Now that the holidays are over, I was finally able to find the time to write this post about the process to refinish our condo’s nasty garage floor. In deciding what we wanted to do, we read through a lot of posts here on GarageJournal, watched youtube videos, and talked with friends. The most influential factors in deciding the route we chose were roger55’s and FFPL’s posts here on GarageJournal. Here are the links, in case they’re useful to anyone else:
roger55: http://www.garagejournal.com/forum/showthread.php?t=26308
FFPL: http://www.garagejournal.com/forum/showthread.php?t=13347
I’m going to break things up into several posts instead of one giant post, so here goes!
Summary / Overview:
We worked on this project over the course of a few weeks at the end of October/beginning of November 2015. Our garage is 360 sq. ft. with no expansion joints. There were 3 – 4 layers of peeling epoxy paint on the floor that a previous owner had put down. Then underneath all the paint was a clear sealant, so no wonder the paint wouldn’t stay down!
We used an epoxy concrete patch from Legacy Industrial to repair the damage due to 40 years’ worth of road salt from New England winters. We also used Wolverine Coatings 100% solids epoxy system. I can’t thank Scotty from Legacy Industrial and Bert from Alpha Garage enough for thoroughly (and patiently) answering all of my countless questions over several phone calls each. You guys rock!
Here’s a breakdown of what we ordered…
Legacy Industrial:
- 2 5-gallon kits of HD 110 Epoxy Concrete Patch in Natural (sand color)
- 1 gallon of Silax-Seal penetrating sealer
Alpha Garage (Wolverine Coatings):
- 1.5 gallons of BondTite 1101 for the primer coat
- 3.75 gallons of LiquaTile 1184 as the body coat in SAND BEIGE (TN4A)
- 1.25 gallons of EnduraShield 2254 for the UV resistant clear coat
- 26 pounds of a 50/50 mix of MILKWEED and AUTUMN TAN DecoFlakes
- 0.5 pounds of SuperGrip 850
- 1 22" notched squeegee
- 1 pair of spiked shoes
Based on Bert’s recommendation, we ordered 450 sq. ft. of materials to account for waste (material left on rollers, in cans, etc.). With those recommended materials, we would have a floor coating with a nominal thickness of roughly 28.40 mils (not deducting for waste). We ordered the DecoFlakes for appearance and to help mask the minor imperfections in the floor. We decided on "medium, 50% coverage" and calculated the recommended amount. We also went with Bert's suggestion and ordered the SuperGrip 850 to add to the EnduraShield top coat in order to provide traction (so the floor doesn’t turn into an ice skating rink when it gets wet).
Locally purchased consumable supplies:
- Masking tape
- Painters' tape
- 2.5 quart plastic measuring containers (used 7)
- 10 quart plastic container (to mix EnduraShield in)
- Cheap 2-inch paint brushes (used 6)
- 4-inch 3/8" nap roller covers
- 9-inch 3/8" nap lint-free roller covers, need to be solvent rated (used 4, had 6 available)
- 11-inch metal paint trays (3)
- Disposable gloves
- Baking soda
- Windex
- Methyl Ethyl Ketone (MEK)
Locally purchased reusable supplies:
- 6" x 2" margin masonry trowel
- 16" x 4" smooth finishing masonry trowel
- Spiral drill mixer paddles (used a small 2-inch one for quart containers, and 3 larger ones for up to 5-gallon containers)
- 9’ x 12’ painters’ plastic drop cloths
- 10’ x 25’ 3.5 mil plastic sheeting
- 10-inch Plastic scraper
Tools we already had:
- 5-gallon buckets to mix DecoFlakes (2)
- 3/4" masonry chisel
- 4-inch paint roller cage
- Small paint tray
- 9-inch paint roller cages (have 2 on hand, may have to throw away the one you use for the LiquaTile)
- Long poles or extension poles (2)
- Rubber gloves (I used dishwashing gloves)
- 4” angle grinder
- 4” diamond cup attachment
- Dust shroud
- Shop vac with fine dust filter
- Low-torque drill
- Extension cords (2)
- Wire brush
- Push broom
- Painters’ 5-in-1 tool
- Utility knife
- Ear plugs
- Safety glasses
- Respirator with carbon and dust filters
- Work gloves
- Headlamp
- Paper towels/terry cloth towels
- Mop and bucket
- Hammer
Summary / Overview:
Legacy Industrial:
- Masking tape
- Painters' tape
- Disposable gloves
- Baking soda
- Windex
- Small paint tray
- 4” angle grinder
- Dust shroud
- Low-torque drill
- Wire brush
- Push broom
- Utility knife
- Ear plugs
- Safety glasses
- Work gloves
- Headlamp
- Mop and bucket
- Hammer
and enjoy!
