NUTTSGT
Northern Central Ohio
Made a shopping list of what I needed to pick up at NAPA and OReilly's and tried to figure out a lay out to make the most efficent use of some J-channel for a co-worker. I don't have enough coil stock to bend it up though.
BaMaDuDe87
AL
Started working on a poor man's dust cyclone and cleaned up and rigged up a filter for my shop-vac.
Took a few min to take the blade off the push mower and about knocked myself out in the process. So called it a night. Don't want to hurt myself too bad tonight.
Kent_B
MI
While my son changed the oil in his car, I started pulling the right-side tin off the old Ford tractor in preparation for a major rewiring job. A sixty year old machine is gonna need some attention. It's all part of the incredible boogie.
R-Savage
Spruce Grove AB
Still on Getting the garage all cleaned out and organized. Today is the day for "The Workbench". Eventually it will be getting ripped out. and a better one put in. I will be getting rid of a lot of Junk today. Hopefully.
LS6 Tommy
Northern NJ
Just got up (it's NOON) after being at my cousin's house until almost 4 am. Gonna Summerize "Jake" the snow blower, putter around and plant some lily bulbs (not IN the garage).
kaymccampbell
Upstate New York
Waited for the temp to get above freezing by organizing, cleaning, purging **** and moving the air filters on the compressor, so I can clean them. The 5/8 of nice new drywall above them blocked me from removing the elements.
cleason
austin texas
put new brake pads on my 2011ss,replaced the rear sway bar bushings and links,(energy suspension) replaced the front sway bar frame bushings. with the poly bushings i can feel a slight difference. poor mans way to beef up handling. the brembo brakes are by far the easiest to work on. learned brake jobs in 1971.
NUTTSGT
Carried in some firewood. Even though it's getting nicer outside, I've still been starting a fire in the morning to take the chill out of the air. Besides that, I still have plenty of wood left from the mild Winter.
I also changed the oil in the wife's Explorer and rotated the tires. It reminded me that I need to pick up a new oil filter wrench.
Gidge
New England
Grinded down one of those stupid polarized plugs -- please don't tell the code police ;)
Stickboy
Byron, GA
Got my new to me kawasaki mule running, stripped many of the previous owner's add-ons and ghetto wiring, new carburetor and new switch and she runs like a top. Not sure what I'm even going to do with it, but it was too good of a deal to pass up.
Outlander
Quebec, Canada
Ran the snowblower down the driveway since I was parked there when my contractor came yesterday. My fault, I slept through his early morning visit (which is unusual for me)
Steevo
43.49600, -112.04300
Dragged the lawn mower in today, dropped the blade, drained the oil, replaced the air filter and spark plug, sharpened the blade, then balanced it, and re-installed the blade and filled with new oil. While I had it in the shop, I scraped and wire brushed all of last year's grass buildup out of the underside of the deck.
Counting the trip to Home Depot for the plug and air filter, I spent about six hours total getting the mower ready for spring.
Vbwiley92
NC (live near the triangle)
Changed the oil, removed the loose oil fill neck, greased the front end, and replaced the oil sending unit on my 04 Z71. While I was under there I noticed grease from the cv axle all over the shock. Looks like I have work to do next weekend. Truck is about to hit 160k, so I can't complain. Only major repair so far has been rebuilt transfer case because of the pump rub and LF axle seal on the front diff.
Sent from my SM-G935V using Tapatalk
Changed the back tires and wheels on SWMBO's Villager. One had a badly broken belt and the mate was discontinued. So I found a pair already mounted with 80% tread at least, for 50 ea and swapped them. I'll use the orphan good tire as a full size spare.
jumpstart
Central MA
Put my welder cart together, then started to do some rust repair on my Camaro. Time to take care of it, been putting it off for awhile.
jkherd
Southwest Missouri
Mowed the yard and then spent the afternoon reworking my blasting cabinet, installed new lights in the cabinet and wiring the shop vac to the lamp wiring so all come on with one switch. Works pretty good, now on to working on the Model A parts. :thumbup:
firworks
IL
Got my rear brakes replaced with the actually correct parts. Recorded video of it all but I'm not sure if it's useable. Time to start transferring and editing...
brownsmustang
SWMO
Finished wiring in my lights and unpacked and organized. Seems like I'll never get done.
Sent from my SM-N910V using Tapatalk
crewchief888
NW indiana
scored myself a "new" tailgate last week
a freebie from one of my customers.
went to install it and found the top of my bed was about 1 1/2" from where it should be.
nothing some blocking and a highlift jack couldnt persuade back into place.
:beer:
R-Savage
Spruce Grove AB
Finally got my Workbench all cleaned up and organized, Cleaned and somewhat organized two smaller toolboxes, got all my shop rags cleaned and put back into place, Cleaned out a lot of junk, Also cleaned and organized a shelf that holds Wax, polish, WD-40, engine oil, etc. etc. All in All a pretty productive day yesterday. Also got the VW Jetta all washed and cleaned. :rocker:
Ill post pics of before and after in my Garage Machine Shop Project.
Ghost11
Im in the process of cleaning as well. Takes forever. Sold a bunch of parts yesterday, made $140 bucks.
LS6 Tommy
Northern NJ
No, but that is allowed by the consumer.
Old-school stereo component with new school stereo component --polarized plug will not fit in "unswitched" plug --PITA.
Happy Easter.
I hear ya. That "Mattress Tag" thing has been used for so many "Big Brother" type comedy routines it's not even funny.
At least your new equipment HAS unswitched accessory outlets. So many of them don't these days.
Tommy
burnedonice
Kansas City
Finally pulled the mopeds out of the shed, and got them all de-winterized yesterday, just in time for 1" of sleet on the ground this morning! cold here in KC
vertguy
SE WI
Wrapped up the final repair to my soon to be sold daughter's 2000 CRV. Can't wait to the get this car gone as this 16 year old car with 190K is becoming a PITA to maintain.
R-Savage
Spruce Grove AB
Had a Hot cup of tea while walking around in my Garage today. Now I'm thinking ...... Uh Oh. I'm pondering a Multi Compressor Line Setup and receiver tank system. Yeah a Bit overkill. :rocker: But it will be fun. :bounce:
Why?? I want to build a "Big Boy" Pneumatics System for my Garage
ryolse
Colorado
Re: What did you do "IN" your garage today?
While switching from a "Industrial" to "Automotive" fitting on my Husky extended tank drain valve assembly I noticed that it had bubbled out of the braided line. Almost as spooky as finding out your friend who was left for dead while hanging from a cross just came back as a Zombie.
Not so sure I want to go back to using this line. Any suggestions? Guess I could go with a solid line, but I wanted it to be flexible when moving the 33 gallon tank around.
