did you use a condensation barrier?
That will work. Grace Tri-Flex is used more these days than felt. In any event you do need moisture protection as condensation will form under the metal.
I went with 5/8 Advantech sheathing, high temperature CertainTeed water & ice shield, Grace Tri-Flex then metal. Don't want to ever have to mess with the roof again in my lifetime.
yea i was going to do bookshelf purlins ,osb,triflex and then metal .will it hurt to use osb ?
