Tools of Japan
superautobacs
Vancouver, BC
Does any Japanese company make a screwdriver set with the new smaller screwdriver bits like this Wiha system 4
http://www.wihatools.com/700seri/759_microsets.htm
Nothing as comprehensive as Wiha's offering. ...not even remotely.
...unless of course you're only looking for a few select sizes like:
Engineer Part # DK-13
http://www.engineer.jp/products/driver/dv06/item_04/dk-13
Just like the System 4, the shaft/shank is 4mm (instead of 6.35mm/1/4"). The length is adjustable from anywhere between 18 - 90mm. It only has Phillips and flat head. It has a cushion grip and free-turn cap.
There's also Anex Part # 3600 to 3602:
http://www.anextool.co.jp/files/3600-3602.pdf
Also features 4mm shank, cushion grip and free-turn cap.
I just purchased a couple of screw drivers from my local Sears store that reminded me of post #1127. I picked up one slotted and one Philips with interchangeable blades and what do you know they are made in Japan. Can't wait to test them out!
I was pleasantly surprised when I learned that Sears was selling Vessel tools.
Vessel introduced this interchangeable/reversible bit series in August, 2013. : http://www.vessel.co.jp/info/html/2013/08/prokon-driver.html
A Pozidrive #2 and #3 bit is also available too.
Australia
Some items that arrived today.
Ko-ken 3/8" Impacts 9mm-19mm. I also have a Ko-ken 3/8" 8mm Impact socket but that did not come in this set.
Also pictured is a Ko-ken 1/4" extension set. Lengths include: 28mm, 50mm, 100mm, 150mm, 200mm, and 250mm. They feature a patented knurled base designed to ease spinning of the extension by hand for quicker running of the bolts/nuts.
I also bought some Aluminum sockets.
Qualitytools
SOCAL
Although if you notice the ones I purchased at Sears have a different shank on them compared to the ones you posted. The shank on the Sears ones does not have the reduced diameter before the actual head of the tool.
superautobacs
Vancouver, BC
Yeah, you're right. I missed that detail.
Those shanks serve dual purposes as it can easily be used with power tools by chucking it to anything accepts 1/4 chucks. That's for the Asian market though, as the North American chucks are not machined deep enough to allow the ball in the chuck to secure it in the 'locked' position.
superautobacs
Vancouver, BC
3-Peaks "Dia" pliers which I've been using for several years now. They've made my life easier by making it easier to pull screws and nails from tires.
The locking pliers version allows you to concentrate your efforts on actually doing the pull/twisting task without having to worry about losing gripping strength.
Qualitytools
SOCAL
Nice! Thanks for sharing :) I like how the tip is shaped, are those available in the US? I tried Googling the make but all I saw are regular pliers and needle nose.
superautobacs
Vancouver, BC
I bought them from Webike.net back in 2009. I just did a quick google search with the part # and i-tools on rakuten was the first hit: http://global.rakuten.com/en/store/i-tools/item/618702/
The product price is not bad at all, but the shipping cost is more. :(
Frankstools carries 3-peaks. Inquire with them to see if they can source the DS-130? Shipping should be cheaper from them.
BTW, I found some pictures I once posted in some other threads:
This tool supposedly made the company well known. It sure beats the cheap band strap thingamajigs.
Qualitytools
SOCAL
Thank You for the information and taking the time to look it up, I will check it out. :)
ER70S-2
Does anyone know anything about this set? I acquired it used around 10-20 years ago. I wonder if the manufacturer's name was on the corner of the label that was cut off...
Van Steele
Norfolk, UK
Man that handle on the tone ratchet sure looks very similar to that found on the new Blackhawk pear head ratchets. I think there might be a connection :dunno:
http://www.amazon.com/dp/B005YSZST6/?tag=atomicindus08-20
That is indeed more than just a mere resemblance.
Tone was one of the early adopters of high tooth-count ratchets in Japan. When they introduced their 72-tooth pearhead ratchets people were led to believe they were a Japanese product, when in fact they were imports from Taiwan.
If the RH3FHX is marked with "Japan", it's a bit deceptive and misleading.
Their new lineup is still imported from Taiwan. Newtools/Hi-Five is definitely one of their sources (probably their primary source).
It is indeed rather misleading, had it not been for these boards I'd be none the wiser.
If it means anything, I've noticed only the flex-head ratchets and knuckle bars are marked Japan.
I'm really liking these KTC oil filter wrenches.
dede2897234
Northern, Ohio
Got a new arrival. 3/8" Zeal sockets and Nepros 3/8" long ratchet.
RXtacy,
Congrat on the new arrivals! :drool:
Which internet stores did you purchase both items? If you don't mind, how much was the Nepros ratchet?
Do you own another set of low profile 3/8" drive sockets? If yes, would you mind taking comparison shots of a few sockets from that other set with the corresponding sockets sizes from the Ko-ken Zeal set?
Thanks,
Dave
RXtacy
Rockville, MD
RXtacy,
Thanks,
Dave
Thanks Dave! I got both from Mutsuura on Rakuten. The NBR390L was $107 + shipping.
The process was much quicker through i-Tools but they don't carry the Nepros line.
I don't have another set of specific low profile sockets. I have standard craftsman and gearwrench sockets if you want that comparison.
dede2897234
Northern, Ohio
RXtacy,
Thanks for sharing your source for the Nepros ratchet. I think Mutsuura has the cheapest price for the NBR390L (compared to Frankstools and Nepros.net).
Thanks for offering to do a picture comparison between the 3/8" Ko-ken Zeal sockets and Gearwrench. I do not think it would be necessary. It would just put the Apex brand to shame due to competing in different leagues! :lol:
Dave
eurocycle01
Received Koken breaker bar(600 mm long) and 1/4" ratchet(160 mm long) from Levelchrome.
Very easy to deal with and both items received in a few days from Japan.
Pics
Skin
Boston
Frank, any word on the new Nepros ratchets? Saw a release pdf back at the start of the year but the ratchets seem nearly non-existent. Its the new long flex (NBR390FL) and stubby flex (NBR390FS).
superautobacs
Vancouver, BC
Great item indeed. I've been using mine for about 3 years.
Compact 1/2 next to high output 1/2:
next to a (not very practical) ultra-stubby 1/2:
kblee27
Singapore
Not sure if this is Made In Japan.
It has a JAPAN stamped on the handle of wrench and a whole bunch of Jap words.
superautobacs
Vancouver, BC
:lol: Push Hard brand. ...brilliant.
Yup, Japan is COO. Care to take some photos of the inscriptions or the front face of the ratchet?
Based on the shape of the ratchet handle, and the "A" circle logo on one of the sockets, I'm going to guess it's made by Asahi.
kblee27
Singapore
Asahi...thanks. Learn something today.
superautobacs
Vancouver, BC
:thumbup:
Be aware of knock-offs and brand logo theft. This was taken at my local Princess Auto (Canadian version of Harbour Freight) a few months back.
First is this Multitec nippers. I was drawn to the logo ... it's the logo from Japan's most famous pliers company, Keiba. I've only read about how the Keiba name is slapped onto fake products. This just confirms it.
The authentic one:
Next is this Powerfist brand plier. A complete knock-off. The design of the jaw is originally from 3-Peaks. They even copied the design of the handle too, but these are made of cheap plastic. Having the authentic one myself, these felt and operated like garbage...some poor replica.
The authentic one:
In the past, I've also seen a Powerfist brand set of hex keys that were imitations of this set from Anex:
F
Frankstools
The 1/2dr line will not be released until the beginning of 2016...few more months of waiting
