metal roof
dlcwent
Member Emeritus
coastal maine
It sounds like you are going to have a metal roof. I personally love metal roofing. I have had it on my garage and house for years. Only drawback that I see, is if you have a deck or driveway next to the building, when it snows you get to shovel it twice unless you wait for the snow to slide off before you clean up. But how much snow do you get in VA. Not much I'd wager. Go for it. It's a one time job. It lasts a lifetime.
DonPowers
On The Hair At The End Of The Dog's Tail
That will work. Grace Tri-Flex is used more these days than felt. In any event you do need moisture protection as condensation will form under the metal.
I went with 5/8 Advantech sheathing, high temperature CertainTeed water & ice shield, Grace Tri-Flex then metal. Don't want to ever have to mess with the roof again in my lifetime.
bob15
Northeasten, CT
Not sure the reason for the OSB, but I would have the panels sitting/attached to the purlins. I would go: OSB, felt, purlin and then the roof panels.
383 240z
Findley Twp. Allegheny Co.
Just put a metal roof on my barn. 4' OC trusses. 2x4 purlins 2' OC. Titanium underlayment. Used it instead of roofing felt for 2 reasons, 1st is to reflect light better than the black, 2nd was condensation. Search "Redhead Racing Shop Rebuild" in garage gallery for pics.
joe_padavano
Northern VA
I've built several barns and buildings on the farm with trusses at 4ft spacing, 2x4 purlins, and metal roofing. No OSB needed. As for the snow, use "snowbirds" at the lower edge of the roofing to prevent the snow from sliding off the metal and tearing off the gutters.
homebuilt burner
central Wisconsin
Mine is trusses 2' oc, purlins 2' oc, reflex (it is a bubble type moisture barrier with a white side and a metallic side) then steel. The lumber yard sent the reflex out I had never used it or heard of it but now I see it in most of the metal buildings around here.
customtronic
Olympia, WA
I have a small leak in my metal roof. I'm really hoping that I can repair it. Any suggestions? I can probably snap a picture of it today.
Jon_E
Southwestern Vermont
Don, did you use the Zip System sheathing by Advantech, or just 5/8" Advantech OSB? Reason I ask is that my roofing contractor is telling me NOT to use the I&W shield and the Tri-Flex under my metal roof (products which I have already purchased, BTW) because I have Zip System sheathing. I told him the only reason I used the Zip System stuff was because it was cheap. Not because I wanted a crappy roof.
P
pjboy
virginia
yea i was going to do bookshelf purlins ,osb,triflex and then metal .will it hurt to use osb ?
432bullet
I have the OSB under the metal roofing, I think it makes it a lot stronger and resistant to hail damage, Much quieter too. The roof has been up since 2000 and seen a lot of bad weather here in Missouri.
