dwljpl
Unpacked this to hang in the garage. I've wanted one forever! :D
crewchief888
NW indiana
i scored a metal shear a few weeks ago, but hadnt been able to put it to use.
i've been searching for suitable material to build a stand for it, and hadnt had any luck....
yesterday i found a HD trailer jack at work that was being scrapped, torched off the bent pieces, and brought it home.
scrounged in my scrap pile and found some more pieces....
dug through my spray bombs and found the "appropriate" color.. :rocker:
:beer:
Kmt803
White Plains Ny
Fixed airbag,the light was staying on ,read a post on Focus Fanatics about using contact cleaner on the connection ,picked some up at HD with a 5.5mm socket and it fixed the problem no more light, gotta love the Internet and all the people that help each other
Kmt803
White Plains Ny
Re: what did you do in your garage today?
[/IMG]
This is the cabinet I built to hold some of my tools. It is 48" tall, 92" wide, and 28" deep. I am thinking about putting some pegboard on the inside of the doors to hold light stuff like carpenter squares, hand saws, and small hardware.
I am NOT a cabinet maker (yet) and I was proud of myself because the doors open and close properly and do not rub or squeak anywhere. I don't like the gap where the doors meet, so I may have to dream up some kind of trim or something to close up this gap.
Nice job,can never have too much storage space
:beer:
My Eyes! My Eyes!... :evil:
jshillin
PA
Today I got a good bit done actually. My brother brought him '03 Ram over this morning and we changed the upper control arm and lower ball joint. It wasn't a horrible job, but the lower ball joint didn't want to separate from the spindle and took some extra coercion. Everything went back together easy enough. I did get to show off my 3/8" and 1/2" Fuel Impacts though.
Wife took my to lunch and icecream for father's day to miss the crowds tomorrow. Then I came home to change the oil in my F-150 and then changed the oil, oil filter, air filter and fuel filter on my John Deere 325. Then hosed off the oil that dropped down from the oil filter change. Got it put away right before the storm hit. Tomorrow I gotta change the oil in the wife's Kia.
lhc_cj7
Bolted down a safe I picked up used for the ammo. Now I need more ammo to fill this one up.
Steevo
43.49600, -112.04300
:beer:
I wondered where that last can of "Barney Purple" spray paint went to.
Lone Star Blaze
Oklahoma
Started cleaning and purging out things in my garage. Getting ready to move back to Texas. Hope this is my last big move until I retire.....if that ever happens
kaymccampbell
Upstate New York
Disassembled some small school woodshop lockers. Cut the door frames apart to reconfigure them. Started welding them back together in a more( to me) usable format.
bobcatdan
Kaukauna,WI
Worked this morning. Milked a general maintenance on a Deere 244J loader while making double time. Now at home, sitting at the garage bar taking a little break from making a riser for my Kennedy 520.
Kent_B
MI
Nuthin' much. Wash & tire rotation on the Legacy sedan. However, Fri. night, my son & I finished a rear brake/rear strut replacement on his Outback wagon. Garage is still a mess.
Vegaman_Dan
Pacific, WA
Worked on the Triumph a bit more. Not much paint left on the body tub. Unfortunately the rear valance has been hit and badly repaired. It also has rust on the bottom and I think while I could save it, it would take 20+ hours versus a replacement panel that can be welded in for $250. My time versus money meter says replace it. Gives me a chance to use spot weld cutters for the first time.
555
Nomad-Arkansas & Georgia
Rebuilt a Craftsman 17.5 hp riding tractor. It had been slowly rusting away in the woods for the past two years. Cleaned the carb, replaced the ignition swith and solenoid, put on new tires, cleaned/lubed everything and I mowed my little acre in Georgia tonight. I also had time to hunt down all the parts I need to build the "bitsa" Honda 750. Overall a pretty good day!
hughfree
Fayetteville, GA
A man after my own heart! I am just getting reenergized to start the reassembly of my TR-6......
Is that a Spitfire? What year?
bobcatdan
Kaukauna,WI
I have say this is very nice morning. I'm on the 9am late start shift this week. On those weeks I like start on my home projects in the morning. Decided today was a good day to take the H out for ride to warm it up and drop oil. Went for a nice 1/2 hour 5th gear cruise around the country side. Backed her in the shop and dropped the oil. Going to let it drip until I get home tonight. Just a simple fun morning playing with the tractor. A beer would be good, but not before work.
k-os
WI
Got an additional slab poured in front of the garage today!
Also got two more pieces of OSB up on the wall in the garage.
buzz4041
South Texas
Cut the oil pan and cross member for drive train alignment. Cut out all the gusset and motor mounts. Will clean them up tomorrow and get them tacked in next.
Dan in Pasadena
Pasadena, CA
Introduced my new pup to the space. She is a 13 week old lab mix.
Sent from my SAMSUNG-SM-N910A using Tapatalk
She's a beauty! What have you named her? Sooner; my avatar is almost 12 and slowing down a LOT. Someday hopefully far off i'll get a chocolate Lab and I'll name him/her Bosco, Hershey or Charlie Brown or some such. I
Give her lots of love and congrats
polexican23
burbs-Illinois
The wife is Irish so she said she wanted an irish name...Her name is Harp (like the beer). My choice of Monkey was vetoed. And she is kinda mellow and knows already that I am the alpha. Took just one day to crate and potty train her. She is a smart lil thing.
Ben Buck
S. W. Ohio
Put new tires and tubes on my dad's old 1977 Sears Free Spirit that I inherited after his passing.
A home brew antenna that has exceptional gain and brings in stations that built in antennas on most receivers can only dream of. if you are in an area with strong reception less of a need, but I know guys that before were lucky to get one or two stations and those would be iffy, and with a J-pole were getting collage stations (with minuscule power...) and clarity on the original stations as well as many they never knew were there...
k-os
WI
Got two more sheets of OSB up. Not have the bottom 2 feet left on the wall.
Concrete guys also came by today to cut the slab and backfill gravel in the driveway.
bczygan
DETROIT! Arsenal of Scrappers
Just started using my garage/metalworking shop after a long period of clearing it out.
Made up and assembled the metal parts for two double screw Moxon bench top vises.
Drilled and tapped the hand wheels and cut the sections of ACME threaded rod.
mbret2004
Took apart my snowmobile engine. Awaiting on a new crank for it. Swept up, and organized my hardware bins. Buddy came by with a anti freeze leak on his truck. Replaced heater hoses then drank a few beers.
zmotorsports
Northern Utah
Started a new position @ work this weak and it has really cut into my shop time in the evenings. I haven't gotten a damn thing done this week other than last night installed my new brake controller in my truck and put my old one in my son's truck.
Mike.
