you guys ever used "Onyx" brand trade name tubing? which isn't exactly or only PEX? It's the only popular black tubing i've seen. is Viega simply black pex? anything unusual about it? thanks in advance, A
Viega is a saline PEX, rubber hose if for cars and gardens.
Foam is a common sub-floor insulation. We will be foaming 5500' under WarmBoard. There are applications of sub-floor systems where spray foam is not appropriate, such as a suspended tube radiant floor, but this system should rarely be used.
In other words, if you don't know what you're doing; you shouldn't.
Are you using the warm board on the first and second floors? I have used when remodeling and building new over a slab. On my rebuild the only way would be stable up in many areas.
Electric boiler yes.
As for staple-up. The definition is: attaching radiant pipe directly to the sub-floor of a radiant floor panel with pneumatic driven staples.
We design for others and install locally, many "sub-floor" heating systems like the one I am sitting on at the moment. We no longer "staple-up" since it is hardly ever "ideal" or best practice in most cold climates like Minneapolis. We use extruded aluminum plates with outputs 175% of a direct staple-up or suspended tube radiant system.
Staple-up should never be done. It is fast, it can be cheap--unless you use expensive pipe--and it will be relatively inefficient, requiring higher supply water temperatures that would be necessary with proper aluminum heat transfer plates or even the marginally better "suspended tube" sub-floor systems.
I was on the RPA technical committee and advocated for the then HeatWay design ideas believing that some, particularly the high temp solid fuel crowd would benefit from high temperatures and make radiant affordable to more people.
One of my first radiant floors--now over 25 years old--was a direct PB barrier tube stapled directly to the sub-floor of an old 4-square with an 1 1/2" of solid flooring over it. The supply temp is 180F. They love it and their fuel bills went down.
Fast forward to 2015, extruded plates and condensing boilers with outdoor reset.
Lower fuel bills, better response time and more comfort.
If you don't have a dedicated software for heat loads that can model output you really take a risk that the stapled up garden hose will not keep up in cold weather. We see this a lot here in kitchen remodels where old cast iron radiators are replaced with cabinets and refrigerators leaving marginal room for radiant floors.
We get the call, when the general and his "staple-up" plumber insist the system is working fine...
Finally. If "failure" is defined by 50-plus years of service before one of many sub-slab copper (or steel) radiant loops starts to leak, I want that kind of failure!
I consult on many Frank Lloyd Wright projects across the country and have seen many sub-slab systems going strong. Even more were installed in a plastered ceiling and very few have failed unless physically damaged from the outside.
What hurt the hydronic industry was a guy named Carrier that persisted with that dang cooling thing until everybody and to have it. Just like that pesky Edison guy.
Polybutylene, increased wealth and education brought hydronic heating back and PEX has assured its future.
Warmboard is a bargain for upper level new construction. I can be used over an existing slab but in new construction I can' abide the waste of a perfectly good slab, so the PEX is in the slab and 3/4" hard wood.
Well like everything in this industry there are installs that are very successful , that according to the RPA won't work . I have yet to sit on any kind of board with out people personal bias coming into play.
I have more than one I stall with onyx that have been working flawlessly.
One in perticular is a 2 story 5000 sq foot house sitting hi on the hill right off Lake Superior , they experience high winds and - 30 temps the last two yrs ,
(the system has been in for 6 yrs now.)
Anyhow the operating temp is 150 degrees and no a peep out of them , in fact I called last winter to ask and all he could do is rave about the system .
It is staple up onyx , no plates .
I don't dissagree about the plates but there are 2 issues with them , the very high Install cost and the noise , yea I know you say it doesn't happen but no one I have talked to likes them or wants them And there are a lot of installs in this part of the country. By several very reputable contractors.
I have been on I believe 4 jobs were aluminum plates were used by other installers. Customer complaints the noise !
P.S some of my first installs (for other companies ) was in the summit county Colorado back in 1974. I saw some crazy stuff and didn't argue as I was working for them but I do know 3 of the commercial buildings are still working just fine. I happen to stop and talk to the maintance guys , these were equipments garages for the snow cats
How many times I have heard you can do it that way , yet it's done and still working.
Did they use the extruded plates that go on first. The ones I used were attached with 10 screws and then the tube (pex) was snapped in .. no glue. The others were thin pressed AL with a grove. The pex was attached at the ends of the joist run with staples and then the plates went over the tube .. staples in between the plates. I think they recommended glue (silicone). I remember seeing a guy staple the plate to the underside of the floor -- so the plate held the tube. Very loose
Looks like you are on the right track. You should consider one of the smaller ModCons, Knight, HTP, or Bosch. You want the outdoor reset and you can do it all with one pump. IN the case of the Bosch the only pump and expansion tank you will need is built in.
My garage and system is similar to yours, but I paid considerably more (about twice as much) for my components. I bought a kit from a company, so the costs may be lower if you assemble the parts yourself. My Takagi alone was about a grand - maybe they're cheaper now.I posted this on a new thread in the heating and AC section and did not receive any replies. I was hoping I would have better luck here.
I am in the initial planning steps of building a new 30x40 woodshop and after reading threads on here for months I have decided to go with radiant heat. I knew absolutely nothing about the setup for radiant heat so I have to thank all of the people on here who contribute so much of their time. If it were not for you guys I would be lost. With that being said, I would like to make sure my design is going to work before I start purchasing anything.
I have attached a diagram of my plan, so feel free to chime in on mistakes and ideas that would be cheaper or more efficient. FWIW I would like to keep the design as simple as possible. Right now the total is about $1600 without the copper fittings
General Specs:
2x6 walls with r19
9' ceilings on lower level
8\12 attic trusses
(4) 300' loops on 1 zone
2" Rigid Foam
Tagaki H3M-DV-N Condensing HWH. I know the condensing boilers are better and if I can swing it I may.
Don't forget to include shutoff valves and hose bibs to allow for filling and/or maintenance work on the system.
Good luck!
I don't know about "best" but mine are on either side of the expansion tank with a valve in the middle to force the water to run through the system and back to the other hose bib.Thanks BlueBomber. Where is the best place to put the hose bib for filling and draining?
Going to bring this one back because its my turn.
40X48 pole barn, 12' x 40' room with bathroom. 2 zones one for room and other for shop. Just under 1900 foot of pex, 1.5" of eps foam under concrete and 3" around perimeter, heating with a Takagi T-H3M-DV-N natural gas.
Fired it up last week to test it (due to warm temps) but everything is right where I expect it.
Here are a few pics of my newly installed combi boiler heat system done by a local professional - critiques and positive comments welcome!
The uninsulated pipes are usually emitting heat in the same room that your heating. So it really makes no differenceWhy are the lines from the boilers or heaters going to the slabs always uninsulated in most of the installs? Is the length from the boiler to the slab so small that it doesn't matter? It seems to me that the cost of insulating them is quite small, and that over time it would pay off.
70R,
Looks like pretty much the same setup I was planning on doing. Do have a list or sketch of the setup you have there?
