let's see your craftsman block grinders
Reversepolarity
Washington State
So, you shot clear coat over the sticker after it was made and applied to the grinder, or they put some kind of clear coating on it before you got it?
What was the cost if you don't mind me asking.
The sticker has an overlamination on it.
I didn't clear coat the grinder.
The printer said a vinyl sticker with over lamination would be more durable.
It cost me $20
Was going to be $15 but she had to reconfigure the file.
It was expensive because I was only having one sticker made.
Even with the cost. I am totally satisfied.
Even with the cost of the sticker and paint. I am only into this grinder $40 total.
McBrownie
Cleveland, OH
It cost me $20
That grinder probably cost over $300 new in today's dollars. So, that is a great deal. Now, use the heck out of it!
JZiggy
Atlanta
It cost me $20
Looks like you got the sticker made to the exact same original size. Was it die cut?
Ridjobradi
Most likely with a vinyl cutter, which is like 2D plotter with a blade. The blade swivels to turn with the direction of travel, like a weather vane into the wind.
There would have been a die charge to make the die cutter.
McBrownie
Cleveland, OH
That makes sense. Those things are cool. I made a few steel rule dies once as part of a summer job in my early '20's. I still have the scars.
Pupuhd
New Jersey
Speaking of vinyl stickers, has anyone tried this method to reproduce one for the smaller block grinders that have the aluminum plate riveted on? Most have gone the way of water-slide decals, however for the life of me I can't get it to stay on the aluminum plate.
This is the last step I need to complete my 1/3hp block grinder and been thinking to go to a vinyl sticker on the aluminum plate. Even though it's not original in look I think it'll be just fine, maybe more durable. Thanks for any opinions? David
Reversepolarity
Washington State
What did you decide to do?
Pupuhd
New Jersey
I'm going to bite the bullet and go with the vinyl sticker. Depending on cost per sticker, I may have a bunch made, hopefully to sell on this thread to offset some of the money spent on the failed water-slide supplies.
ANY TAKERS?
I "see" said the blind man to the deaf man as he picked up his hammer and saw.
S4cruiser
NC
ANY TAKERS?
Depends on model. I could use a couple of the 1/3hp labels.
G20-Budo
Chandler, AZ
ANY TAKERS?
Pup - Would the 1/3 hp stickers be all of one kind, or could we send along our info so they would be for our 1/3hp grinder?
Pupuhd
New Jersey
This is my 1/3hp model that I have. I already have the tag file already made up detailed almost identical to the original. Second attachment shows how I can get six to a sheet.
I'll need to first find out if I can have all six on one sheet done, then cut out individually by me or if it would be more efficient to have individual ones made and cut by them. I'm thinking it would be cheaper, efficient and cleaner looking to have individuals made and cut.
I had also purchased aluminum of the same gauge. Was thinking of selling them with the "sticker" already mounted to the new aluminum with holes punched out.
This Friday afternoon I'm going to one sign making place down the street and see what they can offer and for how much. I really need to get this Block grinder and two other machine tags done as soon as possible so I can move onto the next rebuild/resto.
David
G20-Budo
Chandler, AZ
David,
Those are going to look NICE when you get finished! Issue is, my block grinder has a different label.. Looks like the one I attached.
S4cruiser
NC
David
I'd be down for one label just like you have pictured and how you describe above (with the "sticker" already mounted to the new aluminum with holes punched out). The other two 1/3hp blocks I have are slightly different...can take pics tonight.
Cman101
Northern CA, State of Jefferson
sector9 who did an awesome job with a 3/4 hp label helped me out with modifications for my 1/3 hp. 397.19581
http://www.garagejournal.com/forum/showthread.php?t=310883
I going to do the minimum order of 10 and will make them available for cost to anyone who is interested. I will put up a post when they are available.
JZiggy
Atlanta
My 1HP rebuild thread
danstead
Western, Pa
Block Men:
Picked my first BG'er today! 1/3 hp, 397.19580.
Stand came with it, not sure if was originally sold with Cman Blocks?
McBrownie
Cleveland, OH
Block Men:
Not an original stand as far as I know, but.....
probably better than original! :rocker:
That is a nice setup and welcome to the Block Grinder community. :beer:
danstead
Western, Pa
Thanks McB,
Can't believe how long it runs after powering off!
Stand seems very sturdy!
Hoping to utilize all the info from the GJ threads ;)
scooternut
Pittsburgh, PA
Block Men:
Great grab, just beat me to it. That was one stand up guy that you bought it from. I called right after you, we are in the same town and it turns out that he knows me! But, he told me that I had to call back the next day after 5 to check on you because he made a promise to you to hold it. For once though, a find that I didn't have to drive for.
Glad someone on here got it, and their first. I have another, was looking for a second.
danstead
Western, Pa
Thanks Scooternut!
Yea, That "guy" didn't want to hold this for long because several people have burnt him in the past promising to show and they didn't.
Over the past 6 months I've also missed several blocks by just a few minutes! Very pleased so far!
bagged89s10
CT
Block Men:
Great find and welcome to the block owners club! My first block was the same 1/3 setup which I ended up selling to another GJ member after I acquired 6 blocks which are larger. But the 1/3 HP model like yours run smoother than some 1/2HP models.
davethorik
Norka, Ohio
Getting this block as partial payment for helping a friend. We found it left behind in one of his rentals. Model 397.19440 marked Craftsman Commercial, 1/2 hp. Looks complete except for quench tray, works nice and smooth.
torqueman2002
SE Michigan
Nice Block.
That will dust off and be a good addition to your shop.
You may find a manufacture date on the bottom cover.
danstead
Western, Pa
S10,
Thanks for the comments, I'm now afraid that Block's will be like vises----can't have to many. Definitely want a 1/2 or 3/4 hp Block.
Hoping to find a manufacture's date inside somewhere!
