Carport? and not a garage? WHAT? LOL.
You're going to fail the test worse than I! He is going to have both, of course!![]()
The sealed concrete looks gorgeous. Do you have any concern that a coat of sawdust will make it slippery?
Thomas, are your internal wall heights planned to make use of a standard stud length without cutting? If so will it also correspond with a standard plaster board (sheet rock) sheet size?
If so I can imagine it making for a very efficient build.
Hey Thomas?
Dumb question du jour.
Thanks
Steve, aka 71 MKIV
It took me a while to catch up on this thread. I love pictures of home building and took hundreds while we built our home......
.....I was curious, did the backfill after gravel occur in lifts that were compacted? From this photo below it looks like they just dumped the native soil back into the excavation without any compaction. It could be that it appears that way just because this is a corner though.
Now for your question about the rock back fill. Matt Esker tells me the rock they specify for back-fill on their basements is angular, so it interlocks with itself and doesn't settle.
I also noticed the basement walls look short.
I love watching this build.
I'm surprised you didn't use California corner framing - Can you get insulation in the hollow corners? Also why not put insulation board between the 2 x 12's on the headers?
I also noticed the basement walls look short. Do the floor trusses hang on the sill plates or do they set on top of the plates?
I was actually asking about the soil that went back in on top of the rock.......
Thomas, I have never used tapcon screws. Do you have to drill and plug the concrete?
"16 hour days do that to you. " Thomas, you're obviously putting in a lot of work yourself. How common is it in the US for customers to get so involved with the build? Over here most contractors wouldn't let the customer on their site while they're working, if only for insurance reasons.
Pete
A few of my pet peeves are walls that move or flex when you shut a door, floors and stairs (and railings!) that aren't solid. I greatly dislike floors that give a little when you walk on them, or a hand rail that wiggles when you grab it and stair treads that are loose. Hate 'em, hate 'em!!
And they look to be 12" OC. Should be very solid floor.
You're close, they're really 16" OC. Note they line up with the wall studs below them. We hadn't installed the header in the doorway in this picture. That was the first wall we framed and the 2 X 12's hadn't arrived yet. We'll install it later.
Of course the garage walls would be the first to go up!
I was wondering if someone would notice that.
But I am shocked and stunned my friend, this is bigger than clocked switchplategate! Horrified to see the time lapse camera secured in place by cable, or zip, ties that haven't been trimmed off! With flush cuts, obviously.....
Well that was deliberate of course.Not only is this is a temporary set up, I wanted folks to notice the installation and steer clear of it and not bump it.
You might note that I did use high density foam between the wood block and the post and also I padded all four corners between the zip ties and the post so I wouldn't leave a mark on the painted post.
Pete
