Hot Dawg 45K Heater Install
D
D45
NW INDIANA
According to the manual, this pulls only a total of 3.7 AMPS
Should I wire it up on its own 10 AMP circuit or can I tie it into something else?
I would only assume running it on its own circuit, through its own dedicated wall mounted switch, will be the best route?
D
D45
NW INDIANA
Thanks, I would want the switch on the wall though...........for easier access to flipping it on
csp
Franktown, CO
There's no need for a separate circuit if you have a switch. It can't hurt, but there's nothing to require its own circuit.
Gonna get this thing done before winter or just talk about it? :D
D
D45
NW INDIANA
That's my plan, to slowly work on a few install pieces here and there
Plenty of time, I have about 5 months :)
BCreekDave
Dayton, OH
Tell me more about this "cleanout tee".....what does it do and what is the purpose of it
I looked at and have seen quite a few hanging heaters, including the one we have at work (municipal vehicle garage), that does not have any cleanout tee
The "T" is a somewhat arguable feature that can allow for any condensate to settle in. It can also provide for an easy inspection point to see if anything is blocking the vent pipe (birds,vermin).
I installed one and when the county inspector came by he asked about it and said it was not required by any code he was aware of, but said it made some sense. He was a bit concerned about the cover coming off. It just snaps in place on the inner pipe. I ran my Hot Dawg all last winter and never found a single drop of condensate. I actually had to order it from ebay as no local supply had one in 3 inch. Kind of goes along with what the inspector said.
Only other thing not mentioned in the thread so far is a CO detector. The inspector specifically had to see one installed and wanted a verification of its function.
One other thing I did was to pop rivet the b vent pipe to the cast aluminum Modine supplied exit vent. The area on the Modine part that the b vent pipe slips on is pretty short and could slip off easily.
Sent from using Tapatalk
D
D45
NW INDIANA
Pop riveting is a smart idea
I do have a CO detector in my shop
With 6 roof vents, I'll be fine
csp
Franktown, CO
Pros use 3 sheetmetal screws (self-tappers at that heater exit). This is required on any slip type flue joint.
D
D45
NW INDIANA
In what order do you suggest install:
1) Hang/Mount the unit
2) Run the gas line
3) Wire up electrical/tstat
4) Run duct work
BCreekDave
Dayton, OH
Definitely 1 first. On mine, the final location was determined by #4 as the attic was very crowded in this area.
I made a cardboard template of the heater including the vent as it was going to penetrate the ceiling. I pitched the diagonal of the heater so that two of the lags would hit existing ceiling joists. That way I would only have to add two bridges between joists for the other two lags. My ceiling was drywalled so it is not easy to tell what's above. I wanted the vent to penetrate right in the middle between joists.
Once it was mounted, I then proceeded in the order you say, but I'm not sure it makes much difference.
BCreekDave
Dayton, OH
Self tappers don't work well on the thick aluminum exit housing. They are trying to drill and thread at the same time. They are really intended just for sheet metal to sheet metal joints. I know, I have seen the "pros" use them, but that's cause the pop rivet gun was in the truck.
csp
Franktown, CO
2) Run the gas line
4) Run duct work
The only one that matters in order is the first one. At some point you're just going to have to start and exercise some judgement of your own. Don't turn this into a job that's harder than you're already making it, seriously.:dunno:
I can't even tell you how many of these things I've installed and have never had one problem with a self-tapper in those exit housings. Drove three of them into a housing just this afternoon on a furnace install. Yes, it's trying to drill and thread at the same time and it's a little more effort for the impact driver, but it works just fine. Time is money. I can't say that I've ever seen a pope rivet ever used in a flue.
D
D45
NW INDIANA
Its up, mounted and perfectly level in the back wall of the shop......I have it mounted 20" from the wall
I have it mounted in the dividing wall, between the main shop and the smaller storage shop........just above the area marked "sliding barn door"
Power Sedan
SE Wisconsin
Must be a code requirement for our municipality, because I was informed to have a separate circuit, with a switch to pass inspection.
BCreekDave
Dayton, OH
Mine did too. It did seem redundant as my switch is directly above the panel that has the disconnect.
D
D45
NW INDIANA
I am actually going to be swapping out my small 6 slot circuit subpanel (100amp) for a new 12 slot circuit (100 amp) subpanel next month......along with rewiring the entire shop
This way, I will just have the heater on its own circuit and its own switch, since I will have plenty of slots in the subpanel
Power Sedan
SE Wisconsin
My ceiling joists are 48" apart.........had to add a lot of 2x4s and bracing to hang mine
This kit was nice, but I could not justify spending $95 on it
http://www.qcsupply.com/quicksling-flush-mount-swivel-with-h-bracket.html
I too thought of utilizing this mounting hardware. Mines been mounted (as pictured) for almost 11 years now. It does look a little more professionally finished, but $95, thats debatable. I alwsys intended finishing the ceiling, so all-thread workd for me, since this adaptive mounting fixture wasn't available back then.
D
D45
NW INDIANA
The heater is up and mounted, was very interesting hanging it myself!!!
8 total lag bolts.........rock solid
I spaced it on the back area of the garage, so that it can blow down the entire length of the shop........I also moved and remounted my adjustable three speed shop fan to help circulate air
I think the heater is spec'd out to blow 20-25 feet, so there is about 40 feet down range for the warm air to blow
I mounted the heater 20" off of the back wall, 18" is suggested........I need to move the shop light fixture over a few
Time to run some power, some gas line, hookup the tstate, and install the vent kit.............time is ticking, but I am also in no rush
D
D45
NW INDIANA
Is a direct wire THAT critical?
With only 3.7 amp draw and a close 20amp outlet in the ceiling........adding a plug would be oh so easy
csp
Franktown, CO
It's no a matter of amperage draw. It's a matter of being able to isolate the circuit and shut it off easily.
D
D45
NW INDIANA
I took the tstat out and mocked up a good location for the low temp thermostat
I open the package, expecting a tstat wire harness............no luck
There is about 18" of tstat wiring coming off the back of the heater..........two wires in a sheath (I was expecting more wires, no???)
Time to buy some..........any suggestions or anything in a 2 wire bundle? Is wire gauge important? 18/2 looks very inexpensive and standard
csp
Franktown, CO
Go to the big box store and buy however many feet of two wire thermostat wire you need in the bulk wire section. That's as much detail as you need to be concerned with. It's literally called thermostat wire.
The t-stat didn't come with wire as the assumption is that the wire already exists in the wall.
D
D45
NW INDIANA
Ok thanks
Just bought 15 feet online for $8 shipped
I probably only need 10 feet
Kcragun
I got the DuraVent Vent Unit Heater Kit for pretty darn cheap, IMHO
$63.75 shipped.........very pleased for my FREE heater
3in. Vertical, Model# 0370
Includes:
(3) 24 in. long pipe lengths
(1) 12 in. pipe length
(1) roof flashing
(1) storm collar
(1) cap
(1) 90° elbow
(1) draft hood connector
D45- where did you go the vent kit for $63.75 Please share
D
D45
NW INDIANA
Ebay......."damaged box"
Contents were perfect
I'll see if I can find the link
I have less than $100 into the setup so far, including the heater, tstat, vent kit, and wire I just ordered
D
D45
NW INDIANA
Auction 252249914650
At $85 shipped
Same place i got mine from, not sure why it's $20 more
Still $85 is good
csp
Franktown, CO
Link found in this thread:
For $85.00 shipped, this looks like a good kit
DuraVent Vent Unit Heater Kit — 3in. Vertical, Model# 0370
http://www.ebay.com/itm/252249914650?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Ok thanks
Just curious, do you have some aversion to buying something locally? I get the convenience thing, but I also get having a project completed and off the list.
D
D45
NW INDIANA
I really don't have time to shop during the week
I leave early and get home late......I take a "company vehicle" but can only use it "to and from" work only
Weekends are my time and its easier and cheaper to have various parts delivered
D
D45
NW INDIANA
Going to start running black gas pipe soon.......my plan is to start at the heater and run backwards, into the crawl
I am planning on two valves, or should I add three?
One valve at the heater
One valve where the pipe enters into the garage
One valve in the crawl
I will be getting into the crawl, and adding a "T" where the gas line is feeding the NG fireplace
Also......what size should be used, 1/2" or 3/4" to the heater?
csp
Franktown, CO
How far is the run and what size is the line you're tying into?
It's easier to start at the source and work your way to the appliance, using a flex line at the appliance.
One valve would be sufficient, but good thinking to put one where you tap into the existing line.
D
D45
NW INDIANA
The line I was going to install a "T" onto, feeds the NG fireplace........this line runs under the crawl about 20 feet to the bottom of the fireplace. The fireplace is on the common wall with the garage. This line is 1/2"
The dryer and fireplace is fed off a 3/4" line (I believe?) shown in the top of the picture
The valve shown is soley for the fireplace
Lastly, what is the choice or best line to use for the flex line? Just flexible appliance line for like gas dryers and stoves?
