let's see your craftsman block grinders
McBrownie
Cleveland, OH
Hi guys, see my comments in Blue.
It's not in the picture, but there was a 2nd one to the left forming/collapsing extending about 1/2 way from the cloud to the horizon.
I always thought that took cold air and warm water.
1st one I've seen in person.
They are scarier looking than they really are. Kind of like wimpy tornados. When they come off of the water and hit a tree, they might knock the tree over. But usually, the tree wins. Those blocks should do well on eBay. Probably pay for your gas. :thumbup:
jask
Gods Country, B.C.
kind of rough looking but runs fine - has anyone seen a light like this one before?
This is a Canadian market model with English/French label and the goofy lock out switch.... early 80s?
35$ with a homebuilt stand filled with 80lbs of gravel.
jrobb316
WI
I have 2 blocks that need the power cords replaced. Is there a source or are you guys making them?
torqueman2002
SE Michigan
I'll often use old computer power cords. The heavy server class cords.
:thumbup:
Also, <table border="0" cellpadding="0" cellspacing="0" width="363"><colgroup><col style="width:54pt" span="2" width="72"> <col style="mso-width-source:userset;mso-width-alt:2400;width:56pt" width="75"> <col style="width:54pt" span="2" width="72"> </colgroup><tbody><tr style="height:14.25pt" height="19"> <td colspan="2" style="height:14.25pt; mso-ignore:colspan;width:108pt" align="left" height="19" width="144">Coleman Cable 14-3</td> <td style="width:56pt" width="75">
</td> <td style="width:54pt" width="72">
</td> </tr> <tr style="height:15.0pt" height="20"> <td colspan="3" style="height:15.0pt;mso-ignore:colspan" align="left" height="20">6' Indoor Power Supply Cord </td> <td>
</td> <td>
</td> </tr> <tr style="height:14.25pt" height="19"> <td colspan="5" style="height:14.25pt;mso-ignore:colspan" align="left" height="19">Model Number: 09716 | Menards® SKU: 3702765</td> </tr> </tbody></table>
http://www.menards.com/main/electri...indoor-power-supply-cord/p-1462707-c-6410.htm
balane
Ugh, couldn't even spend 2 minutes with a roll of tape to save the badge. I haven't found any way to take paint off of one and leave the label in tact. Does anybody know a way to do that? Not the first time I've seen that unfortunately.
Price is good though. The eye shields are worth that much imo.
bagged89s10
CT
I 100% agree. I would go buy it for the shields and parts if it was closer to me.
bagged89s10
CT
I've never see the lockout switch before. $35 is a great price though. The light looks like it's aftermarket, unless the Canadian version had that style. I like the idea of having a wider tool rest.
Someone got spray paint happy.
Bench Grinder $20
http://boston.craigslist.org/bmw/tls/5157074078.html
Simple Green is your best shot. I've done it successfully, but its very paint dependent.
bagged89s10
CT
It dawned on me that I've never done a block with any color so I wanted to experiment a little. The cast parts are metal flake blue and the trim pieces are in satin nickel. This grinder was capital U ugly when I got it.
I know the badge isn't age correct but that's my favorite Cman logo so that's what I used.
That came out really nice. Another great restore. What do you print your labels on, with?
balane
Thanks. I use foil decal sheets in my laser printer.
I haven't had any luck on the paint removal with Simple Green in the past but, like you say Outlaw, I just haven't got lucky with paint style.
SG works great to real god on ordinary house paint and fast rattle can jobs. I hit some Epoxy paint and that pretty much sneered at it. I eventually got it to work, but is took the SG soaked Paper towel, and saran wrap to keep it from evaporating and several days to soften the paint, then that was just enough to allow me to start picking it off, but some times it lifted the underlying paint.
I've soaked dead (House) paint loaded paint brushes in it and saved the brush. Its only really worth it if it's a top quality brush to begin with.
highland_hunter
NH
Just got my first C-man block grinder, a 1/4 hp 397.19400, for $20 off CL. Wondering if anyone knows of a source for the owners manual? Thanks in advance.
jrobb316
WI
Owners manuals are long gone, but as they surface some guys scan and post them to vintagemachinery.org Here is one that is close to yours, not the exact model number but nothing really changed anyways
http://vintagemachinery.org/pubs/222/2183.pdf
erty67
Finally drank the koolaid! Just picked up this beauty for $20. Perfect replacement for the 6" harbor freight grinder I have been using. 397.19581
Sent from my HTCONE using Tapatalk
harleybuilder
Southern IL
Welcome to the "blockheads" Doc Block aka-tm will be by shortly to show you the secret handshake. ....
McBrownie
Cleveland, OH
Erty,
Nice early 1970's round top! It may need new bearings, which is easy enough to do, but will cost almost as much as what you paid for the whole unit. :D It would be worth it though, as it will run for another 40 years.
erty67
Erty,
Yea, I have to do my research on it now. It's really clean. It looks more worn from non use than being used. He started it up to show me it works and already seems smoother than my harbor freight one.
torqueman2002
SE Michigan
Hey fellow Block-heads, see my comments in Blue. :thumbup:
That is a great job and color combination. I like the badge!
Thanks for the tip.
Will these work?
http://www.amazon.com/dp/B000UCO8RE/?tag=atomicindus08-20
What do you use?
I've used citrus based paint remover with good results. If it is a foil style label, proceed with care and don't let the stripper sit too long (start with 5 mins, go longer if needed).
Congratulations and welcome!
To complete your induction, please see the following link for the official hand shake/pledge and warnings! :p
http://www.garagejournal.com/forum/showpost.php?p=4832270&postcount=5478
Does this look like your grinder?
Even if it does, we'd love to see pictures of yours.
Thanks, I added that one to my 'library'. :thumbup:
Nice!
Welcome to the forum and Block owners support thread.
See above for the Block-head hand-shake/pledge!
:thumbup:
Erty,
A grinder that is smooth and takes several minutes to spin-down, likely has dried out ball bearings. Also, it will give you the chance to verify the condition of the rest of the grinder.
See my signature for links to resources like the following:
  • parts
  • bearing replacement
  • restorations
  • cautions
See my comments above. :thumbup:
balane
Yes, those will work just fine on a laser printer. I'm pretty sure those are the exact ones I ordered at some point in time. I've had several different brands and all were exactly equal in performance. My only tip is to run a white sheet of regular paper printing something with a lot of text first to make sure the printer head is clean. After you do that you should get good results.
G20-Budo
Chandler, AZ
Balane,
Did you end up spraying a clear coat over the silver label after applying it to the block grinder? Just not sure how well the printed on lettering would hold up to actually use of the grinder?
Thanks.
drivesitfar
Doc: now that Chevelle SS is a BIG BLOCK. was it a tad on the quick side for those passes?
it took me half a day to get the Red joke, but i think i finally figured it out.
BTW have you dunked your PINK Parker in the E tank yet??:D
torqueman2002
SE Michigan
Nope, after I cooled down from the ride-along in the triple black big block I was thinking I'd do it today.
His Chevelle could use some heat management! It's OK above 20 MPH, but even yesterday {the Cruse is today, but for at least a week prior, the cars are making passes along Woodward. Today, it will be a 'parking lot' for the most part} there was a lot of stop 'n go.
Oh, it's RED! :thumbup:
balane
Balane,
Thanks.
I actually believe after a few minutes that laser ink sets in pretty well on these sheets. But I always put a clear sheet of laminate over the top for protection.
erty67
A quick clean up and its looking pretty minus some minor scratches on the top of it. And smoooooth....oh my, it's so much smoother than what I'm used to. Still need to clean up the tray, but overall I'm more than pleased so far.
McBrownie
Cleveland, OH
That cleaned up really nicely. What interesting is that it looks like you have part of a commercial tool rest on the left side. I wonder how that managed to get attached?
View media item 41515
erty67
no idea. I noticed that as well. Didn't know if all 397.19581s came that way. Also, is the light supposed to always be on when plugged in? I couldn't find a switch for the light itself. :headscrat
McBrownie
Cleveland, OH
Sounds like the lamp socket may have been replaced at some point with a non-switching one. The later block grinders ran the light off of the on/off switch, so the light was only on when the grinder was running. I had one of those and put in a switching socket. Yours would be an easy fix since the wiring is already setup for constant power to the light.
bczygan
DETROIT! Arsenal of Scrappers
3 blocks from my house.
The little auto repair shop.
Went there today to get a new radiator.
Sitting on a table, beat to hell, missing an eye shield, with the stone and wire wheels ground down to nubs, was a 1HP block!
Should have got a photo.
Bill
torqueman2002
SE Michigan
Bill
Buddy, as a fellow Block-head, I must advise you in the kindest yet firmest way - It Is Your Duty to Rescue That Block!
If you need help planning and executing an intervention (clandestine if necessary) let me know.
:3gears:
firemanast
Bentonville,AR
Just a group picture of three of my grinders and also my new car lift. :3gears:
