Is this wrench available in the US?
Beenman
Pretoria, South Africa
I searched through Amazon and Harborfreight but could not find anything. Anyone know if these are available in the US?
Its used as a bleeder tool for recessed bleed *******.
Thanks.
Beenman
Facom makes a very well reviewed set which im pretty sure are easily available in the states?
Ah thanks for the tip. I found it on the Facom website, saw that they called it an "angled socket wrench". Searching under those names I found it on Amazon (I searched under "tube wrench" originally).
:thumbup:
gonmad54
Temecula, CA
Can someone post a picture of these in use? I'm a motorcycle guy in the States so these are all new to me. I'm just curious about them and I'm always looking to expand my knowledge.
BK13
PDX, OR
That would be cool to get them at Toptul prices. The Facoms have always been a little too dear for my wallet.
Charles (in GA)
50 mi south of Atlanta
The OP has posted a pic of a wrench that is bent about 75° or so and is open on the backside of the socket.
All of the ones (Facom?) posted by others are bent what appears to be 90° and are NOT open on the back side of the socket.
Very different.
Charles
kblee27
Singapore
Very different.
Charles
Facom is 90 deg angle and has an open end at the bent, although not visible.
This is meant for pass-through of long threaded bolt.
I have one from here
http://sg.rs-online.com/web/p/socket-wrenches/1905782/?origin=PSF_438960|alt
Rich.
Newcastle, Uk
Very different.
Charles
The facoms are exactly the same as the OP's photos, although visually look to be better quality.
u118224
Northern MI
These wrenches look nice, but what do they do that a ratchet and socket won't? Made for the guy that has to have everything? I know they'll remove a nut off a long threaded rod/bolt, but there are better options for that too.
paranoid56
San Diego, Ca
just like they posted, recessed brake bleeders are a big one.
POS Camaro
Goose Creek, SC
I have an '86 Camaro that has recessed bleed screws on the rear drums. I now need these it make brake bleeding easier.
dnschmidt
Phoenix, AZ
In Europe they are used in place of combination wrenches. The offset gives your fingers somewhere to go. I first experienced them when I was working for STMicroelectronics and was sent to work in Crolles, France for awhile. All of the equipment techs used these. I saw one of them using them and asked him what it was he said; "It's a wrench." and looked at me like I was the biggest dummy of all time. Apparently, to a Frenchman, this is what a wrench is.
Beenman
Hi Gonmad, below is just a quick mock-up of how its used on the Dakar calipers.
Bleeder tube is pushed through cutout in wrench:
View media item 60353
Then the wrench can be placed over the recessed bleed ****** in the caliper.
View media item 60354
Its a similar effect to using a tube through the end of a ring spanner (I think you call these a box wrench?) when bleeding a regular caliper. But regular ring spanners don't make it into this recess.
1foxracing
Tuscarawas Co, Ohio
I also work on bikes and use these for screw & locknut type valve adjustments. No pics in use but I'll try to when I get one of those engines in.
The Facoms are open on the back as well and manufactured in the Czech Republic.
JxtAvr0CriZRDjBHwi880sUuf28VYhwfFjSrvXyIYpnxnv9yWb_bIVZzFeIGdNo2LdOpxKrFrm0JL-CMxpcMxOe5eRMMQVgSEB2LV_WWEv_P-3e90-4NlTLDhI37hSKjxUurvicusUT7g8npDespKKKIGm-QTJlj6EhKukZijSN1r0EEC-D3YVYnC1gI_050S9e5oDjsMvZ8U9YYJLSyyxteJya8_bPaNfWaq9TF_bR0xAX-ZEnXqIbv7-sd5xHuEpe08OFk4c7UwvT366JO6J84hgoEcyKPyinHSyMshUQamAa2KmzbO9O2w5JPwayYhRS07Fiz8HNcBKVXakiCfbo17brhTuiaTQAOjG5T_llpa_NOfLbZ8yhqwrvVBaJfQYljusTBZQzdD9jVlrJ3t7SA6bREw3cYaDbmsCPqmFHm9B8HDV9qyoLaK_GKLQqK7pmgDsysOkBbz7tggiI3S8vGeSWadDWE_pigrEETKZtAu2mJwqDoI-Cpl6-cXQsa4nT3zXQB-TjMX0lszqwBI0azGhXcUrtmbZeItb7CUiggN8QGoV-6yaOEjFJ8L3j0CMRlAg=w1136-h955-no
vvobbDcPwOhqNMxzqJkCaeCA6ph5EdWMKM0ZxNLUOl-aLqaE-r6P9eU7nLRB_o3ZtMjEKHtpxew10D_UgB9VzYrBRZaBt8YppO6KDBxs5APPWktCfUyZovEvtvw1TG1NV6dCWfTBQkas3HHwW3oTt3as4ArMvaBRh1o1mZhi8k3vOBEi5ugRWLtbxzOFlRHhNV_jMAEbb5GOPOJJxf5Y5-aJhhs5JQkLpAES_bo_Dm2ufcU8y8oq333kg63lrkL7jLUxXkvW63XieVWZyNKdYabDU3zmgRY7QbT4qBilCybaGeY7Eip2uToKyPk9XCHUmwXI_UTOEdQ2EFjcr_AFTStSfTbMpOeQ97Zngs1JSVUgiPivl8Kxkh113qwRTwT862h_F8VIoilbr2736SWVZgaxT12cFkVBN5F1AH36SKkOLgKmsIRNRusYJqWr_hX0hmbNmM0r89MJGoSfX_b0pkbmpjjGgFuTqCg973t7ClciweXtZJlAn4-fk0EkVfNYnqrwmQssjGQACv8CH-iFnryTjCpeK2lkPMdzJcvcIStC3F3oOYxb3gcARhK-JTsiFOgbXw=w1427-h955-no
sk farmer
nd
nobody remembers that craftsman had these in the lineup. sk also offered them through facom when facom owned them. i am pretty sure the craftsman were rebranded facom as sk was making quite few things for them at the time.
dnschmidt
Phoenix, AZ
I've got several sizes of these in stock in TOPTUL that I'm willing to sell at my normal reasonable prices but I don't have any complete sets. These are 12pt on one end and 6pt on the other which actually makes the most sense. PM me with the sizes you're interested in and I'll let you know if first I have that size and second how much it would cost you.
MementoMori99
The Road Not Taken
Strouty
Southern Maine
I am thinking of just getting the common sizes for bleeding brakes. Looks like it would be a nice tool for that job.
