Unofficial Vise Parts Swap Thread.
1982fxr
Phoenix
trijeff
Northern Cali
Looking for one (1) locking pad for a Wilton Tradesman - doesn't matter this model of the vise, this part is one size fits all.
THANKS!
EDIT: No longer need, found some on eBay.
danstead
Western, Pa
Looking for a replacement Spindle Nut for a Craftsman 5195. Mine seems very worn or it's the incorrect part. see image.
Thanks in Advance!
topop101
NW Missouri
I just acquired a Prentiss 22. The dynamic jaw has been broken and brazed at the start of the slide. If any one has a 22 they are parting out I would be interested in it. Or if you need parts for a 22 everything on this one is restorable . It's missing the pin
autopts
fellas, this is a great opportunity to make your Columbian or unbranded Columbian, (Ridgid, Armstrong etc) a dual lock down. Any bigger Columbian with the empty covered hole on the opposite site would be a excellent candidate for a additional lock down. With 2, your vise will be twice as stable. Oh, and they are priced right.
http://www.ebay.com/itm/Wilton-Vise...a3aac2e&pid=100033&rk=1&rkt=4&sd=381245158052
trijeff
Northern Cali
Thanks, autopts! I don't need this item for any reason, but I did see some lock pads by themselves (for Tradesmans) from the same seller that I did need and that I haven't been able to find anywhere else without CRAZY minimum orders or excessive handling/shipping charges ... this helped out a TON!!! Ironically, I was just PM'ing with Balane about this earlier today and then WHAMO, your post :thumbup: Thanks again for the heads up, much appreciated :D
scooternut
Pittsburgh, PA
Littlestown 112 here all busted up. Broken main screw and bent dynamic slide which I assume could be straightened in a press. I promise I did not do this, I simply rescued it from the scrap pile. I'm good either way, fix yours or fix mine, let's just rescue one of them. Let me know what you have or what you need.
View media item 51481
drivesitfar
Jake: good call. Mark from Indiana one of our members made both of these vise bookends and i think he mention cutting the main screw in half was the hardest part of the job. looks like you got that part done.
if you don't work out a swap with another member here's a couple pictures of Mark's bookends.
good luck
bagged89s10
CT
Hey my dad has a Craftsman 5243 vise and it has a cracked swivel base. It's operational but I would like to find a replacement for him.
part number 3V5510
seasnarf
I have a dynamic jaw, screw and nut from a 4" early Parker combination vise ( thanks to B100 for the ID ) The screw is 14 1/2" long 7/8" dia. and slightly under 4 tpi. I also have a smaller vise screw that is 11 3/4" long 3/4" dia. and 5 tpi. I am looking for a screw to fit a Reed 104 or 204.
bagged89s10
CT
What are the dimensions of that ring with set screw? I might be interested in buying it.
thehorse13
Jefferson County, WV
Hello fellas.
WANTED:
Rock Island 574 main screw nut
HAVE FOR TRADE:
Prentiss model 19 main screw
Prentiss model 19 three mount swivel base
Prentiss model 19 swivel base pin with spring and handle
Prentiss model 19 collar and set screw
Please send me a private message if you have a Rock Island 574 main screw nut. Thank you.
2oolhound
BC Canada
Hi, I cruised through the 15 pages here and didn't see what I needed so I'm looking for the lock down bolts and threaded slugs like you see in my 1st photo for a Record #4. The photos are from my #6 which are too big. They should look similar but be a little smaller. Any suggestions or ideas?
https://www.garagejournal.com/forum/attachment.php?attachmentid=687045&stc=1&d=1506893042
2nd photo shows the slugs in the revolving plate and base.
https://www.garagejournal.com/forum/attachment.php?attachmentid=687046&stc=1&d=1506893044
Fixed photobucket scam but I no longer need these parts for the #4. I need them for my #5 (I need the complete #5 swivel set up.)
jakemac
New England
Last effort, take everything to a machine shop and ask how much they'd charge to make a set for you.
58Yeoman
Central IL
I've got both jaws and screw/handle for a Wilton 5" triple duty utility vise. No nut, base or replaceable jaws. Anyone need these parts?
bradpj53
Hey guys, this is my first post on the site. I have found a couple of threads that have been fantastically helpful in my search for Prentiss swivel jaw vises. I fell in love with them, and have started a small collection. I'll post photos here soon. My first was a local CL find, a #20 that heartbreakingly turned out to have a fractured main nut and several broken threads, making it unusable. May have been dropped at some point?
I've been watching Ebay for a possible parts vise; I know the fixed base #3 and the swivel base #20 (both swivel jaws) have interchangeable parts and I came close to a deal on a #3 that fell through. I recently saw a listing for a #54 Bulldog that was being parted out; the main nut has a "21" casting that means, I think, that it is swappable with a #21. Which leads me to wonder if a #53 Bulldog might swap out with a #20 swivel jaw? Looking at the listing at http://scuttle.dayid.org/wiki/index.php/Prentiss_Vise, the sizes seem comparable.
I did score an acceptable priced #19-1/2 on Ebay that I have reconditioned, and a #22 on a really cool 100 year old cast iron mobile base. Any help appreciated!
Brad
mach158
Marion, IA
Anybody have a handle that will fit a duracraft 4" or maybe 4.5" vise? It didn't have a handle when I got it and I found a handle only to be just to big to fit so before I enlarge the opening I thought I would see if anyone had one and maybe needed a slightly bigger handle.
bagged89s10
CT
I am parting out this Wilton 5" Chicago made vise. Let me knowing you need anything. The swivel base is intact and in good shape. The static jaw shelf has a corner broken off and it's cracked behind the pin hole for the main nut. The rear end of the vise is in good shape. The handle is in good shape as well.
Edit: The vise is sold. I kept the swivel base
back2class
I have a like new record 4" that is missing the main screw and nut...but otherwise complete. Willing to part out or buy the parts if they are available.
lasernat
Greetings all!
What a great organization for information on vices. Thanks for allowing me in.
I have a Columbian autocrat 414 that is in need of a spindle nut. Any ideas?
thanks,
bravedave3
I just picked up a autocrat 414 for 50 bucks. You can get parts from Wilton. I have the parts list here. The spindle nut from them was only 3 bucks, same with center bolt. Some other parts are expensive and 2 you can't get.
  • Columbian Mechanics Vise Parts List.pdf
organ
Atlanta
Have Columbian 503/603 parts up for grabs... swivel base, static jaw/body(just the body, no nut inside), screw/handle(not in great shape), and locking bolt thingy...
bagged89s10
CT
Looking for Parker swivel bolts and wrenches. PM with what you have.
I have some vise parts from 3" and 3.5" Parkers available. I also have Reed 404 with swivel jaw parts available.
hbass
Looking for a 974 1/2 Parker swivel base assembly, anything out there?
Thanks
vonhef
Southern, Ok
Will someone share the dimensions for the handle on a 1967 Wilton c-500?
I need a handle but will probably have it built
xxaler
Sutton Ontario
Have a single jaw in alright condition for a Record 634, and can make pipe jaws out of any material for one if the need is there.
454ragtop
Carver, MA
I picked up a Reed 203 a little while back, not in bad shape, other than the jaw support or "tongue" at the bottom front of the static jaw is broken off. Anybody have a good static? I'll give it a while, but if nothing turns up, I'll have to part it out. Really rather find a static though.
Jim
asadsack
I recently snagged a Merrill Bros 5 inch vise. Unfortunately, it's missing the base plate and the lower locking handle. This seems to be common with the Merrill Bros vises. If anyone has these (or any other Merrill Bros vise) parts, please let me know.
Thank you.
Shiftless
East Bay SFO
I'm Looking for a swivel base for a Wilton 9350.
Bagged:
I have a feeling the base you are looking for fits a few other models. Maybe you should post specs. What is the spacing of the bolt holes? What is the diameter of the very bottom of your vise's base?
