maydaymike
Mounted a new rear tire on my Dyna.
Scott L
Peoples Republic of MA
Glad to see you are putting a ford in a ford hot rod!!
I wouldn't have it any other way. Love the small block Ford motor. This is a 5.0 from an 89 GT. Set up with an edelbrock intake and Holley 650 double pumper.
Also, the old Workmate stands are great. If you don't have an old workmate, go find one. It is perfect for mating engines to transmissions.
vartz04
LaSalle County IL
Rover bed for my 3yr old son,
Did you use plans for that? If so where did you get em
Today just cleaned and sat on my laptop trying to design a barn for style "baby gate" for my stairs. Got it planned out and then hit up menards for the oak I plan to use to build it
jnkpile
Re: What did you do "IN" your garage today?
Sorry, no plans, just a few rough sketches. I knew the mattress size and the room space and just tried to scale it accordingly. I tried my best to keep the proportions correct.
kaymccampbell
Upstate New York
Played with Otto. Played with the phone from hell. It's actually on the wall and working. Looks like Frankenstein's phone with all the seams and contrasting glue lines.
Pics of both tomorrow. The camera's charging and the latest Windows update is biting the PC hard, so I'm using the tablet and it doesn't do pictures.
INSP380
Cleveland, Ohio
Hit a high of 19 today. Great day to fire up the generator and test everything out. The recoil pulled like it was sitting in mud, second pull it fired right up. This time of year I want my backup to run!
Steve
Steevo
43.49600, -112.04300
I had a Craftsman block grinder on my workbench, with steel and brass wire wheels on it, and across the room, I had a Dayton grinder with two different grit wheels on it.
Today I decided to reclaim some bench space and consolidate things.
I had some left over uni-strut in stock, so I used it to mount to the pedestal where my grinder was, and then mounted the grinder and the wire wheel grinder on to that.
I loosened the two pinch bolts that kept the top of the grinder stand in place, and can rotate the top to access whichever tool I need.
6S1284
Carroll County, Maryland
Afraid of the cars on the lifts pinching the battery tender cables and don't have clearance for the prop rods on the cars so made some hood props out of dowels and rubber folding chair leg tips.
Took forever to warm it up today being 20 out. Way too much metal in there to warm up.
NUTTSGT
Northern Central Ohio
Man, those gears in Steevo's head never quit turning, another awesome build man.
I ran a short bit of conduit with some boxes for power and coax for the new tv.
k-os
WI
Got the front master cylinder banjo bolt replaced with a hydraulic pressure switch on the KTM. Once that was in I could bundle up all the wiring in front and get it tucked away to install the new headlight. Just need to get some hose for the coolant overflow bottle and I can start getting the tail and other body panels on.
s14brent
las vegas
Sears had this gladiator bench for $74.95. I did some rearranging. I've been looking at buying/building a shallow bench for a while now, so i'm glad I got to check this one off the list.
rharman
SoCal
Built this riser box out of some scrap wood I had to get my bike off the floor while I work on it. Maybe next year I'll get a legit lift.
Untitled by Joe, on Flickr
Probably 40 or so years ago, I built something similar to the pic I've attached. Only difference was that the full length of the top pivoted in the middle.
You just roll the bike up the incline, it tilts down, and the back flap flips under to support it. A metal top, a stand, or a couple of tie downs in the front, and you're good to go. I don't recall the mechanism to lock the flap in place, but there are a ton of easy options. Rock solid and I used it for years on all my race bikes.
KraftwerkMk1Jetta
Long Valley, NJ
Yep, I've seen that type of table on some other forums before. The one I built was thrown together with wood I had lying around. I'm just glad to be off the cold concrete floor while I work.
NUTTSGT
Decided to jump on the computer this morning and realized the monitor screen need cleaned, then I noticed the keyboard was equally dirty.
So the project for this morning was taking the keyboard apart and cleaning it. It's amazing how much ****, dust and dog hair a keyboard will accumulate.
CRXPilot
west TX
Was about to go look at a great Suburban but now I'm stuck at home because my car keys are riding around in my wife's van. I am a *****. That is all.
kaymccampbell
Upstate New York
Cleaned benches and floors. Put away tools. And hung a couple of sheets of drywall. Played with Otto.
I know I promised pics. I did charge my camera and snap a few, but my PC decided to take a dump today. It refuses to power up. Guess I'm ordering a new one tomorrow if it's not fixable.
JimVonBaden
Northern Virginia
Got started on the engine clean-up. Bonus, the ignition has been converted to electronic type.
Lots of work to get it pretty, but I have nothing but time, yeah right!
Cypherian
Delaware
So the project for this morning was taking the keyboard apart and cleaning it. It's amazing how much ****, dust and dog hair a keyboard will accumulate.[/QUOTE]
Soooooooo not touching this line.. LOL
Cypher
Yv.
Started cleaning up a 90's delta radial arm saw. Its in pretty good shape but I think I will build a new table for it.
Jeeper
Round Rock, TX
Got to love the bolts in the cardboard trick. I always do that when there are more than a few bolts of different lengths cause I know will crank down on a long bolt in a short hole.
Axehandle
NC in the Uwharrie
So a few days ago my 94 Exploder quit running. Rolled it into the shop today and found the crankshaft position sensor bad. Half an hour and a couple scraped knuckles later and the daily beater is ready for another 250000 miles ...I hope.
Colin Len
Long Beach CA
Over the weekend I started a fairly ambitious project (at least for my skill/experience level). Car is a 1992 Integra GS-R prepped for track days, it had a sunroof which was removed and the hole covered with a carbon fiber cap but now that I'm having the whole car painted I wanted to go back to an all metal roof.
Old roof removed
Mocking up the new roof
So far it's not quite fitting right, but it's close. Once I get that figured out the welding can begin - which should be interesting. I'm really hoping I can pull it off without just burning holes through this thin gauge metal.
ABADWILLYS
Hudson Valley, NY
Since installing my 4 speed Auto(4L80E) in my G body last week, This weekend I got started on the wiring, mounted the ECU under the seat, ran the harness to the trans, still need to finish the other wiring and run the TPS to my Carb, I made my trans cooler Lines(braided stainless)and got the headers re-installed. Also converted my new Shifter with a 4 speed plate and since Im Keeping my Bench Seat, mounting the shifter to the floor wasnt going to work, i made a pedastal to raise it up, kind of just eyballing here in this pic, but you get the idea of what its goin to be like.. oh and i "swiss cheesed" my radiator support, drilling about a bazillion holes in it to lighten it up!! I also have alum bumper brackets and a Glass bumper going on the car, just to get weight off the nose..
bodyguy16
QC, Canada
Old roof removed
Looking good! Don't forget to test fit the glass/plexi before finishing. You could also use panel bonding adhesive and you would just have to tack the corners near the glass and save some wleding and water leaks. (It probably wont see much rain)
Sent from my SM-G903W using Tapatalk
NUTTSGT
Cypher
Don't read too far into my post and get your mind out of the gutter. :lol_hitti
