I find threads all over the place suggesting Super Lube from harbor freight which is just about the same as my dry lube from wd40 or Permatex 81950 but people say it leaks out if you use too much and I don't know how to rebuild engines. So I rather use my current grease/lube/oil/solvents that I have which I'll list and If I do have to buy something It needs to be something I can use for other things and not just to lube up ratchets once every year or so.
I have a set of kobalt 72 tooth ratchets (Taiwan for all you COO guys) their a sealed head type with two screws on the back next to the push button and a set of gearwrench 84 tooth flex head ratchets (also Taiwan) they use a snap ring.
Now on to my list of on hand canned liquids and yes I know three of these are penetrates.[emoji19]
I have...
WD40
WD40 rust release
WD40 dry lube
WD40 silicone
WD40 and CRC white lithium
CRC silaramic brake grease
CRC knocker loose
Permatex anti seize
Permatex dielectric grease
Seafoam Deep Creep
So guys like I said I would prefer to use what I have but I need some help in deciding what's best. But if I have to buy something I would too be able to use it for other applications beyond oiling up ratchets.
I have...
WD40
WD40 rust release
WD40 dry lube
WD40 silicone
CRC knocker loose
Permatex anti seize
Seafoam Deep Creep
