[/IMG]![]()
This is the cabinet I built to hold some of my tools. It is 48" tall, 92" wide, and 28" deep. I am thinking about putting some pegboard on the inside of the doors to hold light stuff like carpenter squares, hand saws, and small hardware.
I am NOT a cabinet maker (yet) and I was proud of myself because the doors open and close properly and do not rub or squeak anywhere. I don't like the gap where the doors meet, so I may have to dream up some kind of trim or something to close up this gap.
Cleaned up a million little metal whiskers from the die grinder. Got a few in me.
Cleaned some sticky **** off the bench. Then cleaned the sticky **** off my hands... Wound all the weed whacker spools.
i scored a metal shear a few weeks ago, but hadnt been able to put it to use.
i've been searching for suitable material to build a stand for it, and hadnt had any luck....
yesterday i found a HD trailer jack at work that was being scrapped, torched off the bent pieces, and brought it home.
scrounged in my scrap pile and found some more pieces....
dug through my spray bombs and found the "appropriate" color..
Worked on the Triumph a bit more. Not much paint left on the body tub. Unfortunately the rear valance has been hit and badly repaired. It also has rust on the bottom and I think while I could save it, it would take 20+ hours versus a replacement panel that can be welded in for $250. My time versus money meter says replace it. Gives me a chance to use spot weld cutters for the first time.
Introduced my new pup to the space. She is a 13 week old lab mix.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Working on a J-pole antenna right now or will be again after I eat lunch.
