Hi everyone: I bought a Gearwrench digital torque wrench with a built in angle meter for a head gasket job. The manual says torque the head bolts in 3 steps: First, torque them to 25 foot pounds. Second- turn them 90 degrees. Third, turn them another 90 degrees. The manual says lube the bolts threads and under the bolt heads with oil. When I broke the head bolts loose on the head, I used a 1/2 inch drive 24 in long breaker bar, these head bolts were on really tight. Now, my question is: Can this torque wrench handle the job without the gear head breaking on me for this high torque requirement. I bought this digital wrench thinking that with a built in angle meter it would be easier to do the job without resetting the angle and finding a different spot for attaching the dial angle meter for every bolt.
This torque wrench can torque up to 100 foot pounds.
The manual says to mark the head bolts with a paint mark in the front after the first 25 foot pounds and with the 2 additional 90 degrees, the paint mark will be in the back at finish. Is it a better way to do this job without spending extra money for a dial angle meter?
I'd like to hear what you guys say. Thanks.
