diesel06
running all new wire in my pole barn, new service has already been ran, want to run new wirings for lights and electrical outletss, not sure what type of wire i need to use
If you don't have the needed skills for Emt, I would run bx (ac90) if you want things on the surface like that or plan to leave it exposed
its a wood post frame, two 240 plugs one for air compressor one for welder
5hp 80 gallon, i know ill have to run a bigger wire size for the 240 plugs from the subpanel just not sure what it needs to be, i plan on insulating all the walls and finishing them in white metal so no wires will be exposed
right, it will have its own through switch box correct? yes i do plan on adding a lift thanks for reminding of that option, if i used emt what wire would i use, if u opted not to use emt what would be the next best thing
