Jarhead0408
Thanks man!
Does any Japanese company make a screwdriver set with the new smaller screwdriver bits like this Wiha system 4
http://www.wihatools.com/700seri/759_microsets.htm
I just purchased a couple of screw drivers from my local Sears store that reminded me of post #1127. I picked up one slotted and one Philips with interchangeable blades and what do you know they are made in Japan. Can't wait to test them out!
Vessel introduced this interchangeable/reversible bit series in August, 2013. : http://www.vessel.co.jp/info/html/2013/08/prokon-driver.html
A Pozidrive #2 and #3 bit is also available too.
LevelChrome because they had them on special. First order from them.
Aluminum sockets on sale for only USD17 and 1/4 extension set for USD48. Cheapest price I could find anywhere.
http://www.levelchrome.com/KO-KEN-SPECIAL-SALE_c_46.html
Nothing as comprehensive as Wiha's offering. ...not even remotely.
...unless of course you're only looking for a few select sizes like:
Engineer Part # DK-13
http://www.engineer.jp/products/driver/dv06/item_04/dk-13
Just like the System 4, the shaft/shank is 4mm (instead of 6.35mm/1/4"). The length is adjustable from anywhere between 18 - 90mm. It only has Phillips and flat head. It has a cushion grip and free-turn cap.
There's also Anex Part # 3600 to 3602:
http://www.anextool.co.jp/files/3600-3602.pdf
Also features 4mm shank, cushion grip and free-turn cap.
I was pleasantly surprised when I learned that Sears was selling Vessel tools.
Although if you notice the ones I purchased at Sears have a different shank on them compared to the ones you posted. The shank on the Sears ones does not have the reduced diameter before the actual head of the tool.
3-Peaks "Dia" pliers which I've been using for several years now. They've made my life easier by making it easier to pull screws and nails from tires.
The locking pliers version allows you to concentrate your efforts on actually doing the pull/twisting task without having to worry about losing gripping strength.
Nice! Thanks for sharingI like how the tip is shaped, are those available in the US? I tried Googling the make but all I saw are regular pliers and needle nose.
I bought them from Webike.net back in 2009. I just did a quick google search with the part # and i-tools on rakuten was the first hit: http://global.rakuten.com/en/store/i-tools/item/618702/
The product price is not bad at all, but the shipping cost is more.
Frankstools carries 3-peaks. Inquire with them to see if they can source the DS-130? Shipping should be cheaper from them.
BTW, I found some pictures I once posted in some other threads:
This tool supposedly made the company well known. It sure beats the cheap band strap thingamajigs.
Frankstools,
Would you mind posting a close up picture of the following:
- Merry Carbide Tip Diagonal Cutters, CT305-8?
Thanks,
Dave
Frankstools,
Thanks,
Dave
Man that handle on the tone ratchet sure looks very similar to that found on the new Blackhawk pear head ratchets. I think there might be a connection
http://www.amazon.com/dp/B005YSZST6/?tag=atomicindus08-20
Tone was one of the early adopters of high tooth-count ratchets in Japan. When they introduced their 72-tooth pearhead ratchets people were led to believe they were a Japanese product, when in fact they were imports from Taiwan.
If the RH3FHX is marked with "Japan", it's a bit deceptive and misleading.
Their new lineup is still imported from Taiwan. Newtools/Hi-Five is definitely one of their sources (probably their primary source).
Really wish they had the wobble/fixed extensions on sale. I would be all over those!
Got a new arrival. 3/8" Zeal sockets and Nepros 3/8" long ratchet.
RXtacy,
Congrat on the new arrivals!
Which internet stores did you purchase both items? If you don't mind, how much was the Nepros ratchet?
Do you own another set of low profile 3/8" drive sockets? If yes, would you mind taking comparison shots of a few sockets from that other set with the corresponding sockets sizes from the Ko-ken Zeal set?
Thanks,
Dave
Thanks Dave! I got both from Mutsuura on Rakuten. The NBR390L was $107 + shipping.
The process was much quicker through i-Tools but they don't carry the Nepros line.
I don't have another set of specific low profile sockets. I have standard craftsman and gearwrench sockets if you want that comparison.
I'm really liking these KTC oil filter wrenches.
Push Hard brand. ...brilliant.Push Hard brand. ...brilliant.
Yup, Japan is COO. Care to take some photos of the inscriptions or the front face of the ratchet?
Based on the shape of the ratchet handle, and the "A" circle logo on one of the sockets, I'm going to guess it's made by Asahi.
Asahi...thanks. Learn something today.
