Swedish workshop in a old brewery
hkp
Thank you Sean :)
Tack! Ja grus blir lite jämnare än kullersten, eller som i mitt fal jord, lera, gräs och några singelbitar :)
Thx :)
Woh thats a big turbo, how did the engine behave with that? :)
Holset hx52 full spool at 4500rpm, like getting kicked by a mule.
N
NTCRS
Lindås, Sweden
Okey cool haha, how much can u rev?
I use a Hx40 on my 2.3 litres, pretty much ***** :p Full spool at 4000, and I only rev 7000, so kinda hard to drift smaller turns. But the feeling when you are flooring the pedal and the revlimiter just screams on the third gear and full lock on the wheels :3gears:
N
NTCRS
Lindås, Sweden
I was running a haltech and had limiter set at 9000
Mr Swede approves ;)
What ECU are you using to control that volvo? I am working on a project involving a TV7301 turbo (76mm) on a mild 454 - that 7.4l for you euro folk.
Im using MaxxEcu, its a swedish brand that made there own ecu. maxxecu.se is there website. Very user friendly unit.
7.4l, thats like more than three of my engines combined ;) Im guessing that the TV 7301 got a pretty big exhaust housing?
N
NTCRS
Lindås, Sweden
Working 5-shift now for the next 10 weeks, I was free 5 days last week and now my "7 days work week" started this morning, so I dont think that I will do any big project this following week.
But I managed to get a few things done last week:
Built a storage rack in the small room, very simple and sturdy, cost like 60$ [emoji1360]
Bought some cheap volvo original 16" wheels for the drifter since Im not using it as much these days.
Got a really good offer for the white 17" compomotive and made some dollars, so I orderder new 215/35/18 tires for the cratus-wheels that I will use one the 244 brick.
We own a horse transporter, that is really great for many things, but not so much for long lumber, and since we are gonna build a new porch and some other stuff, So, I bought an old mouldy caracan for 40$ and started tearing it apart [emoji16][emoji1320]
One hour later
Three hours later
And four hours later
Then a buddy of mine came by and took the chassi to his job, gonna blast and paint it black. When thats done I will build the frame/floor of impregnated wood and install some "mounting brackets" so the lumber is secure while driving :)
Cya!
Skickat från min iPhone med Tapatalk
jb3
Rhode Island, USA
looking good! a nice low deck utility trailer is worth its weight in gold, nice job on repurposing what once was a chamber of mold and broken dreams
N
NTCRS
Lindås, Sweden
N
NTCRS
Lindås, Sweden
Got my new tires on the cratus wheels and put them on the 240. Since the front suspension is much wider than the back I had to space it 50mm in the back and 35mm in the front to make it sit well.
Also did a little maintence under the hood couple weeks ago, still looks like **** but it runs well. New 100amp generator (old one was 55amp), radiator and hoses, spark plugs, oil service, painted the valve- and belt cover black, air filter, washer fluid box etc etc..
Also got a pair of cromed mirrors from a friend of mine, the old ones were painted black very badly by a previous owner.
N
NTCRS
Lindås, Sweden
Also helped a friend of mine bleeding his clutch fluid on his Dodge SRT10 truck since he did restored the transmission and put a new clutch on it this winter.
Cool car, filled the shop up really easy ;)
Saltflatsracing
Honolulu,HI USA
Thanks man :)
Yeah I might be helpful, where do u live and what are you looking for?
U.S Hawaii
working on the engine right now.1994 block.020 over,Wiseco pistons and H beam rods,complete ARP stud kit,cometic head gasket,530 head mild port,all stainless valves and stock intake match ported to head.should make some power,not like my 242T racecar,but a good street sleeper.
Looking for Turbo exhaust header to install T4-76 on my B230ft 945t
Don't have time to fabricate one at this time and there are companies in your area that sells them.
Regards
Will
N
NTCRS
Lindås, Sweden
U.S Hawaii
Regards
Will
Hi again!
A friend of mine got 400(something) whp (cant remember atm), b230 with stock turbo manifold, match ported to the head and the collector, he uses a bw200sg turbo with a external wastegate welded to the exhaust housing of the turbo, 2200cc bosch injectors, stock intake etc etc, so if I were you I would change the manifold, I regret that I didnt use stock, so much easier.
Now its bedtime herr in Sweden, just finished an evening shift at work, one more tomorrow then its the graveyard shift for 3 days.
Bonus pic on the newly blasted, primed and painted trailer chassi:
Gonna continue with the trailer tomorrow, buy some materials for the floor.
RacerRick
Durham Region, Ontario, Canada
Its a 76/102mm compressor, with a 83/96mm turbine with a 1.08 A/4 T6 housing. This motor only revs to 5500rpm with the small cam, so it should be alright and good for about 800hp.
N
NTCRS
Lindås, Sweden
Long time no things done..
Cut my finger with the chainsaw couple weeks ago, so I'v been home from work unable to do anything in/on the shop/house.
Now the stitches are gone and it looks like the skin is holding up, but have to take it easy a few more days.
Next project: complete the trailer and then build a new porch on the entry side of the house [emoji4]
N
NTCRS
Lindås, Sweden
Im back :)
2 days work last week, so I was free for 5 days. Did some work on the trailer and kept on with the new house entry :)
Dont know what kind of flooring i want on the trailer, so for now i'll use it like this [emoji4]
Next up is to finish the wall around the new door, and then a buddy of mine will plaster/mudd the area and also around the windows.
After that i will lay the "floor" on the entry and cut/paint/install the facia/wind covers.
Looks like its gonna be a rainy week now so we'll have to see how many gours i can put in [emoji12]
strike a poser
Any reason you installed the entry door backwards? In the states the entry doors swing into the house not out. Just wondering, nice work though!
N
NTCRS
Lindås, Sweden
Hi!
Here in Sweden the door isnt backwards, we dont want our doors to open in the room because of the space, its much more space outside isnt it? :)
ADSR
Cool thread! Did you guys pass that new living wage there yet? Let me know, I'm ready to move.
Bempa
Avesta, Dalarna, Sweden
Isn't there also some kind of safety measure that the doors should open out of buildings in case of emergency and running in panic, atleast in commercial buildings you think in that terms
Skickat från min D5803 via Tapatalk
HCNDM
Netherlands (tiny little country in western Europe
In holland they all open in except official emergency doors which open out.
I think there is something to be said for both methods and the choice is convention more than anything else.
N
NTCRS
Lindås, Sweden
Couple days ago I prepped the wall with some "outside mudwall" and put a net all around it, and today a friend of mine came by to do the mudwork, the other friend only drank beers [emoji6]
Some "trimming" work left for him, but I think I will give it a try with the mudding around the windows on monday, cause I like to be able to do everything by myself [emoji4]
Three graveyard shifts at work for me this weekend, so wont be able to do much for now besides sleep, eat **** repeat [emoji12]
Venkman
Southern Spain
How did you find buying your house? did you buy using the bidding system? Is there any way to buy a house in Sweden without using the bidding system?
Love the Volvos owned a v70 T5 for 1 day but it was suffering from oil seal problems in the sump so the vendor took it back thankfully.
N
NTCRS
Lindås, Sweden
We bought it "private" as we say herr in Sweden. We simply asked the guy living here if he wanted to sell (I already knew he did), and a month later we signed the deal :)
So I guess thats the only way to get around the bidding system here as well.
N
NTCRS
Lindås, Sweden
Me in the white t-shirt making sure the guys working
Cut my hair and changed t-shirt
Came out pretty good, railing and painting the "white" wall + digging away the bushes and putting some crushed stone instead left to do
N
NTCRS
Lindås, Sweden
The entry came out pretty good, after this pic was taken we have also painted the "footing" in a dark hrey color, and I also built a small bench with some leftover wood.
This is the "front porsch" last year when we moved in
Took down the ugly crappy wood
Put up some new fresh ones
And also treated the deck with some greyish lasyr, gonna do the "side wood" in a week or so
After that its time for some white nice railing :)
Bears Fan
Indiana
Man the house is looking great! Nice work on the new trailer too! Looks like you have some great friends :thumbup: :thumbup:
N
NTCRS
Lindås, Sweden
Thank you :) Yeah the trailer came out nice, only spent around 150$, will probably add 200$ for lights, flooring etc..
Yeah the guys did good work, too bad the drank all my beer when they were finished ;)
both porches are looking good. going to add steps in front?
jim
Thanks Jim!
Yes i will add 3 deep and around 4-5 meters wide later on :)
N
NTCRS
Lindås, Sweden
Quick update from this day's deck treatening
The spot where I didnt paint will have a big staircase in front of it :)
Love the color!
