let's see your craftsman block grinders
torqueman2002
SE Michigan
I'd like the links, please.
There are links for parts and pieces in a separate thread, which is the 1st link in my signature line.
Here they are also:
How to Select the Right Grinding Wheel
http://www.neme-s.org/Shaper Books/Grinding Dressers/Select the Right Grinding Wheel.pdf
Choosing The Right Grinding Wheel
http://www.mmsonline.com/articles/choosing-the-right-grinding-wheel
Bearings, Eye Shields, Grinder Feet, and Labels
http://www.garagejournal.com/forum/showpost.php?p=4000529&postcount=3
http://www.garagejournal.com/forum/showpost.php?p=5231461&postcount=7135
Bearing Sources
Amazon
NTN Bearing 6202Z $5.55/each + $9.95 shipping/order
http://www.amazon.com/dp/B010SDLXW2/?tag=atomicindus08-20
NTN Bearing 6203ZZC3 $6.28/each + $9.95 shipping/order
http://www.amazon.com/gp/product/B00DBOIX7E/?tag=atomicindus08-20
McMaster-Carr
http://www.mcmaster.com/#standard-ball-and-roller-bearings/=znvfvv
http://www.mcmaster.com/#catalog/121/1177/=znvhmy
Tool Rests
Re: Picked up a vintage Craftsman "block grinder" #257.19140
:thumbup:
McBrownie
Cleveland, OH
Finally my first block. I watched this one on CL for about a month. They finally dropped the price and brought it to my town. It still has what I think are the original wheels. It came with a rim type stand. Plus another grinder(?) and a Cole vise for about the original asking price of the grinder alone. It was an estate sale and they wanted to sale everything as a package. They had lots of tire kicker but no buyers.. Lucky for me I had some cash at the right time.
It's missing the rubber feet and has the as to be expected forever to stop feature, with no extra charge for the one piece eye guards that are hazy. Hope the guards polish out.
As I've watched this thread I've seen where others have posted the best place to buy bearing and other parts. As you might guess I had no reason to write down the information at the time. Sooo would someone be so kind and save me hours of searching and point me to where I can find this information. Thanks in advance.
Congratulations! :thumbup: A 1/2hp cap start is a very nice machine. Somewhere in this thread someone used a polish on the shields and they came out like new. (Mequiars maybe?) The feet can also be picked up at Lowes, search this thread for Hillman and you should find them.
torqueman2002
SE Michigan
My block began struggling to start and growling a lot during startup. It seemed like the rotor was scrubbing against the armature.
Sure enough, I could loosen the 3 main bolts, shift the relative position of the housing halves slightly, tighten back up, and change the response. Sometimes it was totally stuck, sometimes it was a little better.
Then I had an idea to *force* the air gap to be what it needed to be. I took one half off and inserted 10 thou shim slivers in four quadrants of the air gap. Reinstalled the housing half and the bolts. Snugged them, tapped the housing to equalize, and torqued them down. Pulled the shims out. Now it starts perfectly, no grinding at all.
After doing this I realize it would be best to do this process twice: once when seating the armature to the 1st housing half, and again when installing the second half.
x2!
:beer:
I like this idea. Now, what common household item is 0.010"?
Beer can? :lol:
I went looking for common house hold items that can be used. No empty beer cans, but lots of other close items.
:D
gnpenning
I have more questions than answers.
Thanks torqueman for the links. Do you have a preference on the bearings?
McBrownie Pretty happy about my find. There is a link from yesterday that mentioned the Lowes info. I got the Hillman numbers 38902 00393 H#884633. Hope this helps someone else.
torqueman2002
SE Michigan
You betcha.
I've been using NTN, just because that's what a local bearing supplier matched me up with for my 1st couple of re-builds.
I suppose, USA or Japanese made bearings should be fine.
exmaxima1
Midwest
You betcha.
Chinese ABEC-rated bearings are fine as well for the amount of use a bench grinder ever gets. If it was a machine running 24/7, better bearings make economic sense. And to be honest, I'd rather use modern bearings with modern lube than some >20 year old NOS bearings that have been drying out on a shelf somewhere.
torqueman2002
SE Michigan
I agree of course.
But, how can I tell if the NTN are 20 year old NOS bearings or fresh?
The 'local' bearing supplier I use is a SW Michigan industrial distributor.
Bearing Service
13400 Newburgh Rd.
Livonia, MI 48150
734-591-0400
734-591-1688 FAX
800-929-0200 FREE
http://www.bearingservice.com
JasonJ
Las Vegas
TWINS!!!
Got a second 1/2hp today... happens to be the same model # as my existing one. The new on is on the left, it's missing an eye shield and both are missing quench trays. The one I got today will also need it's lamp stalk and lamp assembly replaced.
The boys are so close together, they were birthed within 2-days of each other.
i.php
torqueman2002
SE Michigan
TWINS!!!
Twin brothers of different mothers!
:beer:
torqueman2002
SE Michigan
This thread is evil. I now have 4 blocks (1/3 x 3, 3/4 x 1). Stop me!!!!
In addition, I have the 1HP 10" Dayton.
I need help. "I'm AlpineWhite and I'm a grinder-a-holic and a vise-a-holic".
Hello Alpine!
We understand, you are among friends. :)
Pictures, we want pictures!!
Oh, this is not a 12-step-program. :lol:
bagged89s10
CT
Less than a week into the restoration and here's where I'm at. New paint, bearings, cord, hardware. Just need stones, tool rests, eye shields and the new label to finish her up.
Here's what she looked like before:
Looking great!
drivesitfar
Alpine: you need to read the entire thread and see all the warnings we've made to keep blocks from reproducing in your garage. One cure is to put different wheels on each one so you wont ever have to change wheels. Another is to sell the smaller blocks to members that need one and use the funds to buy bigger ones.
All: anybody have pictures of a block they either shipped or had shipped so i (we) can see how to keep passing these to other members? Im guessing bolting to a piece of plywood for starters. Do you take off all the wheels, shields and maybe the light too or ship as a unit?
bagged89s10
CT
I've shipped a few blocks and just bubble wrapped the **** out of them. I take off the eye shields and wrap them separately.
I wrap the light and bend it down over the front of the grinder and then bubble wrap the whole unit again.
exmaxima1
Midwest
With 6-inch grinders, I have wrapped them in bubble wrap with the wheels still on. Stuffed additional packing material as needed. I remove the shields and the lamp shroud, tie wrap the cord.
With >7-inch, I remove the wheels and bolt the grinder to a board---I slip plastic tubing over the bolts to keep from scratching the grinder. Cover with a plastic bag and stuff blocks of high density foam to immobilize. 12 x 12 x 24 box seems to be an ideal size for all grinders.
exmaxima1
Midwest
Has anyone tried installing a LED Flex Neck on their grinder?
Maybe something like:
http://www.amazon.com/gp/product/B00H89JQME/?tag=atomicindus08-20
I like this one because it has the ON/OFF switch next to the bulb, but most of these lights have some kind of AC Wall Transformer that would need to be integrated inside the grinder base somehow.
I have an LED sheet music lamp on one of my belt grinders, and it isn't very bright at all:
http://www.mightybright.com/Music-Lights/LED-Orchestra-Light
McBrownie
Cleveland, OH
Try again. trouble with attachments and the posting police.
$90 is a bit too high and I don't want my balls barred. But, this looks like a 397 delco built pre block. The first one I have seen. Is this some kind of missing link? A crown top to boot.
Vintage Craftsman BallBaring Grinder - $90
https://cleveland.craigslist.org/tls/5302083446.html
Pupuhd
New Jersey
A week or two ago I posted that I was attempting to make new tags for my 1/3hp 6" Block. This is my first time ever creating water-slide labels. These were printed on an ink jet printer and the water-slide paper is for ink jet paper and coated with Acylic Clear. However four attempts all yielded horizontal cracks in mostly the gray color, there were few in the "SPIT PHASE MOTOR" line.
Top-left is the original tag, top-right is the first attempt on a scrap aluminum. Here the paper curled immediately while submersing it in the water. You can see the heavy horizontal lines.
Bottom row, in order of left to right: This time I inserted each upside-down quickly followed by a steel flat weight to keep the paper flat. Each one created far less cracks, however still horizontal cracks when applied to the aluminum sheet.
Can anyone with some experience chime in here. Am I doing something wrong here, ink quality, paper quality, etc? Is there an alternative solution to making these tags: Litho, vinyl sticker, silk screening, don't know? Thanks all.
jakemac
New England
I don't know if this will help, because I haven't done large water decals (only small ones so far). BUT, after printing, and before going into the water, I seal the ink with a light coat of clearcoat spray and let it dry completely before dipping in water.
This might help with the ink damage when installing the decal by stiffening the decal slightly. :dunno:
torqueman2002
SE Michigan
Pupuhd
New Jersey
I did do that. I let the ink dry at least a day then sprayed several light coat of Acrylic Clear matte finish. Then let that dry 1 to 2 days before attempting the install tonight. I'm thinking poor quality paper and/or ink in the printer. Don't know, just a stab at possible problem. Thanks
I "see" said the blind man to the deaf man as he picked up his hammer and saw.
torqueman2002
SE Michigan
I looked through my links for a thread on decals, but couldn't find it.
IIRC - I read about it on:
http://owwm.org/
Looking good!
Don't get discouraged. The labels/machine plates are very time intensive for me. I wouldn't be surprised if you get requests for reproduction tags when you get the 'wrinkles' worked out of your process.
:bowdown:
Exeter
I've had success creating water slide labels. Did you spray the acrylic clear on before you transferred it to the metal or after? In my experience, I let the label dry thoroughly after printing then get it wet and transfer it to the metal. This is the stage when the label is the most fragile and can stretch or tear. Once it's dry on the metal then I sprayed with acrylic to make it more durable.
Pupuhd
New Jersey
I sprayed the Acrylic after printing, but before inserting into water. My understanding and from what I read the acrylic should be appied after printing so the colors don't run when dipped into the water. I was also going to spray it afterwards as a second coat, both front and back of completed tag. Correct me if I'm wrong.
....Don't get discouraged. The labels/machine plates are very time intensive for me. I wouldn't be surprised if you get requests for reproduction tags when you get the 'wrinkles' worked out of your process.
I have enough of the 0.020 gauge aluminum sheet to reproduce about 10-12 tags for this style. I even have an 1/8" hole punch to reproduce the corner holes accurately and cleanly.
alpinewhite
Orange County, California, USA
Got pics?
Exeter
I replaced the gas tank on my 12 year old mower. And the labels were no longer available. So I made one up in Photoshop. I painted the steel a gloss white prior to applying the water slide, but there is no reason it shouldn't work applying it directly to the metal. You could even put a gloss clear coat on the metal prior to applying the decal if you wanted.
I'm finishing up the restoration on my 1/2 HP and need a new tag. I've been researching getting one laser engraved, but I may do one up with a water slide decal until I can find a good laser engraved solution. I'll post pics if I do.
nine4gmc
Dallas
I would try printing a new label then applying it to the metal and letting it dry , then clear coating. If the colors do run, you'll notice before wasting too much time or materials. Worth a try:dunno:
Sent from my iThingy using Tapatalk
