dudemanh
I have that shockwave adapter too.. I put it on an older IR corded 3/8" impact at work to use with screws and lags.. Works good - a little wobble in it but otherwise fine. I feel like they should have designed a set screw in the thing, maybe opposite the ball detent. This way it doesn't come off too easily if you use it with an impact that doesn't have a pin lock. It doesn't see much use though, cause I've since gotten 2 other impact drivers..
The only reason I got the Shockwave 1/4" adapter was to use for small bolts when I work on my wife's car, my car, and my wife's mothers car. But my next purchase I'm kind of leaning towards the m18 fuel 1/2" high torque impact wrench tho!
Caparris
Greensboro, NC
Depending on what you do on them, I've really enjoyed the 3/8" fuel impact, 2654 I think is the number. It has pulled lug nuts off for me fine and is a whole lot easier to handle on smaller bolts/nuts
dudemanh
I have looked at the 3/8" impact wrench, but I'm not sure if it would break free lug nuts that are torqued down to 140 foot pounds. So my thought is to get the 1/2" first then the 3/8" impact! But the 1/2" impact would mostly be used for lug nuts and suspension parts.
dudemanh
is that the m18 fuel 7 1/4 brushless circular saw? if so how do you like it? that is one of the other things on my list. which i may have to get before any impact wrenches, due to my wife wanting me to build some book shelves, and not having any saw at the moment!
Frontierajl
It's an awesome saw if you don't mind the blade on the right side. If you prefer the blade on the left side and don't need the depth of cut the 7 1/4" offers you could look around for the 6 1/2" fuel version. I have both and they're both great saws.
Jmanders
El Segundo, CA
No, the one pictured is the 2730-20 6.5" version. As far as use goes I have loved it. Paired with a 5.0 battery I was able to squeeze a full day cutting various 2x stock and some sheet goods. Any other questions, feel free to ask.
StevenB
CA
From Milwaukee.
Regarding the build date, the serial number contains the build date. In your specific example of the M18 grinder, you have a serial number on that tool of B96AD142800756. That tool was manufactured the 28th week in 2014 as indicated by the numbers "1428". The serial number can be found on the nameplate sticker which is typically located on the opposite side of the tool of where the logo is located.
Caparris
Greensboro, NC
Ah yeah, if you want to be 100% sure it will get them off then the 1/2 will def. do it! It won't even hesitate on bolts at that torque.
The 3/8 would be close.. I think with a fresh battery it would do it but if you want to be sure the 1/2" is the way to go
Ign
Butte Peak ND
My 3/8" 2654 breaks lug nuts on our '05 GMC Yukon and '08 GMC 2500 that I torque to 140# myself each time I r&r a wheel. BUT we don't get much corrosion or rust here. I use a deep 22mm socket in 3/8" drive I ordered specifically for the chore, I think it's a Sunex from Amazon.
FOCUS.FREAK
Burr Ridge, IL
I have the 3/8 fuel m18 and I use it at work all the time. I use it when doing brake jobs on school buses. When removing the caliper bolts from time to time I'll run into a bolt someone impacted on it won't remove. But then again it's a 18mm bolt head. When removing band clamps from exhaust work now these are rusted and corroded bolts. Takes a 14mm bolt head I've always been able to remove these powers right thru them. Axle bolts on the fords or Chevys does a great job. I even use it on some international buses. I tested and put a 24mm socket on a reducer and it powered right on with ease. I find myself using it all the time now.
firworks
IL
Remember when I posted that photo of my M12 3/8" impact with the huge spindle nut socket on it?
Well, I replaced a CV this weekend and I DID try it. It worked! It broke the nut free and very slowly progressed on removing it. I figured after a little while though that it proved it was capable and I didn't need to subject it to more so I took it off the rest of the way with a breaker bar. I took a video but I haven't downloaded it yet from my phone. I'll try to put it up tonight. It was weeblewobbling like CRAZY but the important thing is it did it. The spindle nut torque on the car is I think 134 ft/lbs, but I don't know what it was torqued to the last time whoever had it off. This is the first time I'm working on this car.
dudemanh
Yeah, I'm probably going to pick up the 1/2" impact on my way home from work. Then after I save up a little more money, I'll be getting the 3/8" impact and probably an extra xc5.0 battery!
Does anyone know where to buy a carrying case for the 1/2" impact wrench?
Caparris
Greensboro, NC
Do you want the Milwaukee plastic one? If so, I got mine on eBay for next to nothing
I would consider the rubber boot as well. Does a great job protecting the tool.
firworks
IL
Scotty divert power from the main shields to the drive system! I'm givin' her all she's got!
<iframe width="560" height="315" src="https://www.youtube.com/embed/w2ogFHAC-1I" frameborder="0" allowfullscreen></iframe>
Like I said previously the spindle nut torque spec on this car is pretty low as far as they go, and I don't know what the person who worked on the car previous to me torqued it to anyhow. Still was fun to try.
signcrafter
Nice. Is that the 2454 impact? That is my next purchase with the free 1/4" ratchet but HD is always out of stock online. They had some a few days ago but I waited a day and they were out again.
I was pretty impressed when my M18 fuel with hex adapter took off a chevy axle nut. I don't think I would use the m12 3/8 to do axle nuts because I have the big m18 1/2" and my m18 hex driver impact but nice to know the m12 has some balls.
one9gt
San Francisco
Is it the color? Is it the battery bulge? Is it too warm?
I got the black hoodie so the color doesn't bother me. The bulge isn't an issue as I work in open areas so it's not bumping into random things and when I'm in a vehicle it's off to the side and not in my back. I would of thought the high setting would make me sweat but it's keeps me comfortably warm and I can feel the difference between high and medium but the low setting feels like it's off and I've got a $150 sweater on. Maybe it's too baggy on me? I wear medium t-shirts and those are pretty form fitting on me. So I naturally got a medium hoodie. The fit of the hoodie is what I like but maybe too lose for the heating elements to do their voodoo....
montanafordman
Meridian, ID
Finally joined the Milwaukee club today! My dewalt drill is a little long in the tooth, has the 18V lithium batteries that are getting kind of old (2010 I think). I've been drooling over the fuel hammerdrill combo kit for nearly a year and finally pulled the trigger. Got the newer version with the 5ah batteries. Next up is probably some M12 stuff like the ratchet, maybe 3/8 impact, M12 drill...This is a slippery slope...
kctyphoon
Jersey/Staten Island
The jacket is better than the hoodie, but the hoodie does keep you warm. Not hot, but warm.. Where the hoodie shines is its ability to be worn under something else.
A mistake some people make is still wearing layers of clothes under the heated gear. You have to dress lightly.
dacan23
RI
I have a real Milwaukee light problem, just ordered the 2360 Flood light 5.0 battery combo from HD for $134. Here is a list of all the M12/M18 lights I have. According to my records theres only 3 lights I dont own... lol
M12 Work Light
M18 LED Work Light
M12 LED Work Light
M12 TrueView LED Lantern Light
M18 LED Flood Light
M12 LED Stick Light
M12 LED Stick Light
M12 TrueView LED Spotlight
M18 TrueView LED Flood Light
M18 TrueView LED Stand Light
firworks
IL
M12 Work Light
M18 LED Work Light
M12 LED Work Light
M18 LED Flood Light
M12 LED Stick Light
M12 LED Stick Light
How did you get it for 134$? :headscrat
Also sounds like you've still got a bit more shopping to do then!
dacan23
RI
Chatted with a rep, got them to apply a Lowes 10% coupon.
Well the M18 old bulb work light I will probably never own, do they even still sell it? Have considered the M18 Stick, perhaps can get in a good promo eventually, but output is just a little more than M12s. M18 Lantern, max output is 700 vs M12's 400, but either old or new Flood would prolly serve the role.
Of course anyone is free to send me a gift to complete my collection...
Caparris
Greensboro, NC
M12 Work Light
M18 LED Work Light
M12 LED Work Light
M18 LED Flood Light
M12 LED Stick Light
M12 LED Stick Light
And I thought I was bad :lol:
firworks
IL
Yeah do not get the incandescent lights. At least the M12 is horrible. I did a comparison of it vs a few other lights I have. This link should drop you right at the lighting comparison.
ImStricken06
Within Range
just ordered the 2754-20 to add to the collection. cant wait to get it. i have the older m18 3/8th and it was amazing at 167lb-ft tq. it still works, and works great; but i most have it in my trunk for lug nuts on the side of the road if i need it. the new one will be in the garage with the rest.
mrvm
PA
The jacket will be warmer mainly because it blocks the wind better than the hoodie in addition to heat retention. Make sure the fit is a bit snug for best results and definitely don't layer under the heated hoodie/jacket. The heated hoodie works great under a heavier outer jacket.
