Tell me more about this "cleanout tee".....what does it do and what is the purpose of it
I looked at and have seen quite a few hanging heaters, including the one we have at work (municipal vehicle garage), that does not have any cleanout tee
Pros use 3 sheetmetal screws (self-tappers at that heater exit). This is required on any slip type flue joint.
In what order do you suggest install:
1) Hang/Mount the unit
2) Run the gas line
3) Wire up electrical/tstat
4) Run duct work
Self tappers don't work well on the thick aluminum exit housing. They are trying to drill and thread at the same time.
There's no need for a separate circuit if you have a switch. It can't hurt, but there's nothing to require its own circuit.
Gonna get this thing done before winter or just talk about it?![]()
Here's a pic, at the garage ceiling.
My ceiling joists are 48" apart.........had to add a lot of 2x4s and bracing to hang mine
This kit was nice, but I could not justify spending $95 on it
http://www.qcsupply.com/quicksling-flush-mount-swivel-with-h-bracket.html
I got the DuraVent Vent Unit Heater Kit for pretty darn cheap, IMHO
$63.75 shipped.........very pleased for my FREE heater
3in. Vertical, Model# 0370
Includes:
(3) 24 in. long pipe lengths
(1) 12 in. pipe length
(1) roof flashing
(1) storm collar
(1) cap
(1) 90° elbow
(1) draft hood connector
D45- where did you go the vent kit for $63.75 Please share
For $85.00 shipped, this looks like a good kit
DuraVent Vent Unit Heater Kit — 3in. Vertical, Model# 0370
http://www.ebay.com/itm/252249914650?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Ok thanks
Just bought 15 feet online for $8 shipped
I probably only need 10 feet
How far is the run and what size is the line you're tying into?
It's easier to start at the source and work your way to the appliance, using a flex line at the appliance.
One valve would be sufficient, but good thinking to put one where you tap into the existing line.
