let's see your craftsman block grinders
bagged89s10
CT
After looking forever I finally found one!
Pretty dusty but in good shape and only missing a shield. The tag is really weird though, only contains model, serial # and Sears.
What does that mean? Isn't that info necessary for sale?
Anyway, I got it and the cabinet for $15, It runs smooth and I'll bolt it to the cabinet and store my grinding/buffing wheels and organize sandpaper.
You ****! Just a faded label. At least you can print a new one.
torqueman2002
SE Michigan
Poor wittle me...
The used tool market is great, but for some reason grinders are scarce. I have been stuck with this.
This thing has easily has ~23.6x the power of the home cheapo. Very scientific tests using a piece of rebar...
Thanks Drives and Jake! It will get put to good use. I'll update how the cabinet works with it but either way I am estatic to have gotten both.
Hmmmm, just wondering if any of those Ryobi parts would work on a Block ? :shocking:
I know, but the spark arresters, tools rests, eye shields/ hardware, wheel guard covers, .... Could be the difference for some poor abused/neglected Block, like this 1/2-HP m.397.19???? .
torqueman2002
SE Michigan
I just noticed there appears to be 2 nuts on the LH arbor. Probably the inner one was/is used as a spacer.
FWIW - New spacers are available, through Graingers.
1/2" Arbor
http://www.grainger.com/product/DAYTON-Arbor-Spacer-1LNE5?nls=1&nlsit=0.8&ssf=2&searchQuery=1LNE5
5/8" Arbor
http://www.grainger.com/product/DAYTON-Arbor-Spacer-1LNE6?nls=1&nlsit=0.8&ssf=2&searchQuery=1LNE6
bulletpruf
San Antonio
Line power frequency for Italy is listed as 50 hz, but I don't see how that would be an issue other than reduced rpm. At 50hz the grinder will just spin at 50/60 x 3450, or about 2875 rpm. Since that is a 7-inch grinder, the effective grinding speed (about 5300 ft/min) will be very close to that of a 6-inch grinder running at 60 hz, which is optimum for aluminum oxide wheels on carbon and high-speed steels.
Thanks, that's good info.
Scott
jakemac
New England
nine4gmc
Dallas
I would like to have that painted life size on the inside of my roll up door. :D
Please post that in the Awesome Thread where it belongs!! :lol:
exmaxima1
Midwest
Update.
"It is better to operate a 50 Hertz motor on 60 Hertz, then the reverse, but if it's not going to see heavy use it may be OK, and as said by others use a attachment plug to match the local style, Euro cords are brown, blue, and yellow w/ a green stripe,
brown is hot,
blue is neutral,
yellow/green is grounding/ earth." - R Meyers, OWWM
Running 60Hz motors on 50Hz power at full load will heat them up a bit, similar to using a VFD on a motor. You have to expect to derate their power capacity a commensurate amount, but a grinder will be fine.
bagged89s10
CT
Here's a block I just cleaned up for a GJ member. She purrs and takes close to a minute to wind down. Bye bye my first block I ever purchased. Has anyone found a source for printing aluminum labels?
https://vimeo.com/139856193
nine4gmc
Dallas
Flip that aluminum tag over and stick a vinyl label on it. You can print one out on clear vinyl so it shows the aluminum through it or white background if you like.
bagged89s10
CT
That's a good idea. This one is going out at it is, but if I end up with one like this again I am going to try that.
bagged89s10
CT
What's the best way to clean up these glass eye shields? I hate not being able to see thru the shields when using a grinder.
Window clean and a razor blade maybe? Or 0000 steel wool? I don't want to make them worse.
nine4gmc
Dallas
Toothpaste, seriously. We used it to remove water spots and **** from auto windows before car shows. Run it in real good with a light must of water and buff it off. Headlight restore kits would work well too I would imagine.
Sent from my iThingy using Tapatalk
bagged89s10
CT
These are spots from hot metal hitting the glass.
nine4gmc
Dallas
Yeah, like rock chips in windshields, you won't get them out but you can make the rest of the glass crystal clear.
bfm336
St. Louis, MO
Picked this guy up this weekend for $75. More than I would have liked to pay but worth it, great condition other than dry rot in the power cord which I'll replace. And some custom rests, which I may change as I will primarily use this with a wire wheel and buffing wheel to clean up old tools.
bagged89s10
CT
I think that one is technically a pre-block. Still a great find with the stand. :thumbup:
torqueman2002
SE Michigan
Bfm336 that is a great find ! Hell the stand is worth more than you paid for it!
bagged - Yup'ers! :drool:
fireman - Yes it is! BTW - are you still battling the forest fires? And, a big Thank You!
bfm - I love that striped [or is it stripped? I can never remember ;)] center band.
I've only seen 1 other example, on OWWM. It belongs to one of the moderators - Brian K.
http://vintagemachinery.org/photoindex/detail.aspx?id=16591
If you get a chance, perhaps you could post pics of your on their site also.
Brian K's. 1/2-HP m-115_7575 pre-Block with HD Base.
bagged89s10
CT
spongerich
Monroe, NY
Picked this one up at an estate sale a few months back.
I'd already bought a Logan 10" Lathe, Walker-Turner Drill Press, Benchmaster Milling Machine, KO Lee Tool and Cutter Grinder, Craftsman ball bearing rolling chest, and 2 SUV loads full of tools and tooling. She was asking $50 for the grinder and I already have 5 other grinders so I was planning to pass on it.
About the only things I hadn't bought were the grinder, an old Craftsman table saw and a Parker 3-1/2" Swivel Jaw vise. As I was about to leave, I asked her if she'd take $75 for the vise and the grinder and she agreed. She even included the custom dust catchers.
I'm extremely pleased with the grinder. It's amazingly smooth. It spins for an incredibly long time after it's powered down. I'll get around to replacing the label some day, but it's about #1205 on my project list.
torqueman2002
SE Michigan
Yes sir, that one's the Big Daddy!
You ****!
BTW - long spin down times are a function of wheel mass and bearing condition.
New bearings will have more 'drag' [therefore, longer relative spin down time] because of the grease packed bearings. As compared to smooth, older, dry bearings.
When you are ready to deal with the label, check the link in my sig line; there's a MS Word file with an editable label.
Also, if you find a file for the 'Sears Best' label, I like a copy for the thread.
:thumbup:
bagged89s10
CT
Welcome to the 1hp flat top owners club, athough you bought yours before I had mine and you got a you **** price.
BADASS!
:rocker:
:thumbup:
bulletpruf
San Antonio
I'm glad to hear it has 'caught-up' with you in Italy.
It will need the internal wiring re-arranged (see below diagram) to work on 220/230V. Be sure to verify if your power is 60 cycles, as jakemac mentioned.
:thumbup:
Doc -
Took the plate off - had a very nice wiring diagram on the backside. Removed one wire altogether and then swapped one end of another one. Used an adapter to plug into 220 outlet and it fired right up.
Seems to run great -- took 2:03 to come to a complete halt!
Figure I'll swap the wheels for some fresh ones -- I know I've seen recommendations here, but that may have been 50 pages ago, so does anyone have thoughts?
Need one rubber "foot" too -- it came with three. Might as well get a few spares. Anyone have the link or part # handy for these?
Anything else I need to do?
Thanks,
Scott
