EK'S TOOL FINDS AND I.D. HELP!!! (an ongoing sub-forum)
E
ekegelmann
Northville, Mi
Check out this box I picked up. I've looked online for a brand similar but can't find anything right now, 2 sick kids here. uploadfromtaptalk1457229009096.jpguploadfromtaptalk1457229025104.jpguploadfromtaptalk1457229041484.jpguploadfromtaptalk1457229051727.jpguploadfromtaptalk1457229061720.jpguploadfromtaptalk1457229069900.jpguploadfromtaptalk1457229083404.jpgHere are some photos. No markings but it's kinda cool
Sent from my SM-G920T using Tapatalk
E
ekegelmann
Northville, Mi
Curious, picked this up today for $10 along with another. I'm curious, if I try to get the blue paint off u still it going to take the Kennedy color as well? What does anyone suggest? I want to blue x off. Also what color felt is the best replacement?
E
ekegelmann
Northville, Mi
I know this is also a Kennedy, but does anyone know the model #? I want to repaint and restore this....anyone have a Kennedy decal for the top? Also does anyone know what color paint to use to match? Although this box appears to have been black? Has Kennedy ever had a black box?
countryroad82
Kentucky
You MIGHT be able to gently remove the blue paint with fine grit sandpaper and plenty of buffing. Maybe test some thinner on it. It's always a crapshoot with old paint.
E
ekegelmann
Northville, Mi
This was in the toolbox, a Bonney wrench, 1 1/16...has the number 7 engraved. I can't find it on alloy artifacts. Can anyone give any specifics? Seems like an engineers wrench etc. I also can't figure out the production year based on the logo. Thank you.uploadfromtaptalk1458009628240.jpguploadfromtaptalk1458009655853.jpg
E
ekegelmann
Northville, Mi
Here's another, I figure it was part of a tool kit. .Vlchek 36 it measures 5/8" & 3/4"...but I didn't know Vlchek used the forged in usa as a raised panel. ..thought drop forged is what they used? Is this early 50s? uploadfromtaptalk1458010779943.jpguploadfromtaptalk1458010788888.jpg
E
ekegelmann
Northville, Mi
Picked this craftsman 315.27830 6 1/2" electric hand saw up today, its very heavy. Anyone know when they made these as i cannot find a date code etc.
twertsy
Reedville, VA
This will get you close: http://toolarchives.com/node/230
There should be a date code at the opposite end of the shank from the head.
Sam'sAutoParts
Northeast PA
Appears to be a 520 Kennedy, color probably was brown wrinkle. Kennedy has parts available for these boxes, not sure about paint though.
E
ekegelmann
Northville, Mi
Anyone know the date code on this is it a 44? Confused. Thanksuploadfromtaptalk1465146141528.jpg
larry_g
oregon
I have that box and was told it was military issue. It was part of a standard kit. There is information in another thread here somewhere.
lg
no neat sig line
crankshaftdan II
Milwaukee, burbs.
Just a few words of wisdom from my previous bout with Kennedy Tool boxes--yours looks to have possibly been smoke/fire damaged? Handle looks in fine shape considering the looks of the box--I don't know the model #! I have had several Kennedy's with foreign paint residue--I tried thinner, mineral spirits, goop, hand cleaner, simple green +++ and most of the time the paint would come off and the brown would also! Sort of leaves a flat finish on the brown which usually does not set well with the un-affected area. I purchased several 12 oz spray bombs from a Industrial dealer who sold Knnedy's(Pricy $14.50 ea can) these bombs will give close color to the factory finish, however I never could blend in a cleaned area on a damaged box. They more than likely have a special set-up at the factory which gives the special "wrinkle fimish" which you don't get with a bomb??? To r-store to like new condition will take considerable time & $$$-but gives one nice satisfaction of doing same! I did have one regular Kennedy that was in the "Black Wrinkle Finish"-one and only!!
Hope this is of some help and good luck with the projects......Cranky:3gears:
E
ekegelmann
Northville, Mi
thanks, these were actually just rusted, no smoke or fire damage. Im still working on them. Very nice boxes, just taking time.
E
ekegelmann
Northville, Mi
Heres an interesting Dreis & Krump wrench. I think they were for bikes or buggys, not sure on age either. for a $1, couldnt pass it up. Anyone seen these?
